Question about Tomtom ONE GPS Receiver
Tom Tom One
No Audio except through headphone socket
Apparently its a dodgy earphone plug been told if you open the back and solder the terminals together youll have sound .although i would imagine the earphones would not work after doing this depends what you want
Posted on Oct 15, 2007
Unable to hear system through speakers,but ok through headphones
Make certain the connections to your speakers are good. Test each of your speakers with a 1.5 battery. Put the + and - ends of the battery to the + & - of the speaker (not connected to amp). Just for a short time only - the speaker should "pop".
If they are good you might have damaged the headphone socket on the machine. These disconnect the speakers when the headphone jack is inserted. Sometimes the contacts break or become bent out of place thus not reconnecting the speakers. This can be easily fixed and is not an expensive repair. The only exception would be if there is a switch to switch off the speakers on the unit itself. But if in the past you have put a headphone jack in the unit when the speakers were operating and they cut off then a faulty jack socket is to blame.
Feb 06, 2015 | Audio Players & Recorders
No audio in speakers only in headphones
If inserting headphones before the fault caused the speakers to switch off. Then you should look to the headphone socket as the cause of the problem. It could be that inside the contacts have become bent out of shape. You might need to replace the headphone socket. If you can use a soldering iron you can do this yourself. Otherwise it's not an expensive repair.
Apr 24, 2013 | Panasonic SC-AK24 CD Shelf System
No sound on my technika 42" 3dtv
If the headphone jack socket works the audio output for the set is good, I suspect a dvd etc will also work if connected to the rear input audio and video jacks.
This does not leave too much, headphone jack dirty or defective, speakers for whatever reason are switched to off in the main menu.
the sound for the headphone socket if it is built into the set is the same audio going to the speakers.
Dec 05, 2012 | Televison & Video
My headphones will work but my desktop speakers will not why?
If your speakers work fine when plugged into the headphones socket on the front of the system, then there is no fault with them.
If the sound through the speakers is very low when plugged into the rear panel socket, that would suggest that you may be plugged into the line out socket rather than the speaker socket and that there is a mismatch of the impedence between the socket and speakers.
If you have three audio sockets on the rear panel, try the speakers in the second output socket (but not in the microphone socket) and see if it makes a difference.
You could try the same test using the headphones - do you still get good sound levels with the headphones when plugged in to the rear panel socket?
If neither the speakers nor headphones give good sound when plugged in to the rear panel, then you may have a problem with either the sound card if the sockets are on a separate PCI card, or with a poor connection on the cable to the socket header bracket from the motherboard pins for audio for integrated adapters.
Dec 23, 2011 | HP Compaq dc5000 Microtower PC Desktop
Can i connect my ipod to my sony hcd-nez7 through the audio in socket on the back
Any audio device that has a headphone output can be adapted to feed an RCA cable pair for standard stereo to any audio device with a standard RCA input (except one labeled "PHONO"). Get a cable like the one described here:
and connect it into any available analog input on ANY audio device EXCEPT one labeled "Phono".
Aug 22, 2011 | Audio Players & Recorders
I tried to listen to a CD on my toshiba lap top with the headphones BUT inadvertently put the headphone plug in the microphone socket. When I took it out as the headphones did not work, a shrill noise...
first of all, if the pc belongs to you, you are the administrator. as for the fault, it's sounds like you have damaged the board/socket, remove the rear cover & inspect.
Apr 19, 2017 | Toshiba Audio Players & Recorders
Can i use headphones on the nc10 ?? if so, which socket ??
It appears that on the right hand side of the notebook you should see a green socket. It most likely has a picture of headphones or so. This is how you may use your headphones.
Let me know if you need any more help with this.
Apr 19, 2009 | Samsung NC10-14GW PC Notebook
Jack for headphones
Whether your unit has a jack for headphone or not I don't know. But if it has sockets for line out it can be of some help. Line out sockets provide the output from preamplifier section and in many conventional audio systems the same is the substitute for driving headphones. So you can try connecting your headphones to the line out sockets using an adaptor pin.
NB-The preamplifier of all audio systems are not able to drive headphones. Only some can. But if you introduce a headphone amplifier between the line out sockets and your headphone it will SURELY work.
Jan 29, 2008 | Oritron OP1181 CD Boombox
No Audio Output on headphone.
uninstall audio diver and
reinstall your audio driver
i think thisis motherboard line out problem
check external speaker its is work mothwrboard is not problem
Oct 21, 2007 | Acer TravelMate 3260-4874 Notebook
Tomtom ONE GPS Receiver Logo
75 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
