Question about Freezers
Freezer does do not have a tight seal at the bottom
The gasket on my Whirlpool Upright Freezer (Model #EV150NXAN00)isn't getting a tight seal at the bottom. How do I fix it where it will seal or how do I replace the part?
    Sergeant:
    Champion:
  • 214 Answers
It's an easy question! ans: support your leg in the bottom part of the door and pull the top part of the door with your hand with a great force.......it will seems to be bendind. dont worry. it will just make the door parallel................have a nice day :-)
Posted on May 15, 2009
I have a frigidaire stand up freezer model #lffh21f7hw, and the door isn't vacumn sealing the door, why?
If you have too much weight in the door or someone pulled down in the door, it gets twisted. Try lifting up on the bottom outside corner of the door to straighten it up. You might have to loosen the top hinge to reseat it.
Jan 17, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
We have a frigidaire upright (ffu17m7hwd) which formed a lot of ice and we are in the midst of defrosting and don't want to experience this again. Can you assist please? Had to throw food out due to...
Freezer burn to food is caused by air & moisture in contact with it.
There should be a tight seal by the rubber gasket along all the inside edges of the freezer door. This gasket prevents unwanted hot moisture and hot air from entering the freezer compartment and causing ice build up. You can test the integrity of the rubber gasket seal by seeing how the freezer door will pinch a slip of paper in various spots around the freezer door. If the slip of paper pulls out easily, there is not a good seal at that spot. If that's the case (which I believe it is), the door gasket needs to be replaced. By the way, ice will build up over time because you need to access the food in the freezer, hence you will introduce moist air each time you open the freezer door.
Aug 28, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
My upright freezer has water coming down from top shelf and creating ice on the drawer fronts
In a case like that most likely the door gasket isn't sealing on that corner , a dollor bill placed around door then close it should have some resistiance when pulling it out, if it comes out easily the door gasket needs replacing
Gene
Aug 01, 2011 | Whirlpool Freezers
Whirlpool freezer AFG 8060 indicates red light and sounds alarm. Temp always held at -16 to -20, though now indicates only -1.
Please check : - Your door for small leak ( gasket / seals) - Temperature sensor for malfunction. A failed sensor will show wrong data.
Regards,
Dec 04, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
I have 20 cf Whirlpool model #evl202nxtn freezer,I can feel cold air from the top of the door seal.Anyway to stop this with out replacing the seal.The freezer 18 mth old.Thanks
oh wow . i have the same freezer with same exact problem. i bought it brand new. i can definately see the seal on top is not installed properly. i always thought it was only my freezer but i guess its a manufacturing issue.
Sep 24, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
I have a Whirlpool Model EV 200N Upright Freezer which is having ice freeze on the bottom of the freezer. What can I do?
If there is frost forming at the bottom to the door, your door gasket is leaking at that location. You may be able to relax gasket back in place with hair dryer, be carefull you can melt gasket. If it is sheets of ice, your defrost drain may be frozen
Aug 28, 2010 | Whirlpool 19.6 cu. ft. / 555 liter Upright...
I have a Frigedaire Upright freezer, Model says
to verify what i think could be the problem i would need the complete model number so i can recheck what i am about to tell you
the freezer has a heater where the door gasket seals itself on (not on the door behind gasket but on the freezer itself) see if you can feel if it is warm where the gasket rest on the freezer this help it get that solid air tight seal. and prevent ice build up on gasket
well this maybe one possible without being there its alittle hard to tell what else hope this was alittle helpful
Mar 13, 2010 | Freezers
Our upright freezer door will not seal tight with a vacuum anymore. The freezer fills up with snow from the air drawn in. I have defrosted it and cleaned the seal. What should I do now?
That could be one of two things, one the door is not aligned properly and more important the gasket has failed and needs replacement. The snow as you call it is ice condensed from the atmospheric air that is getting by the gasket. You may want to check the door gasket and sealing surfaces especially in the area of the "snow".
Good luck,
Gilshultz
Dec 01, 2009 | Woods 201 cu. ft. Upright Freezer V2003RW3
I have an upright freezer and replaced the rubber gasket around the door. It is not sealing correctly and ice is building up and also, water is leaking from the bottom of the door. It is a Fridigaire...
ice on top of freezer door they came out with a fix but does not work two vent holes on bottom of door seal mthem off with silicone moisture getting in if that don't work you need to take liner off and spray foam the liner cavities
Jun 29, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Freezers Logo
215 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
