Question about Zebra LP 2844-Z Thermal Label Printer
My Zebra LP-2844-Z won't print, says spooling, printing, deleting
I can't figure out how to get this printer to work. I try to print a test page and for awhile it would just give an error, now it says spooling, then printing, then "deleting-printing-printed". Ugh! I have the feeling there may be a cable problem. I have a serial-USB adapter connected to the cord that came with the computer b/c it doesn't fit in any of my ports. I'm just not tech knowledgeable to solve this on my own. Help please!
  • abcrossman May 15, 2009
    Tried it but no luck. Thanks for the response, but any other ideas?
Try this--open the control panel then open system & maint then admin tools. open services then find the print spooler svc and right click then restart. close all jobs and print windows first then try again
Posted on May 15, 2009
Please use a generic windows driver available from the two software providers below, NiceLabel Driver (Generic Windows Driver for Zebra Printers) Seagull Scientific Driver (Generic Windows Driver for Zebra Printers)
Posted on Jul 15, 2010
On the Advanced tab of the driver, select Print Processor. Change it to WinPrint and select RAW. Should fix the issue.
Posted on Aug 27, 2009
2 Suggested Answers
SOURCE: Zebra LP 2844 prints blanks
In addition to jigeo solution you need to know this, the little taken- sense button must be in the off position before this procedure works. You can then return it to the on position.
Posted on Sep 08, 2008
Zebra LP 2844 Thermal Printer, keeps staling
try to reset to favtory default and do a test print, download if needed other driver (www.seagullscientific.com.) reset to factory default with this driver and try a test page. Hope it helps. Paulo.
May 01, 2014 | Zebra LP 2844 Thermal Printer
I have a pending print job in my thermal printer and it won't print. I can't delete it from the que
Go to the Start run window and type Net Stop Spooler and press return and then do teh same and type Net Start Spooler after doing this try and redelete the job, if this fails do another Net Stop Spooler then navigate to C:\WINDOWS\System32\spool\PRINTERS and delete all the files in this folder then do a net start spooler all jobs should now be gone, Be aware that option 2 will delete all spooler jobs, so if this is a shared printer or server that these jobs will be lost
May 11, 2011 | Zebra LP 2844 Thermal Printer
I cant get the printer to print either from the computer or when I run a configuration set for the tag on the printer...any idea why it would quit printing?
make sure no documents are stuck waiting to be printed if so delete them. then right click and hit pint test page. if prints you are good. If not delete the printer and plug it in a a different usb port
Dec 23, 2010 | Zebra LP 2844 Thermal Printer
Zebra lp 2844 prints a blank test page
possible was reset to factory defult and the darkness is to low, press the button until flash 5 times and let run untill see the dark print. then press the buton again. Try to print again (flash 1x)
outher possibility is the ribbon in on other way.
other possibility is the labels need to use ribbon (Thermal Transfer), and the printer is run out from ribbon.(run as Direct Termal.
Aug 17, 2010 | Zebra LP 2844-Z Thermal Label Printer
Zebra LP 2844 Printer Error, Cannot Print
Try this
START
SETTINGS
PRINTER/FAXES
in the pop up window go to
FILE/SERVER PROPERTIES
DRIVERS
SELECT THE MFC5440 DRIVER AND REMOVE
SELEST THE LP 2844 DRIVER AND REMOVE
Now go to www.seagullscientific.com and download the Zebra driver pack, once downloaded run it and install the Zebra Lp2844 to with the USb port.
This should solve the problem, if not please come back.
trevor
Feb 15, 2010 | Zebra LP 2844 Thermal Printer
Zebra LP 2844 printer will not print anything but the test page
possibly not a real LP2844 but an LP2543, a printer mass produced for and used by UPS. refurbishers change the label and sell as LP2844 because they are almost identical.
if it has an AC-AC adapter, it is an LP2543. LP2844 uses a AC-DC adapter, and all LP2844's have USB ports.
Mar 24, 2009 | Zebra LP 2844 Thermal Printer
Zebra TLP 2844-Z Test page print within Win XP
This printer requires special software to print labels with. It uses a unique PCL language to work with. Thats why when you use these printers with Fedex or UPS software, it typically downloads forms first before working.
Zebra used to see a label designer program to work with it. You might want to check with them to see if they still carry it.
Jul 28, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Zebra LP 2844 fuzzy print
1. Clean the print head with cleaning pen.
2. Adjust print speed/darkness in software.
3. Check the media and verify that print surface is facing up.
4. Check that correct thermal media is in use.
Apr 23, 2008 | Zebra LP 2844 Thermal Printer
Open Questions:
See all Zebra LP 2844-Z Thermal Label Printer Questions
Zebra LP 2844-Z Thermal Label Printer Logo
3,082 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
