Question about Garmin NUVI 360 GPS Receiver
Your Problem: I have a nuvi 360, when I power it on, it boots up and accepts my unlock code. When I try to "view map" or type in a destination, it reads "acquiring satellites" for several minutes. It
I have a nuvi 360, when I power it on, it boots up and accepts my unlock code. When I try to "view map" or type in a destination, it reads "acquiring satellites" for several minutes. It then reads "trouble tracking satellites" and asks "are you indoors now?", I tried this start up outdoors and will not locate satellites. It then asks if I've travelled hundreds of miles since last use (I have not). Asks for the present date which is o.k..... Still nothing, I'm getting angry ! :-( I have NEVER updated the maps or "firmware". I am not very computer literate, but I seem to get by. Map updates really haven't been on my priority list, so I haven't done so. I've tried using the reset button on the back under the antenna- still nothing. Just a few weeks back it had this same problem but it was intermittant and worked the last time I used it. Any help would be very much appreciated. I think I will have to go back to paper maps for my trip to Montreal tomorrow morning. Thank you, M.F.
  • Garmin Master
  • 2,130 Answers
Please see this link:
http://www.sharc.net/gps_antenna_repair.htm
- Jim
Posted on Mar 01, 2010
My gps says "no
Question: What should I do if my Garmin nuvi or zumo displays the message "No Detailed Maps Found That Support Routing" or "No Map Data Available?"
--> Answer: The "No Detailed Maps Found That Support Routing" or "No Map Data Available" message may appear on your device for the following reasons:
  • The GPS device is missing it's unlock code
  • The maps on the GPS device have been disabled
To determine the cause of the message, touch the screen until the message "No Detailed Maps Found That Support Routing" disappears.
  • If you see a "Can't Unlock Maps" message following this error, remove any microSD / SD cards in the device and follow the instructions below for Retrieving your unlock codes followed by the instructions for Creating an unlock file
  • If you do not get the Can't Unlock Maps message then skip to the instructions for Enabling maps on the GPS device
Retrieving your unlock codes:
  1. Log into your myGarmin account
  2. Select Manage Maps
  3. Select Details
  4. The unlock code is located under the Installed Maps.
Nov 16, 2010 | Garmin Nuvi 360 Bilingual GPS Navigator...
My garmin nuvi 205 keeps telling my " No detailed maps found that support routing. The nuvi cannot be used without them."
The "No Detailed Maps Found That Support Routing" message may appear on your device for the following reasons:
  • If you do not get the Can't Unlock Maps message then skip to the instructions for Enabling maps on the GPS device at the bottom of this solution
To retrieve your unlock codes you must first register your satnav if you haven’t already done so.
To registe;
  • · Connect the satnav to your computer.
  • · Click on “myGarmin”
  • · Click on “Register Your Garmin Product” and follow the prompts
You’ll be asked to create a username and password. Write them down and keep them safe as you’ll need them anytime you want to update your maps.
  3. Select Details
Creating an unlock code file for PC:
  1. Plug your Garmin device into the USB port
  2. Double-Click on My Computer or Computer located on the desktop
  3. Right-Click on the Garmin or nuvi drive
  4. Click Explore
  5. Double-Click on the Garmin folder
  6. Right-Click in a blank space in this window
  7. Move your mouse over the word New
  8. Select Text Document
  9. Press Enter / Return on your keyboard
  10. Double-Click on the New Text Document. This will open the New Text Document in a window called Notepad
  11. Type the unlock code that is listed in the Manage Maps section of your myGarmin account in all upper-case letters with no spaces
  12. Select File
  13. Select Save As
  14. Change the Save As Type to All Files
  15. Type gmapprom.unl in all lower-case letters for the File name
  16. Select Save
  17. Close the Notepad window
  18. Delete the New Text Document file
  19. Disconnect the GPS device from your computer
Enabling maps on the GPS device:
  1. Touch the wrench icon on the Where to/View map screen
  2. Touch Settings
  3. Touch Map
  4. Touch Map Info
  5. Select the checkbox next to the maps to be enabled on the device
Aug 13, 2010 | Garmin nuvi 205 GPS Receiver
Hello, I have a Nuvi205w...it was working fine this morning and now it is showing on the screen the following message...no detailed maps found that support routing. The nuvi cannot be used without them. Is...
To get your unlock codes you must have registered your satnav. If you haven't already done so you can by connecting your satnav to your computer. Go to www.garmin.com Click on myGarmin and then on Register Your Garmin Product. You'll have to create a username and password to register. Note them down and keep them safe as you'll need them anytime you want to update maps.
  3. Select Details
  4. Click Explore
  12. Select File
  13. Select Save As
  16. Select Save
Creating an unlock code file for Mac:
  1. Open the TextEdit application located in the Applications folder on the Mac HD
  2. Click Format
  3. Select Make Plain Text
  4. Type in the unlock code that you retrieved from your mygarmin account. The unlock code should be in all capital letters and with no dashes.
