Question about Kenmore Microwave Ovens
The door opener sticks and hangs up
The door opening mechanism om moel #56566801690 requires multiple attempts and excessive force to open the door
MicrowaveSvc
  • 9047 Answers
SOURCE: the door sticks on my microwave oven
Usually this is due to loosened mounts inside the oven. The mounts hold the door switches and grab the door hooks when it the door is closed. The solution is to realign and tighten the mount screws inside. It's less liekly, but it could be a weak or worn door open lever inside. I only advise people to work on a microwave if they're fully informed and aware of the deadly hazards and necessary precautions.
Posted on Sep 15, 2006
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave works with door open
If the top is open, the upper door switch should be open and the high voltage section should not be energized. That's the way it's *supposed* to work. But that buzzing is worrysome! Does the turntable turn during this condition? Does the inside light come on? How about the fan? If not, then I would doubt that it's cooking. If so, some models will do this. It's not uncommon to notice that the fan and light will try to come on for a split second when you shut the door. This would not indicate a problem. It has to do with the timing of the door switches and a replay on the board. If it's still under full warranty, it wouldn't hurt to call a GE-authorized servicer.
Posted on Nov 07, 2006
MicrowaveSvc
  • 9047 Answers
SOURCE: Broken Microwaive Door
I'm assuming your correct model number is KCMS145JSS? You have a broken "release lever", part number AP3033332. It's reference number 7 on the exploded view diagram found here: http://www.appliancepartspros.com/sect/4/g/4/4g4rya32jj.gif You can order it by part number from Appliance Parts Pros here: http://tinyurl.com/gv383 If needed, you can download the owner's manual and installation guide here: http://www.kitchenaid.com/custserv/literature_search_results.jsp?searchTerm=kcms145jss If you need further help, please follow up. I appreciate your rating of this answer.
Posted on Nov 18, 2006
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave Comes on when Door is Opened
It sounds like a problem with the door switch or mount or the control panel. I've attached an exploded view of the oven which shows the door switches and mount. They're located behind where the door hooks go into the chassis. You can find our safety and disassembly instructions at our site via my link here: http://tinyurl.com/yzjozk If it's not switch-related, then you may have a shorted component on the control board. We repair these for customers nationwide for $32.50 postpaid in most cases.
Posted on Jan 21, 2007
  • 10 Answers
SOURCE: door won't open
Im sorry to say, but the housing will have to come off to unlatch the door from the inside.Not difficult ,Unplug the unit and remove all of the screws around the top of the housing cover if any,also
rear and both sides will have to come out.When they have all been removed, lift the rear of the top housing cover and pull back.You will be able to see where the two door latches are locked in place.With a screwdriver,you can push up on the bottom latch and the door will open. All this can be done without spilling the milk inside.Just slide the microwave around slowly to get to the screws.The broken part inside should be able to be replaced.Contact repair parts center.
Posted on Nov 06, 2007
Door stuck shut. Pushbutton does not work. How can I get the door open for repair?
Jo. you may have to remove the hole cover, to access inner latch mechanism, where you can manipulate the latch with long screw driver.*** before attempting this, unplug microwave for an hour***
press the helpful button. link below may help...
Microwave Door Won Open
Jan 25, 2016 | Microwave Ovens
Rival rgst902 microwave. Door won't open.
verify that door is perfectly aligned with frame edge , sometimes in busy kitchens the door gets bumped and it no longer aligns with frame , if one forces it shut the mild spring that pops it open cant overcome the friction of frame hitting and it wont open requiring one to "HELP" it to open while holding down open button , look at latch carefully when open to see if any parts look bent or "not quite right "
Sep 17, 2015 | Rival Microwave Ovens
Door release buton does not open the door
You can disassemble the microwave oven and check out the release mechanism. You'll find several hooks that hold the door closed and a linkage mechanism to the door opening button. There may be a broken piece of plastic or maybe just a loose or missing screw that holds linkage together. In the case of a broken plastic part, you can fix it with a 2-part epoxy adhesive, but you'll need to permanently splint across the break with a piece of metal or strong plastic that you've scavenged from somewhere. Before epoxying the splint in place, rough up all plastic surfaces where you want the epoxy to stick well.
