Question about Maytag PAV2300 Top Load Washer
Transmission tries to spin... belt spins and the rubber smell comes. Should I get a new transmission? The washing machinge is only three years old. Thanks... Honey Do Man
  • Maytag Master
  • 8,220 Answers
Check the pump bearing. They lock up frequently on this type machine.remove the belt and turn the pump. It should be easy to turn with no visable bearing parts showing.
21001906 is the part number.
Posted on May 15, 2009
Washing machine has smell (burning) and doesnt spin or drain tub.
Sounds like the belt may need to be changed. it eh pulley are spinning but the belt is not, nothing will spin and the friction of the pulley against the belt will cause a burning rubber smell
Nov 27, 2013 | Washing Machines
Washing machine not spinning
HI! base in your complaint and explanations! i find the problem is the motor belt... maybe this is too loose belt... you can replaced a new one replacement belt... and make sure when you replace the belt is the same size in the original!
Nov 01, 2007 | GE WJSE3110A Top Load Washer
Washing machine was making noise when agitating & spinning
This sure sounds like a bad transmission. Turn the transmission by hand to feel and listen to it. It should be smooth and quiet.
May 04, 2009 | Maytag PAV2300 Top Load Washer
Washer makes a squeel and burning smell
belt which operates pump/motor/transmission pulleys
Apr 10, 2009 | Washing Machines
Grinding noise,unit stopped, burning smell?
broken or slipping drive belt, motor to spin pulley defective drive clutch, spin brake fails to release to transmission is frozzen
Oct 07, 2008 | Admiral AW22 Top Load Washer
Frigidare top loading washer 6 cycle - 10 years old
you may want to inspect the bottom part and see if it still uses fan belt. it could be that the belt is loose and the motor is spinning but can not drive the transmission. so the rubber burning smell is coming from the slipping belt.
the solution is to tighten the belt or replace it if necessary.
tnx 4 using fixya,
drcool
Sep 20, 2008 | Frigidaire CWS3600AS Top Load Washer
GE Washer smells like burnt rubber
Hi, timhowarth1
ngafm at your service,
Because it wouldn't agitate or spin at all the belt burned as it tried to spin!
A problem with th coupler or transmission.
You need an experienced and hands on laundry tech or you may make matters worse or spend money replacing parts unnecessarily.
How old is the washer?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
Bless You ngafm
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF
Thank You
Sep 09, 2008 | Washing Machines
Won't hardly spin
Happymarried
You said,it won't hardly spin It suppose 2 spin fast
It sounds like a worn belt. Does it smell like rubber burning?
Or like the coupling connecting the transmission to the agitator is worn out!
If I were there hands on I could be definite.
But it sounds like you need this replaced!
Thank God it's not the transmission.
When a transmission goes out of warranty, it;s not worth putting good money into bad! They are just to expensive a repair!
Only a hands on laundry tech can make the diagnoses.
This time you should call service
Let me know what is the final results.
Please write me back.
How old is the washer??????????????
Bless You,
huuum
Please give me a good rating before you sign off.
Thank You
Feb 12, 2008 | Frigidaire FEX831CS Top Load Stacked...
Burning smell + Screeching sound but Belt is not the cause, then WHAT is?
A lot of people may be searching for help with horrible sounds and burned belts for Maytag and Admiral washers only a few years old from Home Depot etc. They used a cheap pump that has a corrugated sheetmetal ring that holds the bearings. Well as it runs the vibration and friction cause it to slip down and grind on the pulley as well as not turn easily. If you put the washer on it's back and turn the small pulley and it turns with a gritty feel or you can actually see a loose metal collar type ring thing that looks like a cookie cutte; then you have a bad pump.
There is a small access panel on the back of the washer. Three screws and two spring clips on the hoses and you're done (use big pliers on the hoses). Put the belt back on (just push motor to one side, it's not tight), then check for leaks and reinstall the cover. VOILA! You can find the pump on ebay for $25 or your local GE parts dealers for $50.
Sep 11, 2007 | Maytag SAV5710 Top Load Washer
Washer smoke during spin cycle...
could be belts slipping or a bad motor going - what's it smell like - burning rubber or an electrical smell?
Aug 28, 2007 | Kenmore 98702 Stacked Washer/Dryer
Maytag PAV2300 Top Load Washer Logo
80 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
