Question about KitchenAid (KSRD22FKST) Side by Side Refrigerator
Freezer won't shut itself off
The freezer side of my Kitchen Aid SXS refrigerator runs constantly and won't shut off by itself. I have unplugged it for a few hours and turned it off manually, but the problem persists when I plug it back in/turn it back on.
    Problem Solver:
  • 10 Answers
Turn the temp up a bit and see if it shuts off if not it needs to be repaired,hope this helps ya
Cheers
Johnthetr870
Posted on May 15, 2009
Freezer not getting cold and dripping water
I own a similar Kitchen Aid fridge that had a defrost icing issue: Kitchen Aid KSRP25FNBL00
> Ice had plugged the drain hole at bottom of chill coil section inside the freezer compartment.
> I learned that the coil, circulation fan was not working, but condenser was working.
> I paid a tech to replace the circ fan, about $200, including a new swiss-made fan. He said it was unusual for these fans to fail, but not unheard of.
Expensive, but saved the purchase of a new fridge. Has worked great for 6 months since then.
HOpe that helps.
Al Zayha
Mar 09, 2014 | KitchenAid (KSRD22FKST) Side by Side...
How to defrost freezer in kitchen Aid bottom drawer freezer
My kitchen aid bottom drawer freezer kept melting and freezing to block the drain and then water would leak out all over the floor. I did the WHOLE fridge/freezer defrosting process once, when i really just needed to do the bottom.
I have had issues with other Kitchen Aid (NEW BTW) appliances so I've talked to many repair people. One guy who came out to fix something else, told me that the freezer is really a pain to get to close completely. SO, when you don't close it all the way (Extra push) it will melt and then re freeze when it is closed properly. He suggested I take everything out, leave it open and use a hair dryer on the ice until it melts. Then use a wire hanger to unplug the drain to make sure its draining properly.
It works! You really have to make sure the drawer is shut ALL the way. I have a 2 yr old who is constantly opening it up...this is my issue! The seal is not that great and you have to really push it closed to prevent the ice build up issue.
Hope that helps!
Sep 10, 2013 | KitchenAid Refrigerators
Refrigerator kitchen aid
Might be a defrost problem. or maybe a damper or bad fan motor. Look in the freezer for signs of frost on the back wall. If you see it then that means the frig is not defrosting. Unplug the unit for a few days and if it goes back to normal operation that will confirm a defrost problem.
May 22, 2013 | Refrigerators
Refrigerator won't cool
Unplug for a few hours with doors open to do two things 1 to cool down compressor that got to hot from no fan running and to melt ice off coil in the freezer. There is an internal overload built inside compressor and will stay hot with constant power, thats why you need to unplug. Also check bottom coils where fan is and make sure not blocked with pet hair or debris.
Jan 27, 2018 | Jenn-Air JCD2389G Side by Side...
Freezer not freezing on side by side fridge
Try turning the unit off and leaving the door open for half a day or more in case there is ice clogging something somewhere? If there is no cooling going on whatsoever and fan/s and compressor are running it sounds like a gas leak has devaloped or the compressor has stopped working correctly. If the compressor has stopped then possibly the controll circuitry to it has a problem.
Hope this might help
Dec 01, 2009 | Ovens
KSRG25FKWH04 is not getting cold its a kitchen aid side by side
See if you can hear the evaporator fan motor running in the freezer, if not, you need to replace it because it forces the cold air from the freezer into the fridge section to keep it cold.
Nov 11, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Kenmore SxS 596.52673200 stopped cooling
You have a refrigerant leak. Your coil in the freezer should be frosted. You're looking at 600 dollars minumum for repair.
Sep 12, 2009 | Frigidaire FRS23H7CS Side by Side...
Ksrs25ikss01 kitchen aid fridge portion not
1.check if the fan inside the freezer is running
2. if ref runs none stop, defrost timer is out.
3. or it could be the high limit that paired in series with the defrost heater
good luck!
Jun 25, 2009 | KitchenAid Superba Architect KSCS25INSS...
Compressor runs continuously, and center bar (heat dissipator) is extremely hot to touch.
Molly, The hot bar is a normal part of the sealed system (compressor) operation. The relay they told you about is on the back of the compressor and I would not recommend you changing that. The refrigerator is a balanced system, the freezer air removes the heat from the refrigerator side. If the compressor runs all the time, look for food close to the edge and not letting the doors close completely. Move items back. Don't over pack the freezer, the air must circulate. The refrigerator of today runs longer and uses less power that the old refrigerator. If you are still having issues with this model call a authorized Kitchen repair person in you area and ask how much they charge to come to your house and give an estimate.
May 01, 2009 | KitchenAid Superba Architect KSCS25INSS...
Compressor runs, very little cooling, internal fan not running
You will need to unplug refrigerator and open plane inside freezer to see if fan is stuck or burned out. If freezer is frozen over with ice you will need to warm the ice for removal. Let me know, when you are ready, Sea Breeze
Mar 22, 2009 | KitchenAid KTRP22EK Top Freezer...
KitchenAid (KSRD22FKST) Side by Side Refrigerator Logo
203 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
