Question about Maestro Fan/light Dimmer Ma-lfqhw-wh Fan-light Dimmer
Controller (s) not working
I have 2 Maestro Fan/light Dimmer Ma-lfqhw-wh Fan-light Dimmers on 2 seperate circuits in my house. 1. in the living room. 1 in the dining room. each are on seperate circuit breakers and were installed on the same date. Today neither are working.. the LED for the fan porton is on the lowest setting and is solid. The LED for the lighting control is "cycling" up and down.. both controlers are doing the same thing... Any suggestions?
  • him101 May 15, 2009
    tried all the pull chains in different combonations.. bypassed the switch unit as well. the default possition should be fan on and lights on full intensity., Not working.. I think it may be the canopy units
  • 44 Answers
Someone used the pull chain on both units. Whenever you install a remote or wall-mounted dimmer, it's always best to cut the chains short (after setting the fan to high) to prevent someone who doesn't know any better from using them.
Download the installation sheets here:
http://www.lutron.com/cms400/PageBuyNow.aspx?id=16977&mn=1815
Posted on May 15, 2009
  • badenhop
    badenhop May 24, 2009
    Have you reset your circuit breaker(s)? If not, please try again and post your results.
I have a Meastro dimmer MAW-600 W that is installed, but the light does not turn on and the LED keeps blinking. Any idea what the problem can be?
1) If this installation was working before, the Maestro has a small pull-out circuit breaker that lets you reset the device. This is called the FASS Front Accessible Service Switch, located at bottom of dimmer where it meets cover plate.
Open sample Lutron Maestro dimmer manual to see FASS illustration
http://www.lutron.com/TechnicalDocumentLibrary/0301106A.pdf
2) If this is new installation, then double-check your wiring and check that load matches dimmer capacity: 600 watt incandescent or halogen, which excludes CFLs apparently.
Some electronic devices have shortened lifespan on circuits that are not clean. Use circuit analyzer on outlet on same breaker to see if line has interference.
3) I don't see MAW-600 W listed among Maestro dimmers, so I don't have that specific manual.
http://www.lutron.com/Service-Support/Technical/InstallationInstructions/Pages/InstallationInstructions.aspx?syst=Dimmers+%26+Switches&prodn=Maestro%C2%AE+dimmer+%26+switch
4) Amazon certainly shows the MAW-600 W, in case you need a replacement.
http://www.amazon.com/Lutron-MAW600H-WH-Electronics-Maestro-Dimmer/dp/B000BPCWQE
5) Lutron has customer service numbers:
1.888.LUTRON1 (588.7661)
1-800-523-9466
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on dimmer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 02, 2011 | Maestro Lutron Dimmer 600 Watts Ma-600-wh
Tonight I went to turn on the light and i felt a static shock, then the light just started blinking and the fan would not respond. The light on the switch is just going up and down? Is this a hazard? What...
You posted under Maestro fan-light dimer, but don't say what type of wall device this is.
It sounds like electronic switch.
1) Surge might have burned out device electronics.
Turn off circuit breaker and see if device resets itself.
2) Lutron has tech support number
1.888.LUTRON1
(588-7661)
8-8 eastern standard time
3) Help identifying product for ordering online replacement if needed:
http://www.lutron.com/Products/StandAloneControls/Dimmers-Switches/MaestroIRDimmer/Pages/Models.aspx
4) Add a comment for more free help.
5) Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Jan 17, 2011 | Maestro Fan/light Dimmer Ma-lfqhw-wh...
My Lutron dimmer/lights suddenly will not turn on. all electricity works throughout the house. The green light that usually is lit on the panel is not on either. any suggestions?
Indicator light is OFF.
Either dimmer stopped working or power to dimmer is off.
Check if electricity is present inside box.
Check nearby electrical plug to see if everything nearby has power.
Swap dimmer with regular switch and see if lights turn ON.
Check dimmer wires: if wires to dimmer are pushed into 'quick connect' holes on back of dimmer, these wires can get loose.
If dimmer is connected by wire nut, sometimes a wire can pull loose.
If no electricity is inside the box, and breaker is ON, then there is a loose wire inside one of the boxes on that circuit and electrician has to track back until loose wire is discovered.
Replacement parts for in-wall devices are not made.
If new dimmer is necessary, consider lighting factors:
Total wattage of lights. New dimmer has watt rating.
Type of lights. Dimmers specify florescent or tungsten (incandescent) or both.
Single-pole and 3-way. If two dimmers control same lights, one is control dimmer, other is companion dimmer.
