Question about ViewSonic VPW505 50 in. HD-Ready Plasma Television
Does Not Stay On
When turning on, it cuts off. Sometimes it turns on but freezes in the "wait mode" (hour glass displayed) or other modes (blank screen with input setting displayed) and will not shut off even when pressing the front panel power switch. At this point, the only way to shut it off is by then resetting the rear main power switch which puts the unit back on standby mode (yellow light in front panel). I continue trying to turn it on, (it could take a half an hour or longer) until it finally turns on. Once on, it stays on and works fine, unil it's shut off and have to start the process over.
Thanks for you advice.
  • John Guzman Oct 22, 2007
    I received my first solution from duffmckagan but it was mistakenly for someone's else different equipment and probelm. Thanks for your continued support.
  • 105 Answers
Sounds like your tv is locking up. check with the manufacture to see if there is a software upgrade for this issue. otherwise you will have to replace the signal board (board with inputs) and/or the logic board (located undrneath the signal board). basically there is an lvds cable between the two board. when there is too much info comunicatd between the two the tv will lock up
Posted on Oct 23, 2007
  • 51 Answers
When you insert the card and get the CHA Flashing error, remove the card and format it. Reinsert it again.
Should work.
Posted on Oct 20, 2007
  • Amit Joshi Oct 20, 2007
    Also, if it doesn't work, there is a strong possibility there's a broken or bent pin in the memory card section of your camera. Just look closely and inspect that section to see if there's a broken or a bent pin.
    This happens when you forcibly insert the card the wrong way. This has happened to a lot of users.
    Please ignore this solution.This solution is for another problem. There's no way to delete it myself. Sorry.
SOURCE:
How do I get out of silent mode on uniden dect 6.0
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D1760om.pdf
1. With the phone in standby, press and hold # on any handset. The phone prompts you to select the number of hours (1 - 9 or Always On) that you want it to stay in silent mode.
2. To confirm, press # or just wait about 5 seconds. The phone turns on the answering system and displays Silent Mode On on each handset.
3. After the selected number of hours, the phone automatically exits silent mode. To exit silent mode manually, press and hold # again.
Feb 18, 2015 | Uniden Cordless Phone
How do I turn off silent mode
Silent Mode
You can silence the ringers on all handsets for a specific period of time.English - 10
2. To confirm, press # or just wait about 5 seconds. The phone displays Silent
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D1660om.pdf
Sep 29, 2014 | Uniden DECT 6.0 Cordless Phone ID
Phone is on silent mode I dont know why or how to change please help
Hello there
You didn't give us the model number of your phone but go on the web and get the user manual for your phone.
From this ,manual http://www.manualslib.com/manual/184646/Uniden-Dect1560.html#product-1560-2%20-%20DECT%20Cordless%20Phone
I got.....
Silent Mode
You can silence the ringers on the base and all handsets for a specific
period of time; the answering system answers any incoming calls without playing anything through the speaker.
on any handset. The phone prompts you to select the number of hours ( 1 - 9 or Always On ) that you want it to stay in silent mode.
If the phone is in silent mode and you turn off the answering
system, the phone exits silent mode.
Sep 25, 2014 | Uniden Cordless Phone
520230. 31520193. 7Polaris 550 Xp eps 2009About 20 hours on unitStored indoorsI understand one code is Idle air and the other is power steering is disabled or not functioning. First I would try and...
Diagnostic Mode
The diagnostic mode is for informational purposes only. Please return your ATV to your dealer for all major repairs.
As long as the gauge is in the diagnostic mode, the wrench icon will remain lit.
To leave the diagnostic mode, turn the key switch off and on.
NOTE: Any movement of the tires will also take the machine out ofthe diagnostic mode.
To enter the diagnostics mode:
1. Turn the key switch off and wait 10 seconds.
2. Set the park brake and shift the transmission to neutral.
3. Hold the mode/reverse override button and turn the key switch on.
4. Release the switch as soon as the display is activated.
The initial screen display refers to the software version installed in
your ATV. This information is displayed briefly.
Use the mode/reverse override button to toggle through the diagnostic
screens.
Screen 1: Battery voltage
Screen 2: Tachometer
Screen 3: AWD diagnostic
This gauge indicates whether or not current is flowing through the
AWD coil (only on models with switchable AWD).
Screen 4: Gear circuit diagnostic
This screen displays the resistance value (in ohms) being read at thegear switch input of the gauge.
