Question about Electric Bumpfeed Trimmer, 12"
Need cap for electric 12" trimmer/edger
Where can I find cap that goes over spool
Broken trimmer spool and bump
73-8490 is the spool assembly part number. If you need the cap as well that part number is 105-9422
Sep 08, 2012 | Toro 51347 11" Electric String Trimmer...
Replacing the spool of string for my black and decker 12v electric trimer ? grasshog model
If it is the same as my old 12V version, flip it over and look at the bottom, this is the cap for the string, on the sides there are two push button latches, depress and pull the cap off. Then reach in and remove the old spool. Insert the new spool with the circular sawtooth design to the inside and push the end of the string through the hole in the side. Replace cap ensuring that both latches engage.
Jul 08, 2011 | Black & Decker String Trimmer Cordless 12"...
How do you repace spool
yes becoase it is improtante to replaceit
May 03, 2010 | Worx 12" 4.5 Amp 2 In 1 Grass Trimmer/In...
How do you remove the line spool cap on a toro electric trimmer?
There are 2 tabs, 1 on each side of the cap. You need to press these in at the same time to pull the cap off.
Apr 06, 2010 | Toro Electric Trimmer
I need part for a Craftsman Weedwacker
You can either go to sears, or craftsman website or even easier if you can get one off of ebay
Aug 18, 2009 | Garden
Spool is stuck
Have you tried using vise grips to get it off. Next time put neverseize on it.
Jul 18, 2009 | Craftsman 25cc Gas Line Trimmer
I have a Toro 12 inch Toro Electric trimmer and I can't get the spool off to change. Any solution?
I am having the same problem - the spool should just come off by turning it counter-clockwise but is completely stuck. This model does not have any tabs that need to be pushed in to get the spool off. Very frustrating!
Jun 03, 2009 | Toro Electric Trimmer
I have an 11" Toro trimmer and was having trouble deciphering the symbols on the base. The key is having a method to gain some opposing force to unscrew the cap that holds the spool. I have an oil filter wrench called the round wrench. It is a steel bar with an attached length of rubber belt that can tighten around cylindrical objects. I used that to oppose the unlock direction on the trimmer and "voila", no tabs to push no trick with the button, you just need o_1089.jpg_1088.jpg_1087.jpgpposing force.
May 26, 2009 | Toro Electric Trimmer
How do I insert sring into trimmer
1. take spool cap off;
2. take your spool out of spool housing;
3. reload line on the groove of your spool;
4. final, get it back.
Aug 04, 2008 | Black & Decker String Trimmer Cordless 12"...
Electric Bumpfeed Trimmer, 12" Logo
Top Electric Garden Experts
Steve Oakes
dannydoesita
Mike
Are you an Electric Garden Expert? Answer questions, earn points and help others
