Question about Sony STR-DE545 Receiver
No power When i press the power button all i get is a clicking sound,but no power.
Hey i had the same problem with mine. lol its so simple that when i figured it out i had to laugh. there is a 6.3 amp buss fuse inside.
just remove 6 screws take top cover off and replace the fuse next to the power cable!
Posted on Feb 03, 2008
    Problem Solver:
  • 5 Answers
Check the circuit boards for loose screws. The chassis is used as ground and a bad connection could be the cause.
Posted on Jan 30, 2008
When i press power button it just clicks and the does nothing what do i do about repairing
Perhaps you check out master 'power supply' and find bad 'capacitor' (usually). Click sound is because 'stand by power' is fine.
Apr 22, 2016 | Yamaha Rx-v465/rxv465 Home Theater...
All of a sudden our Bose player makes clicking noises when pressing the start button, and music does not play. What should I do?
My guess is the player is getting old and needs servicing. The clicking could be a bad laser or the power supply feed line that powers the laser/optical pickup assembly.
Oct 04, 2014 | Bose & Wave& Music System
My he2t kenmore front load washing machine won't power on and there's a clicking noise
Vicki, i think that clicking sound is ok when you press start. TRY THIS.
1. close door securely 2. press power after putting detergent.3 After making your selction for different levels eg hot,warm cold, press START.
usually these buttons are pretty reliable, GL
Jan 12, 2014 | Kenmore Front Load Washer
Turn on power, the lights come on but when you press start nothing happens just a click sound.
Click sound at power button and start button should get it going. If not then Dryer drum is not turning.
Aug 08, 2013 | Whirlpool Cabrio WED5550XW 27" Front-Load...
What causes red led on starting?
Remove Power Cord then press and hold the power button for 30 seconds, then put the cord back in and try to start it.
When you press the Power Button are you hearing the fans run, the disk drive running, the cd drive click and the light on it comes on for a second or two?
Anything shows up on the LCD Screen?
If you press the power button and absolutely nothing is happening then you most likely have a bad power supply.
If you press the power button and you start hearing beep sounds or blinking lights in a continuous pattern (ex. 1 long followed by 2 short) then you have a motherboard issue. Those beep sounds and blinking lights tells the technician what is going on with the computer.
Mar 23, 2012 | Dell Dimension 4600 PC Desktop
S9000 will only print black if set on "high" print quality, then looks more grey than black
Hi
Thanks for using FixYa. First of all please try to reset the printer by following the steps---
Turn the power off. Now hold down Resume button and press Power button. Keep holding down Power button and let the Resume button go. Press Resume button twice and then let both buttons go. Green light will flash then stop blinking. When Green light is solid, press Resume button 4 times. Now press the power button and the printer should turn off. If not, press the Power button once more.
If still the issue is not resolved, then please follow the procedure to uncheck the grayscale printing---
On the Windows desktop, click 'Start' then click 'Settings', then click 'Printers' (Windows XP: On the Start menu, click 'Printers and Faxes').
For Windows Vista: Click/Select 'Start' from the bottom left of the Windows screen, 'Control Panel', 'Hardware and Sound', and then Click on 'Printers'.
Note: If you are in 'Classic' view, Click 'Printers' directly from the 'Control Panel'.
For Windows 2000/XP/Vista: Right-click the printer icon, then click 'Printing Preferences'.
For Windows 98/Me: Right-click the printer icon, then click 'Properties' and then on the Main tab, click on the 'Grayscale Printing' check-box to remove the check-mark. Click the 'OK' button to save the settings.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 29, 2010 | Canon Office Equipment & Supplies
My TV does not power up when the power button is pressed.
It's sounds like your lamp or backlight has went out, I suggest reading your manual for service info and look online for a local repair shop.
May 16, 2009 | Televison & Video
Green power light on but no sound or picture.
When I press the power button it just clicks.... what. ... vs-60603 I will only stay on for a few seconds and then shuts off. ...
Mar 30, 2009 | Mitsubishi VS-45502 45" TV
HELLLLPPPPP
First Remove the UMD from PSP if any
1. Switch ON the PSP 2. Press and Hold the Left arrow button until the Sound of "click" Stops. 3. Press and Hold the Up arrow button until the Sound of "click" stops. 4. Press the Down arrow button 4 times (so u will be in System Settings) 5. Press the Enter Button i.e X 6. Press the down arrow button 9 times so u will in "Restore Default Settings" 7. Press Enter button i.e X once 8. Press the Left arrow button once and then press X button once 9. Press the Left arrow button once and the press X button again 10. Press the X button
See whether u r PSP restart and solves the problem
Oct 19, 2008 | Sony PlayStation Portable (PSP) Console
Power button makes a click, click sound
The sound is coming from a failed flyback auto transformer. You will need to replace that.
Jun 14, 2008 | GE 25GT507 25" TV
Sony STR-DE545 Receiver Logo
69 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
