Question about GE Spacemaker JVM1640SJ Microwave Oven
MY GE SPACEMAKER MICROWAVE CUT OF AFTER ABOUT 5 TO 10 SECONDS
WHEN I TURN ON THE MICROWAVE THE DISPLAY IS FLICKERING FROM BRIGHT TO DIM. IT RUNS A VERY SHORT TIME FORM 2 TO 30 SECONDS, BUT MOST TIMES JUST AFTER A BOUT 5 SECONDS IT CUTS OFF AND I HAVE TO RESET THE CLOCK TO START IT AGAIN. IT WAS FIRST ONCE IN A WHILE NOW IT IS CONSTANT. I WAS THINKING A WEEK POWER SUPPLY, BUT I DID NOT SEE ONE ON THE WIRING DIAGRAM. FUSE IS GOOD. NOTHING OBVIOUS BROKEN OR BURNED. SO CAN YOU GIVE ME SOME IDEA WHAT IT MIGHT BEE?
    Problem Solver:
  • 10 Answers
Might be a short in the system to cook the food or a short in the board for it if there is i would recommend in getting rid of the microwave or getting it fixed otherwise its a big fire hazard for ya
Hope this helped ya
Cheers
Johnthetr870
Posted on May 15, 2009
My GE White Spacemaker Microwave just stopped heating-you hear the motor running but the light inside grows bright to dim by a few watts while going thru any cycle of heating. Any answers?
The magnetron has probably failed, there are also two other parts that can be a factor, the high voltage capacitor and diode, the high voltage is generated by these items which in turn heat the food.
Feb 13, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave starts and runs 2 seconds and stops. Display is jibberish. After resetting date and time, it will again run 2 seconds and then shuts down again.
See this FixYa solution. even if your model number is different.
Oct 26, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker Microwave powers off after few seconds of working
Hello :
This could happen because of a bad keypad . Just replace it and problem will be solved . I need you to think before replacing it . Because sometimes a new unit is better than repairing . Think it before !
good luck .
please rate !
Apr 01, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker shuts off after a few seconds and asks for the clock to be reset
Ge Spacemaker comes on ok but after a few seconds the noise level goes up significantly and it does not heat. It keeps running until the time runs out but it doesn't heat.
Feb 11, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Surface lights are not turning off and stay on Bright. Any thoughts on how to fix this?
Unfortunately they are controlled by the circuit board and it is not repairable. The board will have to be replaced.Depending on age of unit you should call manufacturer and see what they say < might repair free>
Apr 20, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Ge spacemaker runs but wont heat
Hi, there are three issues that will cause a no heat situation in a microwave. these issue are a failed Magnetron, busted cut-off fuse and, failed diode.
I recommend checking all these area that are located inside the microwave for faults.
The most common issue will be a failed Magnetron.
The diode and, fuse will be located on the noise filter assembly.
Jan 16, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Ge spacemaker II microwave. sensor error lite comes on
Sounds to me like you have a bad magnetron tube. Call GE Factory Service as there is either a 5 or 10 year parts warranty. Or schedule a service call online at www.geappliances.com
Dec 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
362 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
