Question about Toshiba DKT-2010 Corded Phone
The message light does not blink when there is a message.
The phone being used was at another extension and the light worked there. The girl who used to be at the extension in question said her light never worked. Is this in the set up of the extension? We got to an option which said to change your Message Notifcation, press 7. But when we get there it asks for a Notification template...which we dont' have. Is this the right spot to change this or do we need to call our phone guy?
Our phone's message button is lit and blinks constantly, how do I get it to turn off?
Posted on Mar 03, 2008
  • 131 Answers
No it is not. that is for dialing home, pager or whatever. the voice mail system needs to have message notification on for your extension and the code it uses. This is done by your tech. If the phone will get a message ligt when moved to an extension that it is known working, on then it is NOT the phone. It is either the phone system or the voice mail system programming.
Let me know,
Posted on Oct 19, 2007
How do you get the message light to stop blinking and the call S12 to go away?
(ITCM # 3 plus your extension number) to cancel message
(ITCM, HOLD) to retrieve message
May 21, 2014 | Comdial 8324S-PT Corded Phone
My message button is flashing on my Toshiba DKT2020SD phone, telling me i have a message. When i press the Msg button, it it calls another phone extention in another office and i hear that it is on speaker...
This is what I wrote up for our inhouse manual on telephone administration for this phone:
Problem: An employee pushes the Message button to receive a message but it calls someone else's desk. This is caused by whichever extension the phone forwards to when pushing the Message light. For example: if the person at 333 pushes their blinking message light and it forwards to 316 that means that the person at 316 most likely tried to call 333, got a busy signal and accidentally pushed the Message button before hanging up thus setting 333 to call forward to their extension when they got off the phone.
All phones on our system should have this feature turned off, but if it happens this is the two step process to resolve the issue:
Solution: First, push the Message button to figure out which extension it is forwarding to. Take note of the extension and hang up. With the hand set NOT picked up, dial #409 and Release. You may have to do this multiple times to clear the call forwarding because it needs to be done for each incidence that the person accidentally set up call forward. Finally, in the management software go to Station > Station Assignments. Select the extension # that the Message button was forwarding to (the one you noted above). Under the Basic tab at #41 Active Message Waiting select Disable. Select Submit.
Aug 29, 2011 | Toshiba DKT2010SD Phone
We have a KX-TA624 phone system connected to a TVS50 voice processing system. I have one user who has a KX-T7730 phone and his message button wont light when a voice message is left for him. I know the...
The user may have brushed onto the 62x commands to change or turn off message notification. From the subcriber's mailbox, choose option 621 and make sure it's enabled, then 622 and make sure you're using option 2. (continuous). If neither of these work, have the owner log into mailbox 999 and make sure that the owner's extension of the broken extension matches the extension. That's option 611 mailbox number and follow the prompts. The extension is the mailbox.
Aug 05, 2010 | Panasonic KX-T7730 Corded Phone
The New Voice Mail message appears and the light blinks and there are no voice mails.
What system? A Panasonic KEY SYSTEM (76xx/77xx/74xx/72xx phones) can have messages from other sources than the VM system.
If it's a display phone, try pressing the MESSAGE button without picking up the handset and read the display. It will tell you where it came from and you can press INTERCOM and ring that extension.
It works the same way if you call an extension and press the MESSAGE button...that leaves a message. Panasonic systems have a MW cancel code that usually begins with 700. In a TA system it's 700#, in the TDA/TAW's it's *700 plus your extension.
If it's a Panasonic cordless, it's probably hearing stutter dial tone from custom calling features.
Sep 27, 2009 | Panasonic Lands Phones
Message light blinking. LCD has myext-voicemail#
I received a voice mail which seemed to correct the problem. Sort of the same solution as when an actual extension is displayed. (you connect/disconnect)
Jun 18, 2009 | Toshiba DKT2020SD Phone
DKT2020-SD Msg Light Blinking for no reason
#409 to cancel receive message...may need to key in few time to cancel few message
#64+sent messane extn - to cancel sent message
Apr 17, 2009 | Toshiba DKT2020SD Phone
Strata 3010 msg light won't turn off
To manually turn off the message waiting light press your extension button then press #409. Do this step for each message received.
Mar 25, 2009 | Toshiba DKT 3010 Corded Phone
Intercom light stuck on and no dial tone on GE 4 line phone
You may need to assign an intercom ID for that unit by pushing one of the intercom buttons at the top.
Dec 05, 2008 | GE 2-9450C Corded Phone
Message waiting indicator light will not turn off keeps flashing
Slide the Nortel Grey Bar above the Hold & Rls buttons to reveal the setup button.
  1. Hit that button to show *Options List / # Setup list
  2. Press * to go into options.
  3. Use the arrow buttons or hit 3 to go into CLEAR MESSAGE WAITING
  4. Then hit 3 again to clear the message waiting
This should resolve the blinking light.
Nov 11, 2008 | Astra Meridian 9417 Corded Phone
Toshiba DKT-2010 Corded Phone Logo
384 people viewed this question
Top Toshiba Lands Phones Experts
Oloyede Monsuru
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