Good luck.
Mar 16, 2015 | Panasonic Microwave Ovens
Door hard open
It sounds like the hinges are worn out or broken. Probably cheaper to buy a new one that to fix the old one.
Oct 15, 2014 | GE Advantium 120 Convection/Microwave Oven
Why woll sharp R-530E microwave not turn off when door opens.
It is very dangerous, you're filling the room with radiation, may be best to just dump that one, unless you are a little bit competant with mechanical stuff, in which case it's probably the sensor on the door not registering that it is open,. might be a physical thing, i.e. moved a little. or maybe a electronic thing, requiring a new sensor itself.
Sep 04, 2014 | Sharp R-530ES Microwave Oven
I have a Sharp Microwave Carousel R-420B. I put a bowl of soup in , closed the door, pressed Minute Plus, and hit Stop with approx 20 seconds to go... pressed the door release but nothing happened... door...
Usually, the door lever or hinges is the cause of this type of problem.
But in this case, I don't think the door lever or hinge is the cause of your problem.
I think the door is jammed and only needs some force before is can open or unjam.
Use your hands or a flat Philips screw driver to forcefully open the door. Don't apply too much force. Just apply a reason amount of force that could open the oven door.
Before you attempt to forcefully open the microwave door, leave it for about 45mins to 1hr, after that forcefully open the door.
If the above doesn't help to open the door, please let me know so that I can direct you further.
I wish you good luck.
Regards.
Mine does this occasionally, and it's because the door hinges have got a bit out of line, allowing the door to drop slightly, so the catch mechanism won't quite disengage.
Look along the bottom edge of the door and see if it has dropped lower than the front panel next to it. Try applying a bit of upward pressure on the bottom edge with your fingers, while pulling towards you at the same time, and with your other hand press the release button.
If that gets it open, remove last night's failed meal, open the door fully and carefully force it up a bit at a time, to bend the hinges back to level - keep pushing the door back so it nearly closes, and look at the bottom edge to check on progress. When the bottom of the door looks level with the panel , try closing it fully and see if the release button will open it again.
Jun 03, 2011 | Sharp R420L Microwave Oven
Hello My name is Mohamed. I have a sharp microwave oven model R-316FSU, I am having trouble opening the door. The latch seems to stick. How can I fix it?
Door catches.
One of the latches may be damaged or misaligned and is not lifting the other latch clear of the housing. Remove from any power source, remove the cover of the cabinet. Slacken off the clamp mechanism and ease the clamp over the guide to allow the door to open. When the door levers are in place, the door may be easily adjusted by slackening off the screws that clamp the door catch/actuators in place whilst holding the door closed and then tightening the screws. The rear of the door may be adjusted by slackening the lower door hinge screws and adjusting as required.
I hope that helps.
Mar 21, 2011 | Sharp R-316FS Microwave Oven
I cannot open the door of my Panasonic NN-T543W microwave
Well do not pry the door open since there is an easier remedy which will lead you in the direction that you need to fix your problem. Take the cover off after you disconnect the power to it. Once you have taken the cover off (only a few screws) you will be able to see the two latches that hold the door closed and the link that opens both of them. You can just lift both latches at the same time and it will open. After you have done that take a good look and press in on the open door button and you will see where you have the problem of the door hanging. That button should push a linkage that pushes up on both latches at once to open the door. It is spring loaded so that it comes back down so that when you close the door it will hold the door closed. Anyway that is where your problem is. Let me know if you need more hlep.
Feb 09, 2009 | Panasonic NN-S251 Microwave Oven
Microwave Ovens Logo
32 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
