Question about Motorola Mobility E815
Phone will not power up
My Motorola E815 got a very slight amount of moisture on the outside face of the phone and then stopped working. We blew it out and let it sit in the sun. There was no trace of mositure in the battery compartment and no trace of any moisture anywhere now, we tried a different good battery and still nothing. We were at least hoping to power up the phone to get pictures off of it, any suggestions?
Thanks,
Dale
  • 416 Answers
Better get that warranty card if you have it. or repair / service shop is the next stop. sorry.
Posted on May 15, 2009
Keypad not fully working on a Motorola E815. The 5,7, 9 and send buttons do not work when pressed. All other features work and I can make calls by using voice command, so phone works otherwise, just not...
Hi. If you re attached to the phone you can purchase a new keypad. Otherwise you need a new phone.
The inner keypads of cell phones can become corroded after extensive use. Also as a result of being kept in a hot area.
Thank ou for using Fixya.
May 30, 2011 | Motorola Mobility E815
Why does my Motorola E815 VCAST state in the Window "No Service?
First, Are you in an area that could possibly not be getting good reception? i.e. basement, thick walled room or is the weather outside stormy?
If you are in an area that might not be getting adequate signal I would suggest going to a window or possibly another room in the house.
If it is stormy outside the cell tower in your area could possibly have been damaged or just too much electrical interference from storm to allow phone enough phone signal to your Motorola E815
Also, make sure your cell phone plan is up to date and paid, your service provider may have canceled your phone or temporarily shut off your service.
Feb 28, 2011 | Motorola Mobility E815
I just bought a motorola E815 cell phone and it will not charge
Remove battery, clean contacts between battery and phone, also be sure to use an original Motorola charger instead of one of those "universal" type chargers.Hope this helps!
May 08, 2010 | Motorola Mobility E815
My E815 'end call' key wont work. cant turn my phone back on.
the phone uses a complete keypad for all the buttons you may need to replace tne whole keypad flex assembly. if you can take apart the phone you can purchase the flex on ebay. if not contact your local cell phone tech or you con contact www.fixphonenow.com for a repair estimate.
Nov 08, 2008 | Motorola Mobility E815
Motorola E815 phone number reset
J'AI UN MOTOROLA E815 ET J'AI OUBLIé MON LOCK CODE C'ETAIT PAS AVEC LES 4 DERNIERS CHIFFRE....AIDE MOI A RESET MON PORTABLE
Aug 30, 2008 | Motorola Mobility E815
Motorola E815
Leave it on charger on a while. And then turn on.
If no luck try to open and clean it inside.
If than is not enough phone have not contact with power.
That is usually for old phones just don't turning on.
Jul 24, 2008 | Motorola Mobility E815
E815 Motorola dropped in water
You will need to revive yuor phone by taking out all moisture trapped in. First of all do not turn on the phone, next, in order to take out all moisture trapped in the phone: Dry the phone, battery, any accessory, etc. with cloth and wrap each piece, phone and accessories, in newspaper. Place a few handfuls of rice into a plastic bag and then place the wrapped phone in the bag with rice. The newspaper wrapping avoids direct contact of rice with your phone because the dust from the rice can get into the small areas of the phone. The newspaper and rice will absorb moisture. Leave it there (with the bag open) at least 24 hrs.
Jun 12, 2008 | Motorola Mobility E815
Motorola E815 alarm quit working
I've had a similar problem with alarms not going off.  In my case, it was caused by receiving a text message that was unanswered between the time that I set the alarm, and the time that it was supposed to go off.  Try reading all your text messages, deleting all messages, and then take the battery out and put it back in after a few minutes.  The last part is to reset any caching, but the first two steps followed by a turn off/turn on should also do the trick.
Oct 08, 2007 | Motorola Mobility E815
Motorola E815 cell phone
This exact issue happened to me: I left my phone off for 2 days (unplugged), turned it back on and the internal speaker started working normally again. The phone worked normally for over a month after this. Yesterday, the earpiece speaker stopped working again after the phone fell out of my pocket. I suspect a loose connection or something similar, but I've had my phone off for the last day and will let you know whether or not it starts working again.
Jun 11, 2007 | Motorola Mobility E815
Motorola Mobility E815 Logo
57 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
