Question about Intel Server Board SE7501BR2 Motherboard
Intel se7501br2 board error:0111a:drive error
New Intel board, new 2 160gb hard drives, 2 2.4ghz, 1gb RAM.
Checked the drives in other computer worked fine, checked cd drive, floppy , etc. Just what does that error code mean? That is : Error:0111a:drive error.
Good workable answer much appreciated,
Thanks
Carl
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    Hi Carl, go into your BIOS and see if it is showing a floppy drive, if it is change it to none or disabled and save changes, reboot and see if the messages goes away.
    Genius:
  • 1,148 Answers
TRY ANOTHER RAM CARD OR TRY OTHER SOCKET
Posted on May 15, 2009
Dell xps 710 motherboard replaced with 700 motherboard but it does not boot
This could be any number of problems. First start with hardware. Is everything seated and connected correctly? Are the hard drives installed correctly. Are the power on pins on the board set correctly or pinned at all? Is the ram the correct ram?
Check the hard drives, are they functional, do they boot with other computers?
Use a volt meter and check that the power supply is producing the correct voltages on all the connectors and rails.
If that all checks out, it might be a bios error. Check your boot load order and if the motherboard is detecting the hard drives, check that the correct bios settings for OS management are in place as this is a server. Is the RAM power settings (voltage) and speed correctly selected? Will the computer boot from optical drive using a live CD? Will it boot from a USB live OS (like Ubuntu)?
Since it's not booting, you may not have compatible hardware or damaged hardware. The OS that's installed on the hard drives may not be able to load on the new (older model) motherboard due to driver incompatibility.
Oct 13, 2013 | Intel Server Board SE7501BR2 Motherboard
Does my intel se7501br2 support serial ata
NO, this board has no SATA ports for SATA drives.
This board is very, very, outdated.
Intel has ended it's support for this board.
Apr 12, 2013 | Intel /SE7501BR2/DUAL P4 XEON/V/1GB/...
Intel SE7501BR2 cant get it to boot any os except ubuntu, curious that it boots and installs ubuntu have the drivers disk for the board but it wont boot tring to install winxp also it keeps giving me...
press delete during boot up process enter BIOS then f1 for general help then run chkdsk/f which will automatically fix any corrupt files on your hard drive
hope this helps good luck
Sep 04, 2010 | Intel Server Board SE7501BR2 Motherboard
I just got a Intel D875PBZ Motherboard from ebay, im told its suposta work fine, i hook the entire thing up to my system, and it boots, all the fans start, my hard drive starts, i can open/close my disk...
You could try reseting it. unhook the cmos battery and put it back. also make sure that MB sits well in the casing without any shorting (grounding that is not supposed to).
Regards
Aug 13, 2010 | Intel D875PBZ Motherboard
Error loading operating system
You will need to perform a repair install using a Windows CD. The current configuration on the hard drive was basically with an entirely different computer and thus, it does not know how to "talk" to the new hardware. The repair install should fix that and create a new Hardware Abstraction Layer (HAL) that will enable Windows to "talk" to the new hardware.
Mar 18, 2010 | Famous Brand Dell Optiplex GX280 Intel...
500gb hard disk supported by intel D101GGC
Hey ROY_GV,
This D101GGC Motherboard supports both IDE and SATA.
Regards,
InfDev
Mar 05, 2010 | Intel D101GGC Motherboard
Unable to install software win 2003 server on SE7501BR2 as it didnt detect bootable 2003 cd showing error unable to detect hard drive as we have 2 * 73 scsi pls suggest can it be possible to install redhat...
Okay, has the SCSI system been setup properly? you must adjust some hardware settings to tell the computer what device is the end of the string, and if it is not configured correctly, you won't be able to use some or all of the SCSI hardware. I would check all hardware settings and BIOS settings before attempting that again.
**WARNING** Do NOT open your computer unless you are properly grounded to your computer via ESD Bracelet. any static that is discharged (Usually you don't even see or feel) can damage computer components. Please use extreme caution when working inside a computer.
Ryan Frame
Creative Energy Associates Technical Center
Sep 03, 2009 | Intel Server Board SE7501BR2 Motherboard
Server board SE7591
have memory and hard drive with an op sys
Jul 31, 2009 | Intel Server Board SE7501BR2 Motherboard
New motherboard will not boot from cd.
Nope, just goto bios menu and look for line First Boot Device then select CDROM, or scroll to have CDROm in the selected first boot device.
May 07, 2009 | Intel Server Board SE7501BR2 Motherboard
2.4ghz, 128ram, P4, 40GB HD.need to upgrade the system.
According to intel:
1.6 System Memory
The Desktop Boards provide the following memory features:
• Two DIMM sockets supporting one of the following10:
 2.5 V (only) 184-pin 200/266 MHz Double Data Rate (DDR) SDRAM DIMMs with goldplated
contacts, or
 3.3 V (only) 168-pin 133 MHz Single Data Rate (SDR) SDRAM DIMMs with gold-plated
contacts
• Unbuffered non-ECC DIMMs only
• Maximum total system memory: 2 GB; minimum total system memory: 64 MB
• Serial Presence Detect (SPD) DIMMs only
• Suspend to RAM
And yes, you can increase the hard disk.
Jan 12, 2009 | Intel D845GBV (BOXD845GBVL) Motherboard
Intel Server Board SE7501BR2 Motherboard Logo
373 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
