Dear Byteguy Thanks for getting back to me about my wireless connection problem. To clarify, my Brother-in-law had the keyboard disabled by an expert due to a problem, so am unable to use the "Fn" and "F1" keys to activate the wireless switch. I am a novice at this comuputer stuff so cannot reactivate the keyboard myself. I have searched for a physical button and there is none. Does the Belkin keyboard I have connected to the Notebook have an equivalent key command to activate the wireless connection?
    President:
  • 814 Answers
If the keyboard had a problem you may not want to reactivate it. You should be able to find a solution in the keyboards owners manual or on the Belkin website. using the model number you may find they have a copy of the manual on the website. You should also check the frequently asked questions and troubleshooting sections to see if someone else has had this problem or a similar one and has gotten the answer. If all this fails you are going to have to call Belkins technical assistant and give them a clear description of the problem you are having with the keyboard. Also tell the about the situation that caused the original user to stop the use of the keyboard in the first place. Hope this helps you with your problem.
Posted on May 15, 2009
I can't turn on my wireless LAN. There is a button at the top of the keyboard of my Acer Aspire 4520 but when I press it, it says "wireless LAN disabled". I have tried everything to turn it...
hi, plz type " ncpa.cpl " in run command, it'll shows the network connections. if the wireless (WI-FI) driver is updated, it'll shows in that screen. just move the cursor to wi-fi connection and right click it. it might have been disabled. if it is disabled plz enable it and switch it on ur WI-FI switch...
thanks & regards Anas K A
Jun 01, 2011 | Acer Aspire 4520-5582 Notebook
How to hook up mouse and keyboard to hard drive
Please clarify your question. Are you trying to hook this up to your computer? If so, you only need to connect the transmitter to the USB/Serial ports
Jan 24, 2011 | Logitech Wireless Access Duo Optical...
I have my in-laws Toshiba M105-S1021 that sees the wireless devices, says it connected to wireless device but can not ping or get any internet pages to come up. The ip address assigned is from windows. ...
There should be a switch on the keyboard to enable the wireless i think it is F4 it should have a big "i" icon on it, if it is not there check the other F-keys, or the front under the touchpad area or on the sides you should find a switch somwhere. post back and tell me if you find one .thanks
Oct 27, 2010 | Toshiba Satellite M105-S1021 Notebook
I have a Medion notebook S5612 I cannot turn the wireless on. My brother in law has the same model and has no problem he just uses the Fn and F8 keys. Is there a fix or should I take it back.
I would check and see if the wireless adapter is seen in the device manager 1st - do this Press the Windows key (bottom left of the keyboard} and at the same time press the R key, now in the search box that appears - type devmgmt.msc Then look at the network adapters - click on the + sign - see if you have a wireless adapter maybe labelled 802.11 or say wireless - Nowhere in the device manager screen should you see any yellow ? or ! if you have then you could download the drivers again from the support site here - http://www.medion.co.uk/ click on "service and support" enter you model and serial number should get all the drivers OTHERWISE if still under warranty - take it back / and or call support
Apr 03, 2010 | Computers & Internet
Wireless connection is gone
under network properties enable the wireless network. Or toggle off and the back on. Some notebooks disable wireless when removed from wall
Jun 29, 2009 | Toshiba (PA3212U) Wireless Adapter
Wireless switch is amber
By default the wireless adapter is enabled on your HP PC. However there are many ways to disable your wireless adapter. It can happen by turning it off in windows or some application may disable it due to execution errors.
Most of the time, when a wireless adapter is disabled on a machine it is very often because someone has pressed the wirless button by mistake. If it has been pushed by mistake, turn the wireless back on by finding the wirless button on your machine and pressing it. Check for button location on the top of the keyboard or the side or front of the PC. Thanks
Jun 01, 2009 | HP Pavilion dv6000z PC Notebook
Wireless function combination
i have this laptop the wireless button is on the keyboard on the right hand side, it should be lit up blue if its on
Dec 15, 2008 | HP Pavilion dv1000 Notebook
My brother in law has just purchsed an Acer Aspire 5100 desktop. Coming with barely no instructions, we findly got the wireless keyboard and mouse connected, but haven't a clue as to how to connect to...
Hi there Loisy17a/Glen,
To setup a wireless network you will need a wireless router that can also use a standard phone line. (Dial-up).
http://www.wiflyer.com/TellMeMore.html
Help understanding wireless & how to setup. How to setup dial-up. There is no way to walk you through this but the manual that will come with the wireless router will have instructions & phone support to help. NetZero's support is less than Zero. They will blame your PC to your telephone line as a problem. (Good luck)!
http://compnetworking.about.com/cs/wirelessproducts/a/howtobuildwlan_4.htm
Mike
Apr 21, 2008 | Computers & Internet
Computers & Internet Logo
94 people viewed this question
David Payne
David Payne
