Question about Zebra S4M Thermal Label Printer
Printer is only printing on every other label.
I am trying to print using 2" X 1" labels.  The labels are printing on every -other label.  How can I fix this problem?
  • Andrea Falkner
    Andrea Falkner May 01, 2012
    I am also having this problem. New printer. TSC TDP 247
I had a Zebra 90xill that started printing every other label even after full calibration of media and ribbon. Cleaened sensors to no avail. Set factory reset - No Change
If this occurs it is a sensor problem. I replaced the top sensor - It now works perfectly
Posted on Nov 28, 2010
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Zebra Master
  • 1,362 Answers
Adjut the sensor or re-calibrate.
To adjust sensor:
Open up the printer where you put the label, where the paper is fed there is are two green levers, one that helps guide the paper (media guide) which is adjustable by flipping down and sliding that is located  on the right and another one that is ON the media assembly(media sensor) check this for a reference as to what I'm talking about, it's not for a Zebra but they have the same functions.
http://www.posguys.com/download/DataMax-I-ClassManual.pdf
Go to page 29 and magnify it(400%) to get a better look
depending on the type of labels you use is how to adjust
1- labels with a knotch on the side, sensor MUST be all the way on the left ( standing in front of the machine , for reference)
2-labels with a gap in between each one, MUST be set towards the Middle of the labels.
Adjust a little at a time to check by pushing the feed button
if this does not work it must be recalibrated.
I don't have a manual for that printer, sorry.
Posted on Oct 19, 2007
3 Suggested Answers
SOURCE: 2 LABELS COME OUT
your label length is set incorrectly, there are 2 things it could be
1) your software is telling the printer the label length is longer then the current labels, even if the label size is out my a single millimeter the printer will give you this issue of feed an extra label. you need to change this in your software. you can set a label size smaller then the current label size and it will work correctly
2) you software is not setting a label length and so the printer is going off its internal setting, to recalibrate hold feed and power up the printer letting go after the light starts flashing
it is important to note that label roll will change slightly over time so even though you are ordering the same labels as a year ago the manufacturer will have slight changes from batch to batch
Posted on Nov 09, 2007
  • 1121 Answers
SOURCE: My Zebra Z4Mplus printer is skipping labels when I print
check the label margins, and label dimensions, and spacing , normaly is these problem, or is a printer driver problem, try reinstall driver
Posted on Jan 13, 2010
The printer prints one label and skips another one
First, I need to admit it. This is the worst printer I have ever used. I had all kond of troubles with it.
The skipping labels problem was my misery for 2 days to. I had to find out that my labels were falling out of the printing area generating a new page (label). Go back fix your width. Make sure your label fits one page (label). Print again. That's what I did. Good luck.
Mar 27, 2014 | Zebra LP 2844 Thermal Printer
Lx900e primera when print - blank labels
Are you using the program that accompanies the labels. Or by the same company?
I suppose your labels come 3 to a sheet, and you're only printing 1. Have you tried printing 3 at a time?
Jan 01, 2018 | Primera Technology Office Equipment &...
I want to print 2X4 labels without skipping 2 labels each time
obviously its your vb software. try using a real label program and end this issue.
Sep 05, 2017 | Zebra LP 2844 Thermal Printer
Mis align printout
hi, its hard to say but.... does it feed ok or skip labels??? if it skips labels, the sensor will need replacement or adjustment, also download the latest drivers, and if your driver or software gives u the option, play around with the magnification settings, also double check length, borders etc, try making the label length setting appear longer , shorter etc. Hope this is of help to you,M,
Feb 12, 2009 | Intermec EasyCoder PM4i Printer
Print problem
You should make sure you have the label program set for the same size label you are printing and calibrate the printer before you start a roll.
Feb 05, 2009 | Zebra Z4Mplus Label Printer
Okidata - label printing alignment
The solution posted did not work for my problem. Thanks for trying.
Aug 08, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Label Printing
The printer is not the issue here...That is a great printer BTW.
The issue is which program are you using when trying to print out these labels? Do you have Microsoft Word, Works, or some simular word processor program installed on your computer?
There are free document templates that have all the settings for printing 2 x 4 labels and others. Here is a link for a 4 x 2 tem-late that would work in any version of Word, SureThing CD Labeler and any program that handle PDFs.
http://www.worldlabel.com/autoconfig/autotemplates.asp?finditemnum=ol125
You can take label printing to the next level by using a program that will read in your address book and print each on one label automatically. You don't spend time trying to type them all in.
If yo have MS word, look under HELP for "mail merge", that wil get you on the right track.
Let me know =)
Mar 31, 2008 | OKI C9300 Led Printer
Labels printing in reverse order
It's not the printers, has to be the software.
Contact your vendor for support.
Steve
Mar 04, 2008 | Zebra Stripe S600 Thermal Label Printer
Zebra S4M Thermal Label Printer Logo
1,692 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Marvin
Marvin
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
