Question about Panasonic Audio Players & Recorders
Old Panasonic Shelf System (w/ turntable) plays records too slow.
So I picked up a Panasonic SG-HM09 shelf system at a thrift store for ten bucks. Seemed like a great deal, appeared to work in the store, but I was testing it with an unfamiliar record. As soon as I got it set up at home, and put side B of Abbey Road on, I immediately realized that the 33 rpm setting is too slow.
Now, this is an old crappy shelf system. The platter is plastic, the arm is plastic. I tried to lift up the platter, but it really didn't like that and seems to not be able to come up. I got a peek underneath, and it appears that this isn't a belt drive turntable, although what that makes it I'm not sure. Direct drive? Idler wheel? Dunno, there seemed to be some plastic gears in there, if that helps.
If anyone could shed some light on how to get this thing up to speed (literally) that'd be awesome.
I have the exact same player and it does the same thing.. I guess no one knows how to fix this.
Posted on Dec 20, 2015
3 Suggested Answers
  • 4234 Answers
SOURCE: Fisher Studio-Standard Belt-drive Semi-Automatic Turntable MT-32
Most likely the grease in the whole system has started to stiffen or the motor is failing. This can be fixed. Try oiling the motor first. If that fails, I'd look at the motor driver IC as the most likely failing part.
Dan
Posted on May 23, 2008
  • 105 Answers
SOURCE: rca record player is playing slowed down or sped up
Hi there
this sounds like the belt that drives the turntable itself is slipping you can normally access it by removing the securing clip by the centre spindle and then lift the turntable up and you should be able to see the belt give the belt a good clean with isopropyl alcohol refit and hey presto (if you still get slippage order a replacement belt )
Rgards Al "Alstech "
Posted on May 26, 2009
Electro Brand model number 9801: I played one record, now when I tried to play another the turntable will not rotate. Could the motor have burned out that easily?
Listen carefully with your ear to the turntable when you move the tone arm towards the record. If you can hear the motor running and the turntable is still stationary then the drive belt from motor to turntable has probably fallen off of broken. Lift the turntable, there's normally a metal clip holding the turntable in place, and locate the drive belt.
Jan 19, 2014 | Teac GF-350 CD Shelf System
Need capstan band on turntable...old one broke so turntable will not around
Take the broken one to a hardware store and check the o-rings. You just might find one the right size.
Jul 02, 2012 | RCA Lawton Turntable with Analog Radio/CD...
Kaito ka1916 turntable operates at very low speeds
The turntable motor is bad or the B+ is to low
May 16, 2012 | Kaito KA1916 Shelf System
Turntable will not rotate when in "Phono" mode
I recently was given my Father's CR78CD and, assuming your unit is in working order, you turn on the turntable motor by lifting the tonearm off the post and moving it away from the turntable about one and a half to two inches. You should hear a soft click as the switch for the motor activates.
Jun 20, 2010 | Crosley CR78CD-P CD Shelf System
Is it possible to connect my panasonic sg-hm22 to my Denon Reciev
You need an "Audio Output" ie. Tape 2 mon or Rec out (RCA jack) on the Panasonic for it to work. Hope this helps
Jun 22, 2009 | Panasonic Audio Players & Recorders
Rca record player is playing slowed down or sped up
Hi there
May 26, 2009 | RCA 200-Watt 5-CD Compact System Model...
Turntable speed
There is no pitch control on this unit.
Apr 03, 2009 | Intellitouch Communications INTELLITOUCH...
No sound from my SCEH790 system from turntable...
Hi...
The aux wont work on a TT . You need a turntable pre-amp. Then you can plug it into the aux jacks.
Try partsexpress.com or mcmelectronics.com
Jan 11, 2009 | Technics SCEH790 CD Shelf System
PANASONIC COMPACT AUDIO SYSTEM MODEL #SG-HM22 help
some models have a hole(s) in the turntable under the mat. You can put your fingers through the holes in the turntable to fix the belt into position. Good Luck.
Oct 28, 2007 | Audio Players & Recorders
626 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