46 FEATURES
Instrument Cluster
Rider Information Center
Diagnostic Mode
Screen 5: Programmable service interval
The purpose of the programmable service interval is to provide the consumer and dealer with a convenient reminder for routine maintenance. When your vehicle leaves the factory, this feature is set at 50 hours. You must enable the programmable service interval before it
can be used.
Once the service interval mode is set with the hours when service is due, the hours of actual engine operation are subtracted from the set
hours until 0 is reached. When the counter reaches 0, the wrench icon will flash quickly for 5 seconds each time the vehicle is started as a reminder that the periodic maintenance is due.
To set the hours, press and hold the mode/override button until the wrench icon flashes. When it begins to flash, release the button. The setting will increase by one hour each time the button is pressed.
Pressing and holding the button will allow the numbers to escalate much faster. When the desired time increment is displayed, release the button and wait for the wrench to stop flashing. When the wrench stops blinking, your service hours are set.
NOTE: If you scroll past the intended number, hold the button down until the count turns over to 0. You can then reset the number.
If the service interval is enabled on your ATV and you wish to turn it off, toggle to the service interval mode. Press and hold the mode button for approximately 7 seconds until the word OFF appears in the
Rider Information Center.
Jun 28, 2013 | Polaris 2009 Sportsman 550 EFI XP With EPS
Mp730 says waste ink near full
To reset waste tank full error in MP730.
1. Press the "menu": Key
2. Press "Copy" Key
3. Press "#" Key
4. Scroll thru the menu headings until you come to "Test Mode" - 12th heading or select (-) as a short-
cut to the last setting.
4a. Press "Set" and the display shows:
Test Mode [1] - [8]
CF-FH3 :WLD-11-02
4b. Press "8" and the display changes to:
Test Mode [1] - [8]
Please wait
***note*** you have to wait until the display changes
Then the display changes to:
8: PRINTER TEST
[2]---[8]
5. Then Press the "3" button and the display shows:
8 - 3 : EEPROM Clear
*** the display scrolls to [0] : INK COUNT
[1] : 2PURGE FLAG
6. Press "0" button - for INK COUNT
7. Press the "Stop" button
8. Press Off then On to set new changes.
9. Printer feeds a blank page after it is turned on again.
This should Reset the printer and remove the WRONG CARTRIDGE error and save you a few dollars.
Aug 03, 2011 | Canon MultiPASS MP730 All-In-One InkJet...
My kids put the phone on the silent mode and i don't know how to change it back. the phone is Uniden 6.0
Jun 20, 2011 | Uniden DECT 6.0 Cordless Phone ID
My computer start up but turn to blank check monitor work fine?please help
Start in safe mode. Turn it on and hit F8 repeatedly until it beeps. Wait and then select safe mode. Sig in as yourself and then check power settings and display settings. Go to control panel to check both.
Jun 11, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
Mp3 nextar
Take battery out, wait 15 minutes, put battery back in, turn on power
Jul 28, 2008 | Nextar MA933A MP3 Player
Displays test mode
To exit test mode, turn off phone.
Press *3001#12345#. Scroll up 1 to FIELD TEST (some phones may say NET MONITOR instead of FIELD TEST) and SELECT. Scroll to ENABLED and press OK. Turn phone off and then back on. Signal strength is the upper or lower left number. After test mode is enabled it will stay in your regular menu. To easily get in or out, press MENU, up 1 FIELD TEST and SELECT or OK. Dial 00 to get out and 01 to get back in.
Jul 03, 2008 | Cell Phones
GE monogram ZET3038 locked on Sabbath mode
How to Exit the Sabbath Feature
Touch the Clear/Off pad.
If the oven is cooking, wait for a random
delay period of approximately 30
seconds to 1 minute, until only ⊃ is
in the display.
Press and hold both the Bake and Broil
Hi/Lo pads, at the same time, until the
display shows SF.
Tap the Delay Start pad until
12 shdn or no shdn appears in the
display. 12 shdn indicates that the oven
will automatically turn off after 12
hours. no shdn indicates that the oven
will not automatically turn off.
Touch the Start pad.
NOTE: If a power outage occurred while
the oven was in Sabbath, the oven will
automatically turn off and stay off even when
the power returns. The oven control must
be reset.
Dec 02, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
ViewSonic VPW505 50 in. HD-Ready Plasma Television Logo
180 people viewed this question
Top ViewSonic Televison & Video Experts
Jaime Hernandez
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
