Question about Sony Televison & Video
Picture ok,waves show run left to right
On screen picture ok but wave is coming from left ot right. I think Is EHT gets less power now or some capacitor are going dry ? tell me please. TV sony kv27v65 vyasashvin@hotmail.com toronto canada
    Genius:
  • Sony Master
  • 1,148 Answers
CHECK THE MENU FOR OPTIONS ,,CHANGE ALL JACKS AND CONNECTIONS,,
Posted on May 15, 2009
Generator burning my electronics up
take you generator in and have the output tested for correct voltage and sine wave configuration
electronics rely on a perfect sine wave ac current as a manufactured sine wave affects electronic components such as capacitors, transistors and diodes
generator sets that run an alternator ( not an inverter ) have a pure sine wave and have less affect on electronics.
go google and type in search headings like ---sine wave, inverter sine wave, sine wave affects on electronics, alternator operation and inverter operations and then you may get a pointer as to why your inverter gen set is affecting your electronics
Jul 23, 2016 | Honda EU3000iS Inverter Generator
My Casio wave ceptor EQW-M100D has started to show the wrong time, it started with a couple of minutes slow but this has now esculated to 12 minutes slow. This normally happens when the watch is left off...
Instruction book page E-23. To turn auto receive on or off. In Timekeeping mode press D (Lower right) to display last Signal screen. It should say GET at the bottom and show the last time it updated. (Or ERR) Hold down A until the receiving indicator and current auto receive setting (ON or OFF) start to flash. Press D to toggle auto receive on. A again to end.
If you tried to make it receive manually this will be turned off. If the GET screen said ERR then it did not update and auto receive would still be off. I had to do the manual thing about 20 times before it updated. A upper left C lower left D lower right A upper right (light)
Aug 31, 2013 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Toshiba 32AF45 CRT TV Distortion and Flicker During Moments of High Contrast?
Check its main power regulator section circuit. Replace all the electrolytic capacitors there. This is a power supply fault.
Mar 21, 2013 | Toshiba 32AF45 32" TV
When i try to adjust the convergence, the red and blue adjust ok, i assume the green in the basline color, but it turns up on the right side of the screen and the picture has a green wave in the lower left...
The tv 100% have convergence problems,it dead,if have any colors lines mis alignment or don't stay in the convergence - + grid.The tv convergence board is dead.The 2 STK convergence ICS and some or all is resitors are dead.Must replaced these parts on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Dec 11, 2010 | Panasonic PT-47WX49 47" Rear Projection...
Picture has a "wave" along the sides
I have the parts, very cheap. hill6399 at yahoo.
May 21, 2009 | Toshiba TP55H60 55" Rear Projection...
Blue wave across screen
Just click below for convergence repair kit;
http://servicemanuals.vstore.ca/
Double images and colors are blurry .Blue,red and yellow wave coming up from the bottom of the screen on the lower left symptom is for busted convergence IC,you must replaced this IC in order that will works better again.STK 392-xxx ICs and it's associated resistor,this resistor automatically change value,can caused truoble even though you change the ICs.If you bring this to a service center they cost you $600 to $700,but if you buy the repair kit you can save more,don't wory it is very easy because there is intallation guide including in the repair kit. Feel free to ask whatever the result... click the link for sample picture guide step by step installation;
Hope this may help;
Regards,
VOTIT
Sep 08, 2008 | Apex Digital GB5108 51" Rear Projection...
Red and green fuzzy waves across the screen
my screen just became distorted (red picturer to the upper right & green picture to the bottem left ? can you help me ? wuzuphippie55@yahoo
Sep 08, 2008 | Philips Magnavox 9P6034C 60" Rear...
How to repair a samsung rear projection tv
your power supply is getting weak
Aug 25, 2008 | Televison & Video
Waves
Hi hoovs, Waves streaming normally comes from the 60 cycles hum of the AC mains. Sometimes this is caused by poor or loose grounding in the video cable or at times a weak or defective capacitor in the power supply of the monitor or at times low voltage supply to the monitor. If after checking your cables (both power and video) are not loose and are snugly fitted to their connection points and you still get the waves, then you are probably better off returning the unit for replacement. Another thing you can check is if the monitor is getting enough power. If the monitor's power supply is rated 100~240 VAC, then it should work out ok. If it's got a 240 rating and you are using it in 110, then the monitor is not getting enough juice which may cause the waves. On rare occasion, waves may be eliminated by simply plugging in the AC plug of your monitor the other way around. Hope this be of some help to you. Pls post again how things turn up. Kind regards.
Jul 18, 2007 | Samsung 906BW LCD Monitor
"Waves" generating from the right of the screen.
It's power distortion. If you move the monitor away from the pc, the waves will stop. It's magnetic distortion causing this interference. Your monitor is fine.
Jul 05, 2007 | Dell E173FP 17" LCD Flat Panel Monitor
Televison & Video Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
