has stopped playing DVD alltogether it just clicked and wurrs and makes noise and CD playback is slow and crackly can you please tell me whats wrong with my machine.
Comments:
May 15, 2009
- yes it is a laptop it is in, acer 3683....also it will not play DVD discs
May 15, 2009
- I have a dry clean kit which doesn't seem to be working would a guru recommend me getting a wet kit to clean the laser or just get replaced??
Lazer would need to be cleaned with a clean kit if this does not shore it up then the lzer would need ot be replaced if this helps you please rate it also we d o not get compensated for answering your question we rely on your good ratings thanks..
Here's what to do and if this doesn't work replace the dvd drive. Open the tray and you'll see the lense assembly. Get a q-tip and moisten one end with windex and leave the other dry. Very gently and carefully rub the lens with the wet end of the q-tip and then clean with the dry end. Be carefull not to press down hard on the lense it may damage the laser. This should work. Good Luck
Was this helpful?
Yes
No
Popular Solutions for Acer Internal 32x CD-ROM Drive
My Lightscribe DVD Supermulti Drive /CD Writer is not opening its slot. When OPEN button is pressed,...
(More)
My Lightscribe DVD Supermulti Drive /CD Writer is not opening its slot. When OPEN button is pressed, I hear the noise of opening mechanism, but the actual plate doesn't come out. Tried to open HP Solution Center, but got the following message: Parsing error in file C:Program filesHPDigital ImaginginhpqsclocC3.xml
Ive lost my drivers for travelmate 4650 and my toshiba tecra s1. I have tried to use the drivers...
(More)
Ive lost my drivers for travelmate 4650 and my toshiba tecra s1. I have tried to use the drivers from the website but they do not work. Any help? Thanks :)
why will the DVD not open. The light flashes when pressed and on the control panel I have tried...
(More)
why will the DVD not open. The light flashes when pressed and on the control panel I have tried pressing extract, but it still will not open. Any suggestions on how to unlock or unjam? Thanks. P.