  5. Click Save As and name the file as gmapprom.unl (Note: Be sure to uncheck the box If no extension is provided, use .txt)
  6. Copy the gmapprom.unl file to the GARMIN folder on your device. (Note: Save the file directly to the Garmin mass-storage device if connected)
If you have a second map on your satnav e.g. if USA is your main map and you purchased a map of Europe which you need to unlock also
  4. Click Explore
  11. Type the European unlock code that is listed in the Manage Maps section of your myGarmin account. This will need to be typed in all upper-case letters with no spaces
  12. Select File
  13. Select Save As
  15. Type gmapprom1.unl in all lower-case letters for the File name
  16. Select Save
  2. Touch Settings
  3. Touch Map
  4. Touch Map Info
Aug 10, 2010 | Garmin Nuvi 360 Bilingual GPS Navigator...
My GPS says " no detailed maps found that support routing. The Nuvi cannot be used without them." Tried resetting and no change
To retrieve unlock codes you need to have your satnav registered with garmin. If you haven't already registered it connect the satnav to your computer and go to https://my.garmin.com/mygarmin/customers/myGarminHome.faces and click Register your garmin device. Follow the prompts. You'll be asked to create a username and password. Write them down and keep them safe. You'll need them anytime you need to update your maps or solve problems in the future.
  3. Select Details
  4. Click Explore
  12. Select File
  13. Select Save As
  16. Select Save
  2. Click Format
*nuvi x70 owners with transatlantic mapping will need to follow the Creating an unlock code file instructions above for their U.S. mapping and then create another unlock file for their European maps:
  4. Click Explore
  12. Select File
  13. Select Save As
  16. Select Save
  2. Touch Settings
  3. Touch Map
  4. Touch Map Info
Aug 10, 2010 | Garmin nuvi 205W GPS Receiver
I tried downloading a map update for a brand new garmin nuvi 1300 and now it says cannot unlock maps and doesn't work. Any quick fix?
These are the instructions for unlocking maps from the Garmin website:
  1. Log into your myGarmin account1
  2. Select myMaps
  3. Click Manage Maps and Downloads
  4. Below the appropriate device, select the "Details" link
  5. Look for the Unlock Code listed on this page
  6. Copy all the unlock codes for your device
  7. Close your internet browser
  8. Right click on your desktop
  9. Click new, and then click Text Document
  10. Click on the newly created Text Document icon from the desktop
  11. Type your unlock codes into the document
  12. Click File and Save as
  13. Change the file name to gmapprom.unl
  14. Change the “Save as type” to "All files"
  15. Close the document you should see the file gmapprom.unl on your desktop)
  16. Right click on the gmapprom.unl file and then click copy
  17. Connect your Garmin device to your computer and click Computer/My Computer
  18. Click on the 'nüvi (drive letter:)'2
  19. Right click on the Garmin folder and click paste (see next line for nuvi 1xxx series)
  20. For nuvi 1xxx series devices, the gmapprom.unl file is required in the ".System", "Garmin" folder which is a hidden system folder. In order for you to see the hidden system folder:
    • For XP:
      1. In MyComputer go to the Tools menu and choose Folder Options...
      2. Select the View tab
      3. Select the radio button next to "Show hidden files and folders"
      4. Uncheck the box next to "Hide protected operating system files (Recommended)"
      5. Click OK
    • On Vista:
      1. In the Computer window go to the Organize menu and choose "Folder and search options"
      3. Select the radio button next to "Show hidden files, folders, or drives"
      5. Click Ok
Safely disconnect your Garmin device from the computer to complete the process. If you are having any issues duplicating the steps above or are still receiving the message "Can't unlock maps, your unit will not function without maps” please contact Product Support.
1 The device must be registered to view the Unlock Code.
2 In My Computer, some units may be labeled 'garmin (drive letter:)'.
Aug 07, 2010 | Garmin nuvi 1300 Car GPS Receiver
My garmin nuvi 360 goes in simulated driving mode
if you recently plotted a course and used the simulation mode, it will stay there either till you deactivate it, or you arrive at the destination. go to the simulation mode and see if its in simulation, if so, stop it.
Aug 06, 2009 | GPS
Garmin nuvi 360 wont unlock maps
Master reset is after you turn on the GPS put a finger on the left lower corner rightaway and then keep the finger there, wait until it shows up the "Do you really want to start up in maintainance mode"
You are not able to use others nuvi's map on your nuvi 360, as each map must match with the GPS unit ID, to find out your GPS's unit ID, go to "Setting" tab on "System", tab on " About"
Mar 29, 2009 | Garmin NUVI 360 GPS Receiver
My Garmin nuvi says ''maps unavailable''
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The "No Detailed Maps Found That Support Routing" message may appear for the following reasons:
  2. Select myMaps
  3. Select Manage Maps
  4. Select the device from the drop down menu
  5. The unlock code is located under the "Maps installed on this device" section
    /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Enabling maps on the GPS device:
    2. Touch Settings
    3. Touch Map
    4. Touch Map Info
Mar 21, 2009 | Garmin nuvi 260W GPS Receiver
Screen with message.. " No detailed maps found that support routi
This error is caused by a corrupt or missing map unlock code. Please email me @ sharcnet-usa@sharc.net and I will talk you through on how to fix the problem.
- Jim
SHARCNET-USA
Feb 06, 2009 | Garmin nuvi 350 GPS Receiver
Garmin Nuvi 360 Won't Load Maps
go buy a tom tom you dont havve to do any downloads to keep it up to date.garmin has to many issues
Aug 13, 2008 | Garmin nuvi 350 GPS Receiver
Garmin NUVI 360 GPS Receiver Logo
102 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
