Question about Frigidaire 20 cu. ft. / 566 liter Chest Freezer FFC20C4A
Motor makes noise and not sure if it is using a lot of electricity
I was given a freezer and it is a frigidaire Citation twenty freezer. The motor constantly makes a noise as it is on. It keeps the temperature at 0. Should I be worried about the noise and the amount of electricity it is using.
    Sergeant:
    Champion:
  • 214 Answers
It's normal. because due to running of compressor and motor this type of sound is developed...............have a nice day :-)
Posted on May 15, 2009
Frigidaire upright freezer
Make sure the unit is not plugged into a GFCI outlet...
Jun 26, 2016 | Frigidaire Freezers
I have an 11 cf upright freezer. it has been running most of the time or at least make a noise. and I just defrosted it. and its still doing the same thing. any comments?
Good Afternoon friend, thank you for your post!
I see that your Frigidaire freezer is making noise and you have recently defrosted it, but your freezer is still making the noise. Your freezer will make certain noises which are normal operating noises for the freezer.
The compressor is a high efficiency so you may hear it during start up and while running. Additionally, refrigerant circulating through your freezer can make a tapping sound or even a gurgling noise. I hope this has been helpful. -Matt
Sep 26, 2014 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freezer makes really loud noise
You need someone to check the fans and where the noise is coming from before the repair cost you a lot of money because of damage it can cause. The fan may be hitting ice in the freezer or out of balance because it is worn out. No one can hear what you hear and someone will need to be there to check these things out, Sea Breeze
Jun 10, 2013 | Frigidaire Freezers
Frigidaire freezer making noises
evaporator is probably frozen up
Apr 23, 2012 | Frigidaire Freezers
I have had my freezer for a couple of years and probably only used it 6 times. The motor makles a roaring noise and sparks are coming out of it? Any idea what it might be. I checke the price of a new...
My 6 qt electric was making noise and finally quit spinning. I pulled it apart and the change gear (gear reducer) was wallowed out. This meant the gear rocked away from the motor's drive gear. I called White Mountain to see if I could get a replacement gear and they said I'd voided the warranty because I took the 3 screws out to pull apart. Basically, they are using **** gears, know it, and doing the song and dance to not have to replace. So, I've got a motor that works, housing, and one bad gear that makes the whole unit worthless.
Aug 10, 2011 | White Mountain Freezer F69206-X 6 quart...
We accidentally left our upright 20 cf frigidaire freezer door open for 24 hrs, all the food spoiled and now the freezer is not freezing and only cooling. Any ideas of what is wrong? thanks
THE UINT IS FROZE UP, YOU WILL NEED TO DEFROST IT. USE A FAN TO BLOW INTO THE FREEZER PORTION , AND HAVE LOTS OF BIG THIRSTY TOWELS HANDY .. THIS WILL TAKE ABOUT 2 HOURS TO DEFROST, WIPE EVERY THING INSIDE THE UNIT DRY !... JAY THE POOL PUMP MOTOR REPAIR GUY FLORIDA
Jul 28, 2011 | Frigidaire 20 cu. ft. / 566 liter Upright...
Freezer motor running nonstop
Behind the back panel you will find the freezer fan motor. unplug and take everything out. take the back panel off and find the fan. stick something in the blade like a bannana or whatever (no rags or paper towels though) just something to jam the blade (its plastic so dont break it) replug. remove whatever you put to jam the blade and if you hear the sound then you know for sure it is the fan. got to replace fan if you want the noise to stop
if it is not the fan let me know
hope this helped
Apr 01, 2010 | Frigidaire 13.7 cu. ft. / 388 liter...
HELP! Frigidaire Fridge FRS26HF7BB0 losing coldness and buzzing
That noise is typical when the compresor is trying to start but it doesn't , it could be the condensing fan motor that doesn't work and the compresor goes off on overload ; a common problem with this compresors is the relay (mounted at the side of the compresor behind a black plastic cover) goes bad , this you can replace is about $20 , and if still the compresor won't start you will need to put another one and this is an expensive job.
Aug 02, 2009 | Frigidaire Freezers
Lubricant in gear case electric motor drive
Perhaps there's been some problems with the White Mountain machines since the company was bought out by Rival, the company that makes the cheap *** 30 dollar freezer machines. We have had great success using them to make lots of home mead ice cream and the last time I took the transmission apart, ours had a "dab" of grease in there. I cleaned everything out and used Mobile 1 red synthetic wheel bearing grease. Not filling it full of grease mind you, but using a q tip and making sure all moving parts had lube. As to why yours didn't have any on it, can't help you there unles it had been used so much that it was all gone, but a ne wmachine?; that's a problem. Their warranty dept will give you a new motor within the first 5 years of ownership if you can send them a copy of the recelipt and $10 for shipping. they don't even want the old motor unit back!!!
Good luck
Max
Dec 24, 2008 | White Mountain Freezer F69206-X 6 quart...
Freezer motor has burning smell
disconnect from mains. take cover off compressor electrics. check starting device - easy to replace
Aug 09, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Frigidaire 20 cu. ft. / 566 liter Chest Freezer FFC20C4A Logo
268 people viewed this question
Top Frigidaire Freezers Experts
AJMAL KHAN
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
