Question about Mitsubishi VS-55707 TV
Picture darker/less color/smaller until warm up
Seems something is wearing out & I'm trying to decide to bury it, repair it or upgrade. It's been a great TV but I don't want to kick a dead horse. The description pretty much sums it up. It's taking longer to "warm up" and get a good picture. The color is mostly dark/brown when first turned on. The picture is also less than full screen. After maybe 15 minutes from turning it on we're back to a normal picture. We've done the advanced convergance which helped sharpen the picture & color but the "aging" problem still exists. I'm wondering what might cause this and what an estimated cost would be. Do I say goodbye to my 8 year old friend or say good buy to a nice new plasma or LCD which I'd prefer to put off for a few years?
    Scholar:
  • 135 Answers
Hi there!
Have you checked for dust on the Tubes and mirror? This may cause a bad picture quality. Also power supply related problems like capacitors can cause a dark picture. Try replacing some of them in the power supply area and line stage.Also adjustments in the service mode,but for this you will need the service manual. Good Luck,JUS004
Posted on Feb 29, 2008
My daughter bought back a mini amana fridge it seems too hot on the sides and its on 6 os that normal??
Sorry but I don't recognise the fridge brand. The internet suggests these are not the things called mini fridges but in reality are merely coolers so I guess it is a regular fridge designed to keep stuff between 2 and five degrees C.
Not sure what you mean by 6 os.
Conventional fridge design has a thing at the back that looks like a radiator. This condenser is prone to corrosion and is easily damaged resulting in the loss of refrigerant. Since it was decided all types of refrigerant gas is damaging to our atmosphere, manufacturers have been increasingly burying the radiator thing in the fridge casing where it is protected, often at the sides. Usually the condenser will become quite hot until the fridge interior is down to the required temperature when just maintaining the inside temperature it will vary between warm and cold if the door isn't opened much and the insulation and door seal is in good condition.
Burying the condenser(s) in the casing makes them less efficient at losing heat and so they will become hotter than the conventional old-fashioned design during the interior cooling stage..
I hope this helps and little.
May 15, 2016 | Amana Refrigerators
What is wrong with my Sanyo TV?
T'Con board fault. Check and replace it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD screen are similar, irrespective of its brand and screen size.
Mar 03, 2016 | Sanyo Televison & Video
My samsung led tv is getting dark
With a DLP TV, getting a darker picture means it is time to change the bulb.
Feb 16, 2015 | Samsung Televison & Video
How can you make your nose look smaller with make-up?
Use concealer on the bridge of your nose and use a power on top... I saw it on Oprah.
Use an eye shadow that is a little darker than your skin, and put it on the sides of your nose to make it look thinner. An eyeshadow with a slight green tint will help minimize the appearance of depth around the edges, thus creating a smaller appearing nose.
Buy a thing of powder that's two or three shades darker than the powder you put on the rest of your face, and brush it on the sides of your nose.
I used to do make-up and costume design for theater. The advice above is spot-on: you want a color a few shades darker on either side of your nose. To make your nose look even thinner, use a color a few shades lighter than your skin right along the top of your nose, down to the "ball" --the part that sticks out the most. If you're trying to create a curve to your nose, ie, make the bridge seem like it sticks out less, use the same color that you used on the sides and blend it--gently!--over the bridge, then apply the highlight color just to the ball and blend thoroughly. Less is more here: in Theater, we heap the makeup on so that the audience can see it under the bright lights. In the real world, you want to go very easy on it. If you use too much, or too dark a color, your nose will just look dirty.
Make sure the foundation and concealer you use is matt making your nose appear less shiny and less attention will be drawn to it, also make your eyes, cheeks stand out that way the attention will be drawn to your nose. I have a fairly large nose and just for the past year what I've been doing is taking blush, and rub it gently up and down the nose. but don't touch the sides at all, this will make your nose appear thinner and more narrow than big.
Added an illustrating related link. It's easier to understand by seeing a picture or video.
Another way is to draw attention away from your nose, all you need to do is to apply more make up to your eyes.
Nov 22, 2010 | Health & Beauty
TV picture is unstable until the TV warms up. This is taking longer and longer. Picture gets large, small, large, small... Quality is also lacking until it is warmed up. This is a Phillips 60'' Is this...
What model and brand is your television?
Is it a CRT type or DLP?
If picture is getting smaller then larger, and its a crt rear projection television sound like you have bad connections around the Flyback transformer and or horizontal circuits. This usually happens when a connection is made on the circuit board and the picture returns to normal especially during a cold start, but as the television warms up the connections on the board start to seperate and the problem starts occuring or it could be in the reverse process. Unstable at first then when tv gets warm it make better connections. All in all have a technician check the HV section of your deflection board.
Sep 29, 2009 | Televison & Video
I have a pioneer elite pro 100 projection tv. the picture seems to be getting darker and darker. and the color seems to be fading as well what could be wrong? and i havent tried to turn up the brightness...
hi..first check it out the brightness.It is available in the
menu button,available on the top of the tv.If it still doesnt
work Projection TVs have a high intensity lamp as the light
source. They wear out and gradually get dim.You probably
need to replace it.
check it out..
thank u..
rate my response..
May 05, 2009 | Pioneer PRO-100 TV
Color fading in picture
you need to replace the coolant in thr CRTs( picture tubes) Vert common problem in phillips. You can get the enitre repair kit at the following link which has the coolant and instruction CD for phillips coolanrt change. Heres the link its under the repair kit section.
http://servicemanuals.vstore.ca/
Jul 21, 2008 | Philips Magnavox 9P6034C 60" Rear...
IS THIS TV PLAYING OUT
Color separation is called convergence mis-alignment......that
problem can be repaired...............Blurry,darker when cold may
be a bit of difficulty..............Have a skilled tech give it a look.....T.
Nov 15, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Strange Image Flubbering/Convergence Problem, Flutters From Dark Picture To Light Picture.
you "tooled around with the convergence board" well this chassis has several problems if the convergence doesnt hold replace both stks resolder around that area per tosh tech bulletin the bright problem is probably the hyper module all toshs should be checked with toshiba website to see if they were part of the recalls for power supply caps
Nov 30, 2006 | Hitachi 50UX57B 50" Rear Projection...
Mitsubishi VS-55707 TV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
