Question about Garden
How can I open the spool for line replacement? Please help
    Problem Solver:
  • 10 Answers
Just push the bottom of the weed wacker in and turn to the left the spool should fall out if u need anymore answers just ask
Cheers
Johnthetr870
Posted on May 15, 2009
Replace trimmer line
The steps for replacing line in a single line trimmer head are virtually the same for many trimmer head types, like double line trimmer heads.
1. Remove the Trimmer Head Spool
Removing the spool is the first step in replacing trimmer line in any conventional trimmer head, but trimmer head spools can disassemble in different ways.
The trimmer head pictured above and below disassembles by simply unscrewing the knob around its arbor bolt. Other trimmer heads can use press tab and other twisting styles for disassembly.
2. Insert Trimmer Line and Wind the Line
Single line trimmer heads have just one channel in their spools for winding line. The channel will have a hole in it somewhere that keeps the line in place as it is wound around the spool. Insert one end of the trimmer line in the hole.
Depending on the trimmer head, it might be helpful to bend a small portion of the cutting line at an angle before inserting it in the starter hole. Also, cutting the line at an angle can help this first step on some trimmer heads.
Of course, it is also important to make sure that the replacement line matches the diameter specification of the trimmer head before beginning. Once the line is started correctly in the channel hole, you're ready to wind. Most trimmer heads will indicated the correct winding direction right on the spool somewhere.
It's also important to wind the line carefully, keeping it in neat rows as much as possible. The line will have a much higher chance to feed incorrectly during trimmer use if it suffers from sloppy winding.
3. Snap the Line into its Retaining Notch
A conventional trimmer head will have a retainer on its spool. Snap the end of the trimmer line into the retainer after it is wound around the spool. The retainer will hold the line in place as the spool is replaced in the trimmer head assembly.
4. Replace the Trimmer Head Spool
With the cutting line held in place, the spool is ready to be replaced in the trimmer head assembly.
First feed the extra trimmer line through the trimmer head eyelet. Make sure to release the line from the retainer before completely securing the spool into position.
Replace any knobs, bolts, or other trimmer head pieces removed during disassembly.
Your single line trimmer line is now reloaded, and your trimmer should be ready to get back to work.
Although there are many steps to reloading line the conventional way, a little practice and familiarity with your trimmer will speed the process up a great deal. Once you're up to speed, reloading trimmer line this way can take less than five minutes.
If you want to know about the double line replacement, please click this
Thanks.
Apr 01, 2012 | Garden
I have a Ryobi spinning reel SX4N,in excellent shape. Ineed to know how the springs go onthe bail to makr it work. Thanks
With the new line threaded through all of the fishing rod's eyelets, open the bail. You open the bail by pulling it over across the spool, until it locks in an open position. Tie the line in a knot around the reel's spool, and loosely wrap the line around the spool at least 7 to 8 times, then pull slowly on the line, to tighten the line that is wrapped around the spool.
Holding the box or spool of fishing line between your feet, so that it will remain close to you, start reeling in your casting rod. When you start reeling it in, the bail automatically closes, and makes the line wrap onto the spool properly. Reel the new line in until the spool is about 75% full, or to the lines marked inside the reel's spool. Cut the new line about 8 feet from the outer-most eyelet of your fishing rod.
Hope this solution has been helpful?
Jul 08, 2011 | Sport & Outdoor - Others
Having trouble replacing trimmer line
Hello. I just answered a similar question not twenty minutes ago. Hope this helps.
Please read all the way through this before beginning to actually rewind the spools.
1. Pull the spool off of the head. Clear the dust and debris out.
2. Note that it is actually two spools that are separated by a disc, and that the disc has a slot in it. The outer spool is the spool closest to the bump head, and the inner spool is the one that fits closest to the machine and has notches in it. If you turn the spool so that the inner spool base is up, you will see that there are decimal numbers next to the notches. The decimal numbers are your line size(s). I say sizes here as some machines will accept more than one line size. You will also notice arrows on the inner spool base, telling you which direction to wind the line on to the spool(s).
3. Wind the inner spool first: Put the end of the line into the hole that is in the core of the inner spool. insert ~1/8". Wind in the direction of the arrows until you get roughly even with the divider between the inner and outer spools. You want to end up with your line 180 degrees from the slot in the divider, and snap the line into the notch that is in the inner spool base. You want about 6" of line beyond the notch. Cut the line, leaving a 6" tail.
4. Wind the outer spool: Wind the outer spool like you did the inner spool, filling the spool as before, and ending at the slot in the divider. Feed the line through the slot and snap it into the notch. Cut a 6" tail as before.
