Question about Aiwa XC-RW700 2-Disc CD Recorder
Problem copying from cassettes or vinyl.
My aiwa xc-rw700 compact disc recorder is 8 yrs. old. recently, when i try to copy music from vinvl or cassette, i get a hiss in the right side channel.
    Genius:
  • 1,148 Answers
CHANGE RCA JACKS ,,COULD BE A BAD ONE,, ALSO ,,TRY BLOWING IT OUT
Posted on May 15, 2009
I got a cassette tape stuck in my Aiwa compact disc stereo system and broke the door on one side getting the cassette out. There seems to be a piece broken on one side. Door will not stay closed. I
Google AIWA service centers or go to the AIWA website for help through Customer Service. Good luck!
PS Best Buy Geek Squad may offer repair options.
Jan 14, 2018 | Audio Players & Recorders
My aiwa dual deck player recorder keeps shutting off when playing I don't know the problem
Is it happening to both decks? Generally, it's usually the "take-up" drive belt. They all tend to stretch and dry out over time, so a complete belt renewal could restore proper function.
Jul 03, 2014 | Aiwa XC-RW700 2-Disc CD Recorder
What is original remote control model number
The model # for the original remote is.
XCRW700
Sep 12, 2011 | Aiwa XC-RW700 2-Disc CD Recorder
I cannot finalize my CD's on my Aiwa XC-RW700 Dual CD recorder might you know the problem? when I push the finalization button in blinks for a few seconds like it's going to finalize but...
On page 18 of >>>> the manual <<<< it says to press the " > " key within 3 seconds after "Finalize". You wouldn't want a careless button push to just run off and close out the disc, would you?
Aug 03, 2011 | Aiwa XC-RW700 2-Disc CD Recorder
Aiwa Dual CD Burner, cd's skip and sound scratchy
memorex and kyphermedia WON'T work in this recorder FYI Don't know what brand will
Jan 19, 2011 | Aiwa XC-RW700 2-Disc CD Recorder
Why doesn't unit power up when power button is pushed? Checked outlet and is plugged in.
Take the cover off the unit to look at the fuse...it looks like a little glass tube and will be near the power cord input....you should see a little wire element inside that must be all the way across the tube, otherwise it is bad and will need to be replaced....these fuses are available from places like Radio Shack....If the fuse is good then there is probably a problem in the power supply circuit that will need to be troubleshooted by a service tech
Jan 16, 2011 | Aiwa XC-RW700 2-Disc CD Recorder
THIS IS AN OLD UNIT. SUDDENLY THOUGH IT HAS STOPPED RECORDING.THE MANUAL HAS A NOTE IN IT ABOUT THE OPC LIMIT.1st QUESTION IS WHICH SIDE OF THE RECORDER IS IT TALKING ABOUT BECAUSE IT HAS RECORDED OVER...
Are you actually getting a message regarding OPC?
I'm not sure we can determine which CD drive is exhibiting the problem from what is given, if that's what your Question #1 is about.
Answer #2: If the problem appears at initial calibration of the new disc, try a different (or cleaner) disc. BTW: did you start using a different brand or type of disc in the middle of this?
These links lead to some technical info about what OPC is.
http://www.cdrfaq.org/faq05.html#S5-11
http://www.osta.org/specs/pdf/opc.pdf
Running Optimum Power Control (Running OPC)
A technique used by recorders for monitoring and maintaining the accuracy of all the
mark and land lengths across a CD-R disc.
The CD Recorder does some sample write testing at the beginning of a disc to get a bead on how much laser power it needs to use to make reliable 'ones and nones" on the media. It records the settings in memory. Throughout the recording it monitors surface relectivity and compares it against the test data and in many cases can compensate on the fly for changes.
My read on this is that it may be trying to tell you on any given recording that it has reached or surpassed its effectiveness limit.
Jan 20, 2010 | Aiwa XC-RW700 2-Disc CD Recorder
Only records Lps and CDs, but not other cassettes
there are programs on the net that will copy from tape to cd via the computer if you have a cd writer on the pc hope this helps regards Jim
May 02, 2009 | Audio Players & Recorders
Power
Check the internal fuse.
Oct 21, 2007 | Aiwa XC-RW700 2-Disc CD Recorder
Aiwa XC-RW700 2-Disc CD Recorder Logo
142 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
