Question about Kenmore HE2 Plus Front Load Washer
It wont drain and wont spin. It is flashing F and DL. I have a Kenmore Elite HE 3t
    President:
  • 1,136 Answers
Hi, most common problem is the pump gets plugged. Take off the loser front panel and you can see the pump front middle. It has an access that you can unscrew and see what is in it. You can get the water out of the machine by using a shop vac and **** the water out of the drain hose. This will let you get all the water out. If you have a floor drain, you can lay the drain hose in it to release MOST not ALL of the water.
If I can assist you fyrther, please let me know.
THanks
Vic
Posted on May 15, 2009
Cycle will not spin and drain properly near end of cycle. Keep getting F11 fail codes when I try resetting my kenmore elite HE 3t any suggestions?
Hi Shaun, I just found (and watched!) a good youtube video which may help with your problem regarding the F11 code, link follows below.
Trust this helps, best regards Alan
Troubleshooting and Repairing the F11 Error Code in Whirlpool Duet Washer
Feb 12, 2015 | Kenmore Washing Machines
Kenmore Elite HE 3t motor runs but does't spin or drain
SOUNDS LIKE BAD CLUTCH OR MOTOR COUPLER IF ITS BELT DRIVEN MAY HAVE BAD BELT OR LOOSE BELT. i DOUBT ITS IN UR DRAIN PUMP AS UR NOT GETTING A SPIN WHICH IS WHY NO DRAIN.
Oct 17, 2014 | Kenmore Washing Machines
Hi, We have a kenmore Elite HE 3t front load washer. When we try to start the washer we are getting an error on the screen. The error flashes DL and then F. what does that mean? Thanks! Sabrina
'DL+F' stands for Door Lock Fault. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor. Both require a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Apr 29, 2011 | Kenmore Washing Machines
What do you do if you get an F21 code on a Kenmore Elite HE 3t steam front load washer
The F21 error code is an indication that the unit has a too long of a drain out condition. If the control call for the unit to drain & the water does not drain out in 8 minutes or less the unit will stop & flash the F21 error code. I would recommend checking the drain pump & pressure switch circuit.
Mar 06, 2010 | Washing Machines
Kenmore elite 3t the front light to select wash blinks but when s
Press 'drain' & 'spin' together for 3 seconds to see if it clears. This is your control panel lock.
If not cleared unplug the washer & wait for 30 minutes for the CCU (computer) to reset.
If helped you can rate.
Mar 01, 2009 | Kenmore Elite 45986 Front Load Washer
I have a kenmore elite 3t that fills with water when not in use
sounds like you have a bad fill valve it should only let water into the machine when the fill valve is energized. If water is coming in when unit is not in use change the valve.
Dec 17, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 3t washer
unplug machine, go down to the pump motor and squeeze the tab and connector and pull it away from the pump.
Oct 24, 2008 | Kenmore Elite 45986 Front Load Washer
F 11 Error Code
The door will stay locked if the machine did not drain properly. Try running a Drain & Spin cycle.
Mar 17, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
228 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
