Question about Classic Accessories Garden
I would like to see the manual on how the mower deck is hooked up and where the cables go.the tractor works good but the deck is screwed up.
  • 1,000 Answers
I'm going to need some information.
1) What is the make of the mower.
2) What is the model number.
Regards,
Posted on May 15, 2009
Deflector installation
Where does it go the mower deck or the engine. On a John Deere rider like we have , it goes on the mower deck that is located under the tractor or mower. On the right side ( when sitting on seat) ours is on the right and it is for the bag or box attachment for clippings and or debris. A plastic cover is held on by a short rubber bungie on each side that as a hook on each end and it hooks around a small bracket to the front and a small bracket to the rear...Do you still have owners manual ?. most guys keep them in some drawer or shelf in the garage or tool shed area ...good luck...
Jun 05, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Found large spring at end of cable unattached lying on top of deck cover. Where does the spring attach in order to engage the blades on the riding mower? The lever is very loose and when checking, I found...
There are 4 pulleys on your deck. Two for the blades, these are the big ones on the outsides. To the insides there are two, one on left side is an idler and the one on the right is a tenioning pulley that hooks to the blade engage lever throught the cable you found. Look on top of this pulley and see if it has a piece sticking up. If so the spring at the end of the cable attaches here. Slide it over. You also need to find the clip that goes through the little hole in the end that keeps it from sliding off. Make sure that the cable is properly routed and attached near the back of the deck. If it is still attached, good, if not you will have to find that pin also.
If this is helpful, please rate.
Jul 10, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My craftsman lawn tractor quit while cutting heavy grass. wouldn't restart..........pushed it to the garage............ took off deck......... still woundn't start replaced battery ......... still will...
Try using jumper cables and jumping from the positive battery post to the starter lug where the main cable hooks to the starter. If you don't have jumper cables find the solenoid on the inside of the right side panel. Pull the rubber caps off and jump that with an old screw driver if the engine turns and starts on either occasion it is the solenoid. Part # 192507 sells for about $15.00 at searspartsdirect.com
Oct 08, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Broken manual clutch cable
You can go to www.Searspartsdirect.com and put you units model number in and order the cable yourself. They can ship it right to your house and you can swap the cable yourself with just simple hand tools.
You can see the details on the idler attachment in the parts schematic when you are ordering your new cable.
Good luck and be careful!
Jul 18, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I have a model 13AH762F752 MTD Lawn Tractor on the front the bar that holds up the mower deck which way should it go in.? If you are looking at the tractor from the front R or L
if the mower deck is on the ground under the tractor raise the front of the deck up and push the deck towards the front u ntil the tabs are lined up with the hooks on the deck..good luck
Apr 06, 2010 | Mtd LAWN MOWER PART # 683-04163B FRAME...
Riding lawnmower wont start
yeah i do... you need to remove the cables and hook them up the right way.. the red cable to positive post ( + ) and the black cable to the negitive post ( - )..good luck
Apr 03, 2010 | Craftsman 20 hp 42 in. Deck Yard Tractor
Where does the manual clutch cable mower deck spring connect to on a Craftsman YS4500?
It should connect on top of the idler pulley on the idler arm. The bolt is extended and the spring hooks over it with a 'hairpin' or cotter key through the hole in the end to hold it on.
Oct 09, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Need a manual for a LT1000 craftsman 19 1/2 HP 42 inch mower deck
You can download a free copy at www.managemyhome.com or you can go to www.searspartsdirect.com and buy a copy along with look at the diagram that you need.
Jul 19, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Cant find the 20 amp fuse on my husqvarna yth2148 riding mower
Find the solenoid and on the side the battery cable is hooked to is another smaller red wire that has the inline fuse on it.
Jun 07, 2009 | Husqvarna 23 Hp 48" Deck Yard Tractor
How do you remove the mower deck from a craftsman riding lawn mower
Most of these have a cable to pull deck into gear, which has a r clip to remove ,than two rods that go from font of deck towards front axle- remove 2 R clips to drop them, and 2 more at the back of deck, un hook belt around engine pulley, than slide deck out. See how this goes. Or you my have dune it by now.
Dec 15, 2008 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garden Logo
52 people viewed this question
Top Classic Accessories Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Classic Accessories Garden Expert? Answer questions, earn points and help others
