Question about RCA HD50LPW175 50" HDTV
RCA HD50LPW175 DM3x help??
Do you know much about the DM3x module on the HD50LPW175? I fixed 3 of the ACIN power boards with the capacitor fix, and tested them all with a known good DM3x - every one of them worked perfect! But in testing the good power boards with 2 other of my 3 DM3x boards, they are **** in what I think is the "boot-up" sequence. When plugged in, the front LED comes on, blinks 5 times, then just stays lit like it's stuck - the only way to power the TV off is to unplug it. I thought I've read of a DM3x fix before, but I'm not sure. Anything I could replace in there? Thanks a bunch for your help.
  • 3 more comments
  • Ben_Eve May 15, 2009
    Thank you for the reply. Where exactly located is the shunt diode? Or what number is it?
    The DM3x module doesn't have a chopper output does it? All my voltages on my power supplies are good and are working perfectly. I tested all 3 with the one good DM3x module that I have - and all 3 power supplies powered my HD50LPW175 right up. It's just when I test them with 2 other DM3x modules I have, the TV appears to be stuck in a boot-up, front LED is on but unresponsive - no fans are spinning. Could this be a firmware issue possibly?
    Does this particular set have a horizontal deflection board? It is a DLP, not a CRT. Forgive me...I know a little, but I'm learning, so I greatly appreciate you help.
    Standby power I have: +15v, and -25 from the AC IN. And then to the DM3x module I have +12v, +6v, +33v, +5v, and -5. Then I have +320v going to the ballast.
    There is one wire going to the bulb housing, then another coming into it from the light engine. I can't get in there to read the voltages for the wire coming in from the light engine, but I'm sure they are correct since the TV comes on without a problem when I have the good DM3x module in there.
Slinteriors
  • 8617 Answers
SOURCE: ATC336 Power Supply Issue?
You can get the capacitors at the following link just leave them a email indicating that you need the capacitors for the ATC336 power supply and they will get back to you quickly, they have the high temp capacitors in stock.
Here is the link
http://servicemanuals.vstore.ca/
Posted on Jul 10, 2008
Slinteriors
  • 8617 Answers
SOURCE: RCA Scenium HDLP50W151YX1
you can get the ATC336 DLP Power board repair kit, that often repairs the 5 blink error code. The kit conbtains the replacement capacitors and the info on which board and capacitors that need replacement and also includes the service manual for the TV on CD. You can get the repair kit at the following link its under the repair kit category
Posted on Sep 27, 2008
SOURCE: replaced lamp. 5 blinks, does not start
the solution is if it gets repaired 3 times, and lamp assembly replacements dont count, i repeat 3 times, best buy will replace it, as they are going to have 2 mine. these rca sceniums are a black hole for money. i have had capacitors replaced, speakers, the lamp twice, what i call the motherboard( the place where you plug in other devices to the tv. and now i still have problem of tv, at times pixelating(this could be caused by cable signal however), and i get a blank screen when i try to turn on. sometimes i have to attempt this 3 times prior to the tv starting. i have a service tech coming wednesday. good thing i bought the 4 yr warranty as all this in on best buy, and now they will have to provide a new television under their lemon laws. service tech just coming to confirm need to repair. THE REVIEWS for this rca are horrendous, like 1 star out of 5. final note : i bought this in june of 2006. solution is if you do not have warranty - QUIT PUTTING MONEY INTO A BLACK HOLE. i bought a 42 in samsung at the same time i did this one and it has never had a problem. so now i will replace this with a samsung dlp, plasma, or lcd - what ever options best buy gives me.
Posted on Mar 08, 2009
  • 147 Answers
SOURCE: bad capacitors? ladywinn
If you take the back off the deflection board is the one on the left. You must remove the board and near the front you will see a capacitor with a puffy top. Replace this one and the three closest capacitors around it. Not easily done unless you have some experience.
Posted on Apr 09, 2009
SOURCE: RCA D52W19B light on power
where do ypu get the cp150 at thanks
Posted on May 16, 2009
RCA 52 in D52W20 that has no power, I have 1 blink followed by 9
Check these 3 capacitors on your Deflection board. its bottom board left hand side / cp150 2200uf16v and cp114 cp120 220uf 35v if any of them are swollen,vented or puffed up on top replace all 3 capacitors.
Mar 23, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
5 Times it is a problem with the lamp.
Either the lamp is gone, or the small pwer board powering the lamp is defective.
Sep 26, 2008 | RCA HD50LPW175 50" HDTV
Tip
Power supply repair for ATC 336 chassis HD50LPW175
I have seen quite a few of the ATC336 have dead capacitors in the power supply preventing start up . The capacitors in question are CP647, CP624, CP639 and CP641 all were bad. Replaced these capacitors and the sets powerd up and operated
on Feb 23, 2008 | RCA HD50LPW175 50" HDTV
RCA HD50LPW175 50 in. HDTV Television Problem
If it's agreen wire with a stripe (usually yellow) it is likely a chassis ground (ie center plug of 3 prong electrical cord). The best source for schematics I've found (although they cost) is servivcemanuals.net.
Hope this helps.
Dec 02, 2009 | RCA HD50LPW175 50" HDTV
I have a 50 inch RCA Real Projection TV (DLP or HDTV). I just replaced the lamp and everything worked fine. One night it made a big sound and shut off. Now when you turn it on, nothing appears, a few...
you could have a color wheel problem or a power supply problem
one questions did you reinstal the door at the rear
you might want to remove the lamp module and try a reinstal and see if condition changes
as to costs if you can get the color wheel 150.00 or so
there ae several things that could cause this a dmd module a color wheel and power supply or digital board the lamp cover when installed it closes a saftey switch there thats why i ask if you has installed door
Oct 22, 2009 | RCA HD50LPW175 50" HDTV
Hd dlp rca scenuim
the 5 blink error is caused by faulty capacitors on the power board. There is a kit called the ATC336 power supply repair kit which contains the replacement capacitors and instructions that will usually repair that. You can get the repair kit at the following link.
Sep 27, 2008 | RCA HD50LPW175 50" HDTV
ATC336 Power Supply
Yes the symptoms of bad capacitors on the Power supply can mimic the symptoms of a failed DM3. Its alot better to try the capacitor change first, as they are a common source of failure and the price of the DM3 is very exspensive.
Jul 10, 2008 | RCA HD50LPW175 50" HDTV
Here is the link
Hplpw175x7
Thats a good price as long as they guarantee that it works. How were you able to pull a capacitor off without un-soldering it?
May 30, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
Rca hd50lpw175
I'm sure you've found out by now that your bulb was going bad...
Jul 28, 2007 | RCA HD50LPW175 50" HDTV
RCA HD50LPW175 50" HDTV Logo
338 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
