Question about Nokia 6280 Cellular Phone
My phone was washed by my nephew
My nephew washed my phone with water and when i turn it on it won't work any more and it was already 10 months since this incident happened. what should i do to make it work again? please help me
  • 470 Answers
Try to open your fon, and let it dry the surface that drain by the water, and clean it with the toothbrush using a lacquer thinner, then try it on
Posted on May 15, 2009
My kenmore 29822800 won't fill with water, it works on spin and drain
The last time I moved, my washer/dryer combo (Frigidaire) had the same issue for approximately 7 months before finding out all I needed to do was level the washer, and of course, make sure the faucet connected to the washer is turned to on position. Hope this is helpful.
Praysemema.
Mar 13, 2013 | Kenmore Washing Machines
Have a 1995 Chevy Caprice classic won't start get light that says pass key fault
Get a second ignition key, the one you are using is dirty or moisted, you need to turn on and off the car witha clean key, hapens to me once in a while.!!
Jun 24, 2012 | 1995 Chevrolet Caprice Classic
We pulled our stacked washer out from the wall to service the cold water hose filter on the back of the unit. when we pushed it back into it's location the washer won't start, won't fill...
I know you don't want to hear this, but either you did something to the hose filter or you didn't get it plugged back in correctly.
If you banged the water inlet valve in moving it back, it might be damaged.
Suggest you unplug everything and start over.
Sep 04, 2011 | Frigidaire FEX831F Top Load Stacked Washer...
After wash cycle, tube will not drain water?
Probably a blocked empty pump filter. Spin won't kick in until all the water is evacuated. If there is a little left, the machine will do the slow turn cycle that it does just before spin starts but not start the spin cycle because of the water in the drum.
You need to locate the filter and clean it. That should fix your problem. Once this is done, remember to keep the filter clean every few months.
Jun 23, 2011 | Whirlpool Washing Machines
CRYSTAL LORD 909 not dry spinning or pumping out water
You're the 3rd person to log this problem in 10 minutes!!
Jun 23, 2011 | Washing Machines
This is my Model # WTW57ESVW1 In the normal wash cycle, the timing seems off. When you first turn it you can hear the water but it also seems the agitator is already going and at the end of the cycle when...
Seems possible that the program controller is not working in order of the sequence that is required of the program.
So you must check the connection contacts, clean and try if this helps or else a new controller might be necessary as many of them develop bad contacts on usage..
Check cost , if possible swap and confirm before you buy one to fix.
Oct 11, 2010 | Washing Machines
I washed mu phone in the wash machine a couple of
you should never put your phone in water. If you put it in water then it will not work any more
May 10, 2010 | Samsung Finesse SCHr810 Cell Phone
Fills water & stop
I had the same situation but it is now fixed. Be sure your hot and cold water are both turned on, even if you use the COLD / COLD . My washer kept stopping in mid stream.Haven't had a problem in a month
Jan 29, 2009 | Frigidaire FTF530FS Front Load Washer
Nokia 6280 Cellular Phone Logo
43 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
