Question about Cooktops
Light sill not go off, and eye stays very hot. Must cut off at breaker
The large eye remains on at all times and the light will not go off. We have to cut the breaker off to get the burner to go off. Have changed out the burner, and the plug for the eye.
    President:
  • 1,136 Answers
Hi, You will need to change the switch for that eye. If you give me the model#, I can help you with part#.
THanks
Vic
Posted on May 15, 2009
My left front burner was turned off for almost half hour but remained hot. the hot surface light was still lit. I had to throw my main breaker to turn it off. What could be my problem
Sounds like the thermostat on that burner gas gone. When you switched the breaker back on, did the burner get warm after being cold? If so, you need a new controller. They are easy to change if you can get to the back of the unit. Make sure you turn off the breaker and physically remove the plug.
Nov 24, 2013 | Whirlpool RCC3024 Electric Cooktop
Large burner elements ignite, and igniter spark fails to stop, then the burner shuts off as if ignition failed. Tiny central burner element does NOT light at any time. Apparently the safety cutoff...
There is a thermistor that must be in the flame area that needs to get hot. When hot it will turn the igniter off and keep the flame on. Check it's location and if it is in the flame then it needs to be replaced. not sure about the central flame problem. could be the switch.
Sep 20, 2010 | Gaggenau 36 in. KG 291 Dual (Electric &...
Large element stopped working/that hot surface light stays on
I have the same problem with mine. Do you have any answer yet?
Jul 20, 2010 | GE 30 in. Profile JP938SCSS Electric...
Large eye thermostat is not working. Heat stays
Hello JBlum, Yes, most stove top elements, including those with the thermo sensors, are replaceable. Without the model number, I can't steer you towards the exact part number, but you can look it up yourself at www.searspartsdirect.com
Just enter in the full model number of your GE range and it will bring up all the line drawings and parts lists for it. You can either order the parts from Sears, or use any other supplier you wish.
Just remember to disconnect the range from the wall outlet before you undertake any repairs or attempt to replace any parts, so you'll be safe.
Hope you find this Very Helpful and best regards!
Dec 10, 2009 | GE Cooktops
I have a neff T1.D20 dual circuit hotplate but although the inner lights up and gets hot the outer part doesnt. Is the outer part supposed to?
I have a T172 model which also has a dual circuit hotplate.
In the control area you should find a dual circuit control pad - this has two concentric circles on it. With the hob switched on, pressing this button will chnage the mode of the dual circuit hot plate bewteen:
1. Just the inner part
2. Both the inner and outer together.
When the hob is switched off using the Standby control pad, it remembers which mode was selected and will therefore work the same next time it is switched on. However, it is worth noteing that when the mains power to the hob is interuppted, either by an isolator switch/breaker, or a power cut, the hob defaults back to just the inner ring mode.
Oct 03, 2009 | Neff T1323 Electric Cooktop
Right front (large) burner indicates hot, won't work, flashes F153
I hade a code 153 also. Changed the element(costly-$200) and had to recalibrate the pan sensors(in the manual). All works fine now.
May 21, 2009 | GE Cooktops
Viking professional induction cooktop large burners defective
Throw your circuit breaker that leads to this unit for a few seconds, then reset the breaker This unit is very sensitive to power fluctuations.
Mar 07, 2009 | Viking 37 in. VECU165 Electric Cooktop
Dual Element
check underneath the element, you may have something preventing the element from gihting up. if you didn't find anything, then it is time to get a new element.
Oct 08, 2008 | Jenn-Air JED8430 Electric Cooktop
HOT SURFACE LIGHTS
Hold the button down 5-6 seconds and it will go off...then to cut on...press down again for 5-6 seconds and it will come back on.
Sep 06, 2008 | KitchenAid 30 in. KECC506R Electric...
Cooktop light stays on when cool
the "hot top" indicator lamp is switched by a contact on the plate cut-out. sometimes this cut-out is available as a separate part but often must fit complete plate. by plate i mean the bit that gets hot!
Mar 28, 2007 | Kenmore 30 in. 42701 / 42702 / 42709...
Cooktops Logo
89 people viewed this question
Top Cooktops Experts
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
