Question about GE JKP27 Electric Double Oven
The oven is flashing code F7 and keeps beeping
  • 6,784 Answers
HI, this is an issue that concerns either the key pad or the control board.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Posted on Jun 20, 2009
My stove is beeping and is flashing F7. What does this mean, it is a built in oven.
The F7 error code means that a function key on the touchpad is shorted or stuck, the F7 can be cleared by pushing the clear/off button,if the error code returns the touchpad would need to be replaced.
GENE
Sep 10, 2011 | GE Ovens
JKP15 Electric Single Oven: Oven keeps beeping with F7 error...
F5 Loss of relay drive circuit If this fault code cannot be cancelled, replace the oven control (also called clock or ERC).
May 07, 2010 | GE JKP15 Electric Single Oven
Ge oven JTP15 beeping and flashine F7 error
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Jun 17, 2009 | GE JTP15 Electric Single Oven
Double GE wall oven - F7 code
from repairclinic.com:
It looks like you have a function button pad stuck or a bad clock.
Unstick button or replace electronic range control.
Apr 27, 2009 | GE Ovens
F7 beeping an cannot stop it... any solutions?
HI, if this error code cannot be canceled, this will confirm a touch pad issue. the membrane is damaged and, this will require you to replace the ERC.
Replacing the Electronic oven control will fix this issue.
Mar 29, 2009 | GE JKS05 Electric Single Oven
F7 code keeps flashing on upper oven, nothing on keypad works
A function pad is probably stuck.
Push all buttons several times each. Often this will clear a stuck pad.
If that does not work replace the clock.
Mar 04, 2009 | GE Profile JT910SASS Electric Single Oven
You either have a stuck touch pad button or a bad clock.
Push all buttons several times to try and clear.
If not successful repair is a new clock.
Feb 22, 2009 | GE Ovens
Beeping and F7 when cleaning
F7 stuck keypad
Stuck keypad may mean relay is turned on.
Jan 07, 2009 | Jenn-Air JJW8230D Electric Double Oven
GE JKP15 Electric Single Oven - Code F7
If possible i will need the letter that come next after the JKP15.
Aug 19, 2008 | GE JKP15 Electric Single Oven
Kenmore Gas wall oven flashes F7 Code
Hi Indy2008,
You can find my solution to the most common cause of the F7 problem at the following link:
http://www.fixya.com/howto/h155060-dreaded_f7_error
I have helped over 1600 folks solve the F7 problem. The problem is usually with the touchpanel and not the ERC. My fix tells how to determine which part is faulty. Hopefully you will not need to purchase a new touchpanel, however, if you do, an internet search will lead you to lower cost sources.
Please let me know if my fix works for you. You can email me at:
hutchipop@yahoo.com
Regards,
Powerman
Mar 19, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Ovens Logo
250 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
