Question about Garland M-1 GL Gas Single Oven
Posted on Sep 29, 2008
I have a Garland Mater 200 electric oven and the fan continues to run even with the door open. Is there a switch / sensor that controls that?
This web site had a manual that may answer you question. It seems that here is a heat/cool switch. The cool switch is designed to function to cool the oven down by running the fan with the door open. If you close the door, it will heat so the door has to stay open.
Aug 20, 2017 | Garland Ovens
Blodgett conv oven heating
a couple of things to check--are you baking more product than usual at one time?does your oven have a load control dial?if so the dial could be set wrong or inoperative.if your baking to much product than normally the excess moisture could cause this.has any electrical work been done to the oven or its power the fan running clockwise?when you look at the fan do you see a tube in front of it?if so check for a blockage (tinfoil).lastly you could have a bad heating element.
Oct 03, 2007 | Ovens
I have a Garland MCO GS 10, and the Master 450 indicates "SRB Overheat" when ever it is turned on. I can not find a definition of "SRB". Could someone please enlighten me?
If what you say is true, look for a vent fan to keep board and compartment cool. may not be working, no air flow, dirty.
Aug 04, 2016 | Garland Ovens
Electric overn working but not heating up
If it is a electric fan assisted oven, and the fan is working o/k, then it is likely to be a faulty oven element.
This is usually located at the rear of the oven compartment behind a removeable cover.
Please rate ny solution.
Jan 14, 2010 | Ovens
Model TE2B garland does the fan run to move
The fan runs to circulate the heat inside the oven for more even and faster cooking...That is how a convection oven works :)
Jan 14, 2010 | Garland Convection Oven - MCO-NAT Gas
My garland air deck will not heat up
I own a large repair company we charge these fees for our tech. ability I often give you people free advise but when you insult our techs try to figure it out yourself then you will know why we chargey the way I would not give you free advise you would not say thank you
Dec 31, 2008 | Garland M-1 GL Gas Single Oven
it sounds to me like the door switch is not making. if you take off the bottom panel the switch is to your rightat the bottom. make sure that you kil power first brfore you remove the panet.
Dec 22, 2008 | Garland Convection Oven - MCO-NAT Gas
Overn will not work properly
sounds like you have a bad oven ignitor, very common problem with alkl gas ranges, easily repaired by you a few screws and a wire harness part number 12400035
Apr 05, 2008 | Ovens
Fagor overn doesn't heat
I had a similar problem - turned out the knob on the left by the clock was set to automatic instead of manual.
Dec 15, 2007 | Fagor 5HA-196 X Single Oven
Ovens Logo
143 people viewed this question
Top Garland Ovens Experts
Dennis Boxerman
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Garland Oven Expert? Answer questions, earn points and help others
