Question about Brother HL-2040 Laser Printer
Paper stuck in printer, I need to dismantle printer to dilodge it and don't know how
    Sergeant:
    Champion:
  • 240 Answers
Im not sure of your 0f your printer if there is a backdoor on it..
try to open...the backdoor of your printer...if available..
its located on the rear portion of your printer..^_^
Posted on May 15, 2009
Dismantle the Canon PC6 copier to remove paper fragments.
Try to dismantle it by the look, you need to remove leftside covers.
If you want I can send you service manual.
emma.servis@gmail.com
Jul 03, 2010 | Canon Office Equipment & Supplies
I have some small pieces of paper stuck in the fuser unit from a sheet that got stuck - how do i get them out as I cannot see them?
Start to dismantling it untill you are able to see the paper and then with tweezers remove the paper carefully
May 03, 2010 | Konica Minolta magicolor 2430 DL Laser...
Printer has paper stuck. I can't see the small piece of paper. The printer will not work.
I would suggest taking dismantling the printer, but check in manual for safer way of freeing the paper.
Hope this helps!
Feb 06, 2010 | Computers & Internet
Paper Jam light is on and there's no jam anywhere. What do you do?
A paper jam notification can be caused by two things. One a hard jam, paper stuck.
Two, If the paper does not reach a flag or sensor on time, the printer knows that a jam has occurred.
Most likely, you had a paper pick problem caused by dirty rollers or maybe the paper is held to tightly by the paper tray. Also a static charge on the paper can sometimes cause sheets of paper to stick together.
Don
Dec 09, 2009 | Dell 1720dn Laser Printer
Paper jam epson c84
If you are sure that no scraps of paper (or other object) is jamming the paper feed path, you will need to dismantle the printer to investigate further. This is really a job for a technician; however, if you want to have a try yourself, you can download the service manual from here:
http://www.eserviceinfo.com/downloadsm/12748/Epson_C64%20and%20C84.html
Also, post a new comment to this effect since I can provide useful extra info on getting these difficult machines apart.
May 08, 2009 | Epson Stylus C84 InkJet Printer
Howto dismantle officejet printer 5610, and remove battery
well if you are having a paper feed problem then you dont need to disassemble the printer. observe the area where you feed the paper in and you will see two rollers pressing don on th paper when loaded. theas two are spring loaded to adjust to the thickness of the paper in the tray. 10 sheets or tyenty five . it still appplies downward pressure on the whole stack of paper. The rubber roller is on the right ,and a hard plastic one on the left. the rubber roller is the motorized feed roller. Clean both with a q-tip.
Nov 30, 2008 | HP Officejet 5610 All-In-One InkJet...
Printer not working
There is a high possibility of something stuck in the interior of the printer.Take a flashlight and check the paperfeed area for anything that is obstructing the roller movement(you can hear for the sound of the rollers for this)Then turn off the printer gently tilt it such that the paper feed thing is facing downwards and gently shake the printer..If nothing comes out open the side and top panels of the printer so that you can have a good view of the paper feed area..
PS:Deskjets are panels are pretty easy to dismantle..You can let me know if you need help or refer your manual..
Eagle!
Oct 23, 2007 | HP DeskJet F380 All-In-One Printer
Epson stylus photo 830
Yes it can probably be fixed. I hope you poked your friend in the eye for giving you such a headache though. You will need to dismantle the machine and remove the Auto Sheet Feeder (ASF) Once removed, check there is no bits of paper stuck inside. Then turn the pick up mechanisme by hand through a couple of revolutions to re synch everything. Also check the paper sensor is still intact - if not you can construct a new one from a piece of plastic or if the old one is still present, just glue it back together. You can download a service manual to hep you out with the dismantling from either: http://www.TheServiceManualShop.com http://mikeburton.tradebit.com/
Apr 12, 2007 | Epson Stylus Photo 830 InkJet Printer
No Paper jam
It is possible that your machine has either a foreign object stuck in the feed path or that the paper sensor has got stuck or broken. The best way to tell if something has entered the mechanism is to tip it on it back and give it a gentle shake or nudge. Then continue to turn it over (front to back) so that if anything was dislodged it should fall out of the back. If nothing falls out, it may be neccessary to partly dismantle the machine and physicaly check the state of the feed mechanism to see if there is something stuck, or if the sensor is broken. If you need a service manual to be able to dismantle the printer check out. www.TheServiceManualShop.com if they do not have it listed, they should be able to get it for you and they are very good value for money.
Apr 08, 2007 | Epson Stylus CX3800 Printer
Paper-stuck errors
1. turn printer off and back on, maybe it can solve problem itself. if it gives you a specific error code, check manual for its meaning. 2. turn printer off 3. remove paper trays, check for any wrinkled or torn papers in there. 4. open all entrances to achieve reaching ways for all parts. 5. if needed, remove tuner. put it in a sealed bad to prevent damage. 6. if you see a stuck piece of paper, pull it strong, with both hands. your goal is to keep it from tearing to pieces. 7. if it gets torn, spin the wheels manually to release it, do not use force. 8. return the tuner, close all entrances. 9. if it happens again, dismantle it again and follow the paper route.
Feb 22, 2006 | Citizen Impact PR Matrix Printer
Brother HL-2040 Laser Printer Logo
112 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
