Question about Admiral AW22 Top Load Washer
Admiral Washer Model# AAV7000AWW
I bought this Washer Valentines Day 2007 for my wife shortly there after we started having problems. Sometimes the machine will not fill up with water and sometimes it will but like today I was washing clothes and came back and noticed it had never filled up - can you help me its brand new and should I have bought a better washer
  • Donnmead02 Mar 21, 2008
    Admiral Washer Model AAV7000AWW,
    will not fill up in any of the 3 settings, cold-cold, warm-cold or hot-cold when starting a new load. It will however send in water if you turn knob to rinse cycle. Fills with cold water and spins. Hoses are fine, water pressure is fine, hose screens are fine. Washer is only 1 year old.
  • Anonymous Apr 20, 2008
    THE MACHINE WILL FILL & WASH & SPIN, BUT WILL NOT FILL FOR THE RINSE CYCLE
    Scholar:
  • 116 Answers
Your problem sounds like a defective water level switch, the rinse switch bypasses this switch therefore your get water whan you go to rinse.
lift the top cover, look at the front of the machine, insert a flat knife approx 4" in at each side of the seam between the front panel an the lid to release the clips, this will allow you to lift the lid, the water pressure switch is at the back (usually round with 3 wires and a small hose to the outer drum low down, ensure the small hose is connected, or with a mais tester check the output (orange/purple wire terminal 2), no mains voltage=no water, the input is grey (terminal 1) from the timer and should be live, the 3rd wire is the output telling the timer "the washer is full" (light blue terminal 3) and will be live when full.
Posted on Apr 13, 2008
My admiral AAV7000AWW washer makes a loud chattering noise and leaks water..An solutions?Thanks a bunch
Chattering could be a shaft bearing and if it got bad enough could have damaged the tub seal and makes it leak. attached is a price on parts if your interested
http://www.appliancepartspros.com/07-tub-parts-for-admiral-aav7000aww.html
Jan 07, 2012 | Whirlpool Cabrio Washing Machines
Washer makes straining noise when draining water from tub while spinning?
my admiral washer machine model AAV7000AWW makes a noise only when draining/spining water, is no water spill at all. Thanks
May 21, 2010 | Washing Machines
Willnot spin
You may have a bad lid switch.
Mar 07, 2010 | Maytag Admiral AAV7000A
AAV7000AWW washer
sounds like the thrust bearing is worn causing an imbalance on the shaft. check herehttp://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=AAV7000AWW&mfgModelNum=&fkMfgID=1:- for a schematic on this machine and parts as listed.. hope this is of some help
Oct 22, 2008 | Admiral AAV7000A
Top load washer Admiral # AAV7000AWW
I would replace the belt part # 21352320 which cost about 20 bucks. Tilt the machine back when off and empty and look for a glazed belt with maybe some cracking and wear.
Sep 01, 2008 | Admiral AAV7000A
Won't agitate
Ours did this and it was because the bearings had busted. I called a local repair guy and he told me over the phone just by listening to the sound. Maybe you could do the same. I do know this, if it is your bearings, buy a new washer. It's not worth the repair...trust me.
Jul 24, 2008 | Admiral AW22 Top Load Washer
Admiral Washer Model # aav7000aww
Look if there are any screws on timer knod side. If not, you should just pulls it straight off once. Following your description it sound like a timer issue, but it could be a loose connection to timer or inside the timer as well. Good luck!
Aug 31, 2007 | Admiral AW22 Top Load Washer
Admiral AW22 Top Load Washer Logo
1,637 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
