Question about Refrigerators
Ice maker water line freezes
The water line inside the freezer freezes before water can fill up the tray. Ice maker Kit: UK Kit - 6 GE Refrigrator TBXS21K
  • Anonymous May 26, 2009
    how do i fix the leak in the inlet tube?
    thanks
    President:
  • 1,136 Answers
Hi, it sounds like the water valve is leaking just enough to cause the water to freeze in the inlet tube. This is the most common fix.
If I can assist you further, please let me know.
Thanks
Vic
Posted on May 15, 2009
I have a GEmodel GFSF2HCYAWW french door bottom freezer model. The ice maker seems to not be getting cold enough, resulting in drippin water that freezes all cubes that do form into one huge clump o
Sounds like your water inlet valve is leaky. Go to repairclinic dot com AnD type in your model number. they will have a fixit kit with all the icemaker gear in it for the big bucks, as well as the individual parts separately. Check that your fill hose has not failed or that the icemaker mech assembly is not cracked or broken.
Jan 12, 2015 | GE Refrigerators
Troubleshooting a GE TPX24 icemaker
a19e2387-1433-4c2d-bb46-e670a2bac700.jpgSimple if the ice maker is not filling with water after cycling then fill ice maker until full allow water to freeze and if the ice maker drops the ice into the ice bin and then does not refill with water replace the=> WR57X10051 Water Inlet Valve If the Ice Maker does nothing with ice still inside the ice cube slots then replace the=> WR30X10093 Ice Maker Assembly These ice makers are electronic and once they fail there is no replacable parts. I am here should you have questions, Thanks Sea Breeze
Jan 13, 2013 | GE WR30X10093 Refrigerator Icemaker Kit
Ice maker fill tube freezing
There is a possibility that the water valve isn't closing completely leaving just enough space for a drop or two of water to make its way and freeze in the tube, but more than likely the fill tube is a plastic one and little divots have formed retaining water and freezing up. These divots may not even be visible to the ***** eye. A good solution is to switch to a rubber fill tube which is less likely to have this problem.
Jun 16, 2012 | GE Refrigerators
GE TFX24E side by side refrigerator, ice maker won't fill with water.
Hi, I have a GE TFX24E refrigerator. The ice maker is not filling with water. I replaced teh water valve with no joy. If I pour a cup of water into the dispenser the ice maker will freeze and harvest the ice. Any ideas? Is there a replaceable water fill sensor?
Sep 03, 2011 | GE WR30X10093 Refrigerator Icemaker Kit
I have a ge side by side both the freezer and fridge will not cool off, we hear the fan but nothing happening
Follow the steps mentioned below to solve the problem:
First remove the ice bin and look inside the mold of the ice maker to see if it is full of ice. If the ice sensing arm is down ( on position) and the ice maker is full of ice, there is a failure inside the ice maker and the ice maker should be replaced.
If there is no ice in the ice maker, look at the fill tube on the rear of the ice maker. If the fill tube is frozen up the ice maker can't fill.
You can defrost the fill tube with a hair dryer.
The water valve on the rear of the refrigerator supplies water to the water dispenser and the ice maker. Since the water dispenser is working, the only line that could be blocked runs up the back of the cabinet and attaches to the fill tube for the ice maker. The water valve could be bad and not sending water to the ice maker.
If the fill tube freezes again you should replace the water valve.
Hope this helps.
Shane
Mar 12, 2011 | GE Refrigerators
I do not believe the other advisor understand my problem. I have a GE Profile Arctica refrigerator PSS25NGMDBB. The problem is the cup fill (GE part name) is frozen and full of ice. So when the ice...
You are right. The water inlet valve is leaking a small drip and it freezes when it reaches the cold air in the freezer at the fill tube. Melt the ice in the tube with a hairdryer and replace the water inlet valve. It's on the back where the water supply connects to the back.
Feb 22, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Water leaking to bottom of freezer
ok you have a blocked freezer drain. The best thing to use to clear this is 'curtain wire (the plastic coated wire you use to hold up net curtains). Ok you need to find the drain hole in the "small tray on the back wall inside that fills and freezes and then the water is overflowing at this point to the bottom of freezer" you want to gentley feed the curtain wire down the hole untill the water drains down there. If you can't get the wire down you may need to turn the unit off to defrost as it could be frozen solid with ice. cheers
May 31, 2009 | GE Refrigerators
The ice maker (GE Profile - 3 years old) produces ice and then, the next morning, the ice melts down into the rest of the freezer (i.e. the ice compartment is somehow not staying cold enough to sustain any...
If the unit is freezing well in the freezer and your ice bin is defrosting or ice is melting together it is your ice maker over filling the tray causing water to leak into the bin. You can purchase kits that contain all ice maker parts needed , it may be the ice maker and it may be the water inlet valve in the back , both come in the kit , go to sears parts on line with the model number from your unit.
Dec 30, 2008 | Refrigerators
Ice maker freezing up
The problem is in the water valve.
The water supply line going to the Ref is connected to a water valve. This valve is not shutting off completely which causes water to drip into the ice maker. This dripping will freeze and eventually completely block the fill tube in the freezer.
Aug 23, 2008 | Whirlpool ED2FHSS Side by Side...
Refrigerators Logo
223 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
