Question about Cycling
Assembly intructions for 2004 Raleigh Chopper mk3 bicycle. How to put on handle bars. How to assemble front brakes.
  • 161 Answers
SOURCE: Brake assembly
if this is what I'm thinking of you have to pull the little knob at the end of the cable out a little with pliers so that some of the cable is exposed and then it shoud fit in the pull handle
Posted on Mar 19, 2009
If you loosen the wire that is connected to the gripping machanism first , you will have long enough wire to put it throu the brake grip first then tighten it back at the wheel gripping area.
Posted on Apr 10, 2009
  • 864 Answers
I did no find assembly instructions specific to this model.  From what I see in pictures and descriptions it looks like a standard caliper brake on the front wheel.  The knob/plug on the cable should fit into a groove and hole on the brake lever if the cable is slack enough to make the connection.  You may have to loosen the cable tension nuts at the caliper and at the brake handle (labeled 1 & 2 in the instructions) to get enough slack.
Generic instructions are at: http://www.huffy.com/resources/pdfs/multispeed_manual.pdf
See pages 21-23 for instructions about adjusting the brakes.  You will have to do this after making the connection and it shows the various cable tension nuts that you can use to get enough slack in the cable to connect it.  If you loosen the cable tension nuts (1&2) enough you should be able to remove the cable from the slot through the housing, expose the attachment slot in the brake handle by pressing it against the handlebar, insert the knob/plug into the hole and then work the cable back into the slot in the housing.  Tighten up the tension nuts and make the final adjustments as described in the instructions.
Posted on May 28, 2009
cogdoc
  • 7 Answers
SOURCE: how to raise the handle bar in huffy 14
The silver bolt on the neck behind the handlebars. Losen it off a few turns, and the entire stem can be raised and lowered. Be sure not to raise it too much, should be a minimum mark, or else leave a good inch or two still in the frame, and tighten it back up. Make sure it's aligned with the front wheel though!
Posted on Jul 01, 2009
  • 8 Answers
SOURCE: instep bike trailer assembly
This is the manual for the model that you have. Pictures included. http://www.instep.net/productInstepPDFFiles/168pdf-1pdf
Posted on May 25, 2010
How to remove handle bars on Raleigh 3.0
See if this manual works for your bike:
http://www.raleighusa.com/wp-content/uploads/2009/02/09_ra_ownersmanual_lores.pdf
Jan 05, 2013 | Raleigh Venture 3.0 20" Mens
Front brakes bicycle
There is a nut dead center on the front of the brake caliper. loosen that and adjust it left or right a pinch and tighten back down while holding it in position.
Sep 04, 2012 | Raleigh Cycling
We purchased a Radio Flyer Stroll and Go but during assembly the front wheel was put on but was put on 90 degrees the wrong way. We are not able to get the wheel off so we can correct the wheel.
Where you inserted the handle bars into the bearing assembly on the frame there is a fork clamp you had to tighten to secure the handle bars and front fork. Loosen this and you should be able to disassemble the front end. While reassembling be sure the you line up the notches on the fork with the grooves in the bearing assembly and that the handle bars are properly aligned before tightening the fork clamp.
Apr 03, 2011 | Cycling
Instep bike trailer assembly
May 25, 2010 | InSTEP EZ Bike Trailer
Brake assembly
May 28, 2009 | Huffy Disney Princess 16 in. Girls Bicycle
Brake assembly
Dec 01, 2008 | Huffy Disney Princess 16 in. Girls Bicycle
Cycling Logo
278 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