5. Reinsert the spool: Get the spool close to the machine. Insert the tails into the grommets in the head, and snap the head into place.
6. Preparing the line for use: Push the spool in as if you were bumping it against the ground to advance the line. Grab the tails and pull. This will release the line from the notches, and should release about 1" of line in doing so.
You should be good to go.
Every so often, it's a good idea to put some graphite dust into the spool just before putting the spool back onto the machine. This helps when you are advancing the line. I do this every 8 to 10 times I rewind the spools.
If this fails to correct your problem with the spool, it would be best to purchase a replacement spool.
Best regards, --W/D--
Jan 31, 2011 | Tanaka 22" Double Sided 24cc Hedge Trimmer
I need to know how to restring my Twist & Edge RTE weedeater. I've looked everywhere & can't find an answer that makes sense. PLEASE Help.
I found this solution on the net. I hope it helps.
Unscrew cap and remove. Remove line guide ring. Note which way to put line guide ring back on, slot to outer edge. Remove the empty spool.
Don't take spool apart unless you need to get inside to remove string. The outer half should be yellow. Cut 25 ft. of .065 line. Start pushing the line inside the spool from the center making sure the string is winding inside in a counter clock direction which should be shown on the spool. Keep pushing until there is about only 6 in. left.
Replace spool. Then the line guide ring, making sure to pull the string through the middle of it. Then hold the string on the slot in the ring while replacing the cap.
Oct 07, 2010 | Poulan Weed Eater Rte115 4.5 Amp Electric...
I have 11" Toro Trimmer and cannot turn spool counterclockwise to replace line. I am a woman and do not know what to do. Used strap wrench large open end wrench and cannot budge this spool.trimmer is less...
With most trimmers, you may have to push the spool casing inward and then turn. It should unlock fairly easy. You may also want to spray the divider crease on the spool casing with some kind of lubricant like WD-40 or Tri-Flow to facilitate the process of detaching the spool casing from the body. Good luck. I hope this helps.
Jun 29, 2010 | Toro Electric Trimmer
How to install replacement line for a Ryobi 18v weedeater
The long bolt coming down at the end shaft like place reel over bolt then turn back and forth slowly while pushing upward and it should lock in and take knob or bolt at end and tighten to the right.
Jul 05, 2010 | Ryobi Garden
Replacement of Cutting Line! How to do? anneodello
There should be a half sphere-like object on the bottom of the spool where the line goes. Twist counter clock-wise to remove.
If it is a duel line trimmer then:
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
If it is a single line trimmer: Then just wind a single piece of string clockwise onto spool. This may need to be longer than 7ft.
Jim
Oct 21, 2009 | Black & Decker Garden
Echo trimmer with bump feed is not feeding
Sadly, they do wear out..... but sometimes they're just stuck. The line can refuse to feed if the line is caught on itself in the spool winding, or if the head is bad. Try this: remove the spool and clean it pretty good. Check that the line isn't caught on itself in the spool. Sometimes it just locks itself in between wraps, and you have to pull it out of the groove to get it to continue to feed. Give the inside of the spool a liberal dose of graphite powder. Put the spool back on with line. Bump it against the ground as much as you feel necessary to further distribute the graphite. Now, push the spool in as if to feed line, and pull on the line. It should feed a bit and stop. If it does, you're good to go. If not, replace the spool.
Best regards. Hope this was helpful to you, --W/D-- Please feel free to rate this solution! Thanx!
Jul 30, 2009 | Echo Garden
Can not remove spool to replace string
If it's like my Ryobi, the alignment arrows are for feeding in string, not removing the spool. When aligned with the arrows, you should be able to insert two pieces of line into opposite sides of the housing. The ends of the line will come out of the spool next to a tiny hole. Put the end of each of the two lines into the holes, then pull the two lines from the outside. This will lock the ends of the line into the tiny holes in the housing. Now you can turn the housing by hand to wind the lines onto the spool. I think it will take about ten feet of line (on each side).
Alternatively, spin the bump stop out of the assembly. This holds the spool in, so when the bump stop is removed, the spool comes right out.
I hope this helps.
Jul 01, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
I am trying to spool trimming line into my black and decker GH1000. It is supposed to feed automatically. It is not. I'm afraid I fed the line onto the spool incorrectly. Need help
Yes, it does feed automatically.
Please make sure the trimming line spooled in your spool regularly.
If above does not work, please go to service center to change a lever inside spool housing.
Aug 29, 2008 | Black & Decker String Trimmer Cordless 12"...
Garden Logo
194 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
