Question about LG 37LG30 37 in. LCD HDTV
Tv says no signal after hooking up computer to it
Got a rgb cable to hook up to my tv and computer but tv keeps saying no signal what do i do
I had same problem, adjust settings on your computer desktop resolution to 800x600 solved my problem right away, computer resolution is probably too high. Hope this helps!
Posted on Jun 09, 2009
  • 3 Answers
Do you have it on the right input
Posted on May 15, 2009
Reset my Sanyo tv so that it recognizes the rgb input
RGB is for a computer, unless you had one hooked up it would say no input.
Oct 14, 2016 | Sanyo Televison & Video
I can't get a signal because this tv don't have cable antenna terminal the tv has rgb terminal. I don't know what to do?
RGB is for a computer screen display signal and has nothing to do with TV display of channels. You must have a Component hook up, it is a yellow cable, a red and a white one. Yellow is video signal, the red and white are sound.
Sep 12, 2016 | Panasonic TH-42PWD7UY 42 in. EDTV-Ready...
Monitor is saying no rgb signal its hooked up to tv
Depending on if you have a video card and not the onboard video see if you do and change the cable on the computer to the proper one sending out the signal.
Mar 14, 2014 | Compaq Presario Desktop / AMD Sempron...
Hooking up my Sony HD Tv
Couple of items come to mind.
In the menu of the receiver, is there a way to choose video and RGB?
Set the receiver to SAT
Connect the HD Cable Box to SAT
Check the TV is on Monitor RGB.
Check the input being used by the monitor RGB cables is selected on the TV.
Have a picture? NO, receiver has issues.
Yes? Do this with each input to confirm they work.
You can reset the whole receiver to factory by holding the tone button down and holding the standby button for three seconds. (This clears your speaker setups, too.)
Apr 02, 2010 | Televison & Video
TV will not stay on.
MIne did this at first. Unplug from source for 2-3 minutes, then try again to turn on. Should come up then.
Apr 03, 2009 | Vizio L6 20.1 in. HD-Ready LCD Television
No RGB imput signal
You need to change the input signal, get into the menu on your monitor and change the signal from rgb to dvi, hdmi or vga dipending on what cable you using for connection.
There is NO rgb connector on that monitor
Good luck
Dec 05, 2008 | Balance CM2015 15" LCD Monitor
Trying to use rgb input
Cable TV: Connect the LCD TV to the cable with CATV and Digital cable. Preset the cable TV channels into memory with Auto Scan function when using a cable TV system. Make sure you set the INPUT SOURCE properly (TV, VGA, S-Video, etc)
Mar 10, 2008 | ViewSonic VPW425 42 in. Plasma HDTV
LG 37LG30 37 in. LCD HDTV Logo
2,028 people viewed this question
Computer Repairing
Computer Repairing