Nov 15, 2010 | Lutron #MA-LFQHW-WH 300W White SP Light...
Lutron dimmers throught the house, lights go high brightness to low all by themselves, is this just a bad dimmer?
I have spent considerable time on the Lutron site past couple days looking at their dimmers.
Lutron has a lot of dimmer varieties. The basic breakdown is 600Watt and 1000Watt. But different dimmers control different types of lighting.
Here is the long list of Lutron dimmer manuals:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
I cannot find a specific troubleshoot manual for Lutron dimmers
So I suggest 4 things:
1) Feel the dimmer switch for heat >>> if it is getting hot (not warm), then that dimmer is dangerous, so remove dimmer immediately, add up your total bulb wattage to make sure you're below the 600 or 1000 watt capacity of you model dimmer
2) Look at the list of manuals shown at link, and make sure your dimmer matches the type of bulb you are using. Your dimmer model number and wattage should be printed on side or back of dimmer.
3) These dimmers use electronics to control the lights. Electronics go bad. The higher the wattage controlled by your dimmer, the more heat, and the shorter the dimmer life.
4) Short in the wires. Replace your dimmer with one from Home Depot and see if the condition persists. If it does, then a short is probably somewhere in that circuit. Troubleshooting a short is another long answer that needs more wiring detail ... please repost if you have a short.
Oct 17, 2010 | Maestro Lutron Dimmer 600 Watts Ma-600-wh
I am trying to install two Lutron dimmers in the same box. The dimmers are models MA-S8AM-WH and MA-600WH. I can get get the MA-600-WH to work but not the MA-S8AM-WH. Anyone have any hints.
My first thought is that if you were using these devices to replace existing light switches, the MA-S8AM has an additional electrical connection that wasn't necessary with a light switch or the MA-600. The MA-S8AM has an addtional screw on it (I think its silver in color) that connects to the neutral wire in the circuit. Hopefully you have a bunch of white wires all wire-nutted together in the back of the box - pull a connection from there and attach.
If that's not the issue, then I would call Lutron's tech support. They're available 24/7, so you may as well. They're at 1-800-523-9466.
Aug 25, 2010 | Maestro Lutron Dimmer 600 Watts Ma-600-wh
Lights won't dim
Here's a link to an article that explains the wiring. If you've followed the guidelines, then maybe you have a faulty dimmer.
http://www.ezdiyelectricity.com/?p=441
Mar 16, 2010 | Maestro Lutron Dimmer 600 Watts Ma-600-wh
I just wired 2 3way switches with 3 lights in between them. Tried 2 different dimmer switches on the circuit but neither would dim the lights nor operate the lights as they should. The lights perform...
In general practice, you can only install ONE 3-way dimmer switch to control the lights. If you use two regular 3-way dimmer switches, the circuit won't work.
However, newer technology allows for double 3-way dimming from different locations. See this article about how to do this:
http://www.smarthome.com/2494M3/SwitchLinc-3-Way-Dimmer-INSTEON-3-Way-Dimmer-Kit/p.aspx
Mar 12, 2010 | Maestro Lutron Dimmer 600 Watts Ma-600-wh
I went to replace the Lutron Skylark dimmer with the Maestro today and found 3 black wires in the box, 2 were bundled and connected to one of the dimmers black wires and the other 1 was connected to the...
The 2 wires that are tied to each other is most likey your hot lead from the panel , the other goes to the light.Tie 1 blk dimmer wire to the 2 wires together and the other blk dimmer wire to the single in the back.Also Maestro dimmers have a small kill switch check to see that it is not off.If you work with hot leads remember don't cross your heart ( wires in both hands current passes through the body)
Aug 31, 2009 | Maestro Fan/light Dimmer Ma-lfqhw-wh...
Lustro Maestro MA-LFQHW-WH Fan/Light Dimmer
something is messed up for sure... two solutions.... disconnect outlet and cap wires.. or open up both boxes and see where / how they they wired the outlet into the fan/ light control and disconnect it there and then pick up power for the outlet from the black /white wires BEFORE the dimmer control
Aug 19, 2009 | Maestro Fan/light Dimmer Ma-lfqhw-wh...
Maestro Fan/light Dimmer Ma-lfqhw-wh Fan-light Dimmer Logo
417 people viewed this question
Top Maestro Electrical Supplies Experts
Steve
jdthefixer
ken skalski
Are you a Maestro Electrical Supply Expert? Answer questions, earn points and help others
