Question about KitchenAid Refrigerators
Refrigerator Model #KSRA25ILSS03. How much and how difficult is it to replace a starter relay?
How much and how difficult is it to replace a starter relay for a kitchenaid refrigerator?
  • 245 Answers
A 3 in one start relay usually runs about $75 and it is not that difficult to replace if you are sure that this is the problem there is also the chance that the compressor could be damaged. you do not want to replace just the relay as there is also an overload circuit the 3 in 1 starters have everything in it and good instructions as far as which wire goes where you have 2 wires for 120 volt in and then three connection on the compressor
Posted on May 15, 2009
Clicks but wont start
The most likely problem is the battery. Take the battery out of your bike and take it to an automotive parts store or somewhere that can run a "load test" on the battery. Depending on what year and model bike you have, it could be a problem with the starter or the starter relay. If the "click" you hear is a very faint one, it could the the starter relay which is a plastic cube type device about one inch dimensionally. The same type of relays you find in todays automobiles. This device is activated by the "start" switch and it activates the solenoid section of the starter. If the "click" is a relatively loud click, it's probably the solenoid of the starter. If the battery is good but all you hear is the "click", the large copper contacts in the solenoid are probably burned and need replacing. The procedure for doing this is not difficult but varies with year and model bike. On the late model bikes, you take the 5-sided plate off the backside of the starter and pull the plunger and spring out. Inside, you'll see two large copper contacts. If they look burned and uneven across the face, they need to be replaced. Disconnect the battery and a kit is available that has everything in it that you need to rebuild the solenoid.
Good Luck
Steve
Jul 30, 2011 | Harley Davidson FXR Super Glide...
The compressor clunks very loudly when it cycles off but the mounts seem solid. What's the cost having a new compressor installed?
If your refrigerator is very old model then the clunks you are hearing is most probably from starter relay which was mechanical in those days. You can get this starter replaced with the electronic one without any compressor change or modification.
More accurate diagnostics maybe given by checking the refrigerator so before you go for any costly repair, do get it checked by a friendly refrigerator technician.
May 31, 2011 | Kenmore Refrigerators
Refrigerator just stopped working - coils are lint free. I just plugged it in and heard something - possibly the compressor but it has since stopped humming when I re-plugged it in. I think it may be the...
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Aug 13, 2010 | KitchenAid Architect KBRA20ERSS Bottom...
Im trying to locate the starter for 1994 jeep grand cherokee , see if its easy to replace, and also the location of the starter relay
starter relay is in power distribution center near battery. don't know which engine you have, but if you flollow the positive cable on the battery, it will lead you to the starter. Most are not difficult to replace, depends on how much experience you have. One tip...dont overtighten wire connections on starter the solenoid cover is plastic and can break.
May 07, 2009 | Jeep Grand Cherokee Cars & Trucks
Kenmore refrigerator 253.57192600 making clicking noise
It could be as simple as a bit of expansion and contraction of the wall panels or the damper which allows cooling to flow from the freezer to the fridge side.
Mar 08, 2009 | Refrigerators
Smell electircal burning
The Starter Relay consists of various parts depending on the make and model of your unit. Most larger Refrigerators have these 3 components: The relay itself, the Overload, and a capacitor. If you replace the Relay and if another component is bad then you would still have a problem. A service technician could test each component individually. The first move I would make is to use an Amprobe electricians meter and check the amperage that the compressor is pulling. If the compressor is VERY HOT to the touch and pulling a lot of amperage current, than you'd need to have the compressor replaced. THis is usually the case if the unit is approx 10 years give or take. This is a very expensive fix...usually around $500 or more so it's probably worth buying a new Refrigerator if that's the case.
Nov 17, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerator stopped cooling
I have the same problem on my GE model :
GTS18FBMERWW
It is a 18 cu ft, top freezer model.
If you get an idea please let me know.
TK
May 20, 2008 | KitchenAid Superba Architect KSCS25INSS...
Refrigerator humming noise and loss of coolness in freezer.
the relay overload on the compressor is bad. its a very common problem. replace the relay overload and it will start back up again. ( relay overload is what your calling the starter)
Nov 27, 2007 | Refrigerators
Refrigerators Logo
385 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
