Matsui plasma tv
When turning off my tv i normaly just flick the power switches on the plugs, i rarely use the on off button on the set, since new (about 2 years) i have used the set switch about 20 times. i turned the set off the other night and then wen i came to turn it on the on off switch wouldnt click in and activate the set to come on. i have tried pressing it a million times and nothing is happening?? can you suggest anything?
  • 372 Answers
Hi.
What is the model number of your matsui tv. ?
http://dysonmanuals.inc.io/
Posted on Oct 19, 2007
How to I reset my Matsui 19W127 to factory settings
  1. With the TV in standby:
  2. Press and hold the {i} button on the remote while pressing the {POWER} button on the TV.
  3. The TV will turn on with the Service Menu displayed.
  4. Use the {UP}{DOWN} buttons to select menus/options.
  5. Use the {LEFT}{RIGHT} buttons to change settings.
  6. To exit, turn the power off.
May 30, 2017 | Televison & Video
I have had a Hitachi 42" Plasma screen TV for almost 3 years and recently it has had problems. When you turn it on, the TV only stays on for about 10 minutes, and then the screen goes black with the...
The signal from the STU to the Hitachi box is going in the wrong direction.
Is the adaptor that you have switchable? If so, flick the switch in the
other direction and this will fix it. If the adaptor is not switchable get
one that is. Then set the STU output to RGB.
Hope this Helps. -CA
Jul 14, 2008 | Televison & Video
Turn on tv blue light comes on then when i press a button to put a channel on blue light re appears
What you see is a protection mode. Change input device to some other like a DVD player. Switch off TV, switch off power, remove plug and wait for 48 hours and retry. If problem persists, call in a qualified service technician.
Aug 03, 2012 | Televison & Video
My ps3 normaly runs on hdmi but i have to use a standard def tv. i plugged in the Av cables and the screen is blank
KEEP YOUR FINGER ON THE POWER BUTTON WHEN SWITCHING IT ON AND IT WILL RESET THE OUT PUT SETTINGS TO DETECT NEW INPUTS.
Jan 23, 2010 | Sony Playstation 3 (PS3) Console
Philips 42PF5320 plasma - unplugged and plugged in. wont turn on
This is a common problem on these plasma TV's. The problemresides in the high voltage boards known as the X and Y Sustainboards.. You can purchase them here for a very reasonable price:
http://www.discount-merchant.com/Y-SUSTAIN-FOR-42-PLASMA-TV-PN-6871QYH036A-p/sku9510.htm
The above link is to a Y-SUS board. The X-Sus board is often the 2nd cause of failure and can be found here:
http://www.discount-merchant.com/X-SUSTAIN-6871QZH041B-6870QZE017D-6871QZH052D-p/sku9509.htm
Totest which board is failing, you need to check voltage input to theYSUS board first... Input should be 120V from Power supply, outputshould be above 250V.. Do this test with XSUS disconnected. IF 250+Vexists, then XSUS is damaged. If not, then the YSUS is the faulty part.
Sep 14, 2009 | Philips Televison & Video
Brand new LG plasma stuck on test screens
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
Hope it may help you;
Regards;
VOTIT
Jan 29, 2009 | Televison & Video
No power
it sounds like he triped the internal fuse on the tv when he surged the power
Dec 01, 2008 | Hitachi P42H401 42 in. Plasma HDTV
Matsui television
1 it might be due to loose contact in plug or socket. 2 there might problem in power supply section in your tv.
Sep 17, 2007 | Televison & Video
Televison & Video Logo
127 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
