LG WM2050CW 40 cu. ft. Washer Logo
Cossette Beltran Posted on Dec 17, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Water is coming out from the bottom - LG WM2050CW 40 cu. ft. Washer
Tedowen
Level 2:
Prodigy:
An expert who has answered 500 questions.
  • LG Expert 536 Answers
  • Posted on Mar 28, 2014
Tedowen
LG Expert
Level 2:
Prodigy:
Answers
536
Questions
0
Helped
264815
Points
943
Water leaking out from the machine can be caused by a number of problems:
Check the drain pump hoses for condition and security, check the tub seals and also door seal.
  • Tedowen Mar 28, 2014
    Check also the condition of the pump housing for cracks
Kenmore refrigerator water leak from bottom right while using water dispenser
no info generic answer leak in dispenser valve or line need to access the dispenser unit most models need to remove inside panel
1helpful
Leaking water on floor appears to be coming out of fridge at bottom inside. after removing vegi crisper cannnot see whereits coming from suggestions please
does it have a water line, if so make sure that is not leaking. check bottom of freezer to make no standing ice or water is on the bottom.
1helpful
Water is coming out of the bottom of my Quick and hot instant hot water heater, whats wrong
Water coming out the bottom is usually an indication that the tank has failed.
Have a new electric tank,top element wont come on,replaced thermostat 3 times top element comes on once but next morning not enough hot water&top element wont come on,can someone help? thanks
The top element only comes on when the heater is about out of water. The water is directed to the bottom of the tank. Cold water stays on bottom, Bottom heater element heats water. If you use all that water then the top of the tank gets cold and the top element comes. When the top of the tank is warm, then the bottom element comes on. I would susupect the bottom element as it does most of the work. If you have an ohm meter, turn off electric, and remove wires from element. Check element for continuity. If you don't get reading, then that element is bad.
2helpful
I don't know how to open the shower. It only works the water below
Hello. At the bottom (spout) where the water comes out it have a pull button. Just pull it up and water should comes out trough the shower head. If water comes out without pressure and is partially comes from the bottom just replace the spout. (bottom part)
4helpful
Keurig b40
We need to determine where the leak is...
Unplug it...
Start by removing the water resevoir...dry out what you can with paper towel...
flip it over on a table with a bath towel. Take off the metal bottom plate
you can then check for water inside the unit.
since you didnt say where the water is coming from... the K-Cup arm or the bottom...
I will assume the bottom is where the water is coming from.
Hoses on these units are fastened with 4 inch "Ty-Wrap" nylon fasteners.
You may have a broken one, and need to replace one... hopefully it is located on the bottom between the water fill and the main water motor... which you shouold be able to see when the bottom metal pan is removed...
If the water is coming out from the top. then I suspect hot water expansion is bypassing one of the valves, or there is a nylon strap/hose combination you cannot see instde the unit...
Hopefully it';s the bottom
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/lisa_52daba487e5b4d53
2helpful
Water on the bottom inside the Freezer
the water usually comes from the evaporator defrosting and the drain being plugged with ice or frozen water. try a hair dryer and defrost the frozen water and clean the drain plug and hose
1helpful
How to flush the anti-freeze in1997 gran marquis
remove bottom and top caps from radiator, turn car on, place water hose in radiator, turn water on slow, let run for a while, making sure water is constantly coming out of the bottom of the radiator. keep an eye on hose to ensure water is not coming out too fast and that the hose does not come out of the radiator. watch color of water at the bottom, wait till it is totally clear before taking the hose out and shutting off the car. make sure you turn car off the allow all the water to come out. replace bottom cap, then fill with 50/50 fluid to proper level and fill side container to proper level as well
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
