Question about Matrox PARHELIA 128MB 8XAGP TRIPLE RGB DUAL-DVI,TV OUT- With DVI to VGA/TV cable (Retail) (Retail Bo... Graphic Card
I put my rgb cable into my HD tv and when i put it to the inpute for RGB in it says invalid format and i have no idea what to do. I have played around with the graphic properties and such but no luck at all. I have a pc not mac. Please help
  • 3,866 Answers
Well you need HD calbes there Blue Green and Red not Red yellow and white so put these in the yellow red and white and use them as RGB because it is a invalid format!!
Posted on May 15, 2009
How to turn on rgb from lap top to tv.
In order to connect your laptop to your TV using RGB, you need an RGB adapter. RGB is also known as component video; it breaks up a video signal into red, green and blue. laptops do not have RGB outputs. However, many laptops have VGA, DVI or HDMI outputs. An RGB adapter connects the single VGA, DVI, or HDMI cable to an RGB cable, which is actually three different cables tied together. INSTRUCTIONS:
1. Connect either the VGA, DVI or HDMI (in the order of increasing video quality) cable to the VGA, DVI or HDMI port on your laptop, depending on what is available. 2. Connect the other end of the cable to the side of the RGB adapter with the single input. 3. Connect the RGB cables to the red, green and blue ports on the other side of the RGB adapter. 4. Connect the other end of the RGB cables to an available component input on the back of the TV. 5. Tune the TV to the component video input you used through your television's menu. 6. Turn on your laptop. The laptop should now display on your TV screen.
May 30, 2011 | Computers & Internet
Trying to hook my home PC into my LG TV gets me the message Invalid Format, what can I do to get the signal or can i use this tv for my monitor with a dell PC
Connect VGA (D-sub 15 pin) cable from PC to TV (RGB PC) input jack. Connect audio cable from PC to TV. Set screen resolution on PC to be compatible with TV, such as 800 X 600 or 1024 X 768 etc. Select on the TV, the PC INPUT using the TV remote when ready to use as monitor.
Under PICTURE on the TV select SCREEN (RGB-PC). You can AUTO-CONFIG or you can set resolution manually to the same you set PC to. Other adjustments can be done here as well to get optimum picture on TV from PC.
Mar 01, 2011 | LG 26LG30 26 in. LCD TV
How do i get 1080i, my tv shows im only in 480i. i think i might have it hooked up incorrect. my other tv of another brand is much newer so all i did was connect the hdmi cable from the tv to the cable box...
Hello
Your TV will display all High Definition signals as 1080i True HDTV™ and all standard definition signals will be displayed as 480p.
Component Inputs 1-2
YPbPr(480i/480p/1080i)
These inputs can be used for the connection of A/V equipment with component video outputs, such as a DVD player or external HDTV receiver. Please see Appendix B for signal compatibility.
Input DTV (480i/480p/1080i)
This input is used to connect an external DTV receiver, and can be configured for YPrPb and RGB plus H&V signal types.
As a special feature, you have the ability to adjust the red and blue light beams in reference to the fixed green light beam. This process is called convergence. There are two separate memories for convergence. One, for SD 480i/480p signals; the other for HD 1080i signals. SD convergence should be adjusted while watching an SD source and HD convergence should be adjusted while watching an HD source.
Wide Expand: Enlarges the picture, cropping some of the image on both sides. This Expand format is useful to remove or reduce black side bars on HD broadcasts of 4:3 images with black bars. Available for analog 1080i, digital SD 16:9 and digital HD signals.
InputDTV
This input is compatible with most standard DTV and satellite receivers with component video (YPbPr) outputs. Compatible DTV signals are SDTV 480i/480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Please check the DTV receiver specifications before connecting.
This input is compatible with some DTV receivers using RGB with "separate H and V sync". Compatible DTV signals are SDTV 480i, 480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Industry standards for DTV RGB signals (systems, synchronization, timing, and signal strengths) are not currently established. These inputs will not be compatible with all DTV receivers that offer RGB, HV outputs. RGB, HV signals with less than 5 cables are not compatible.
If your DTV receiver offers both DTV component video signals and DTV RGB, HV signals, we suggest you use the DTV component video signals. Check the DTV receiver specifications before connecting.
Ok.
Feb 05, 2011 | Mitsubishi WS-73909 73" Rear Projection...
Screen turns blue after Windows XP boot. It is
You cannot set your PC video resolution to 1920x1080 @60Hz?
Per user manual:
1. Set computer to a resolution supported by your HDTV (see Preset PC Resolutions). If your
computer supports it, we recommend 1920x1080 @60Hz.
2. Turn off the power to your HDTV and Computer.
3. Connect the VGA cable from your computer to the RGB PC jack on your HDTV.
4. Connect the 1/8-inch audio cable from your computer to the RGB PC Audio jack on your HDTV.
This step is optional and only needed to transmit audio from the computer through the TV.
5. Turn on the power to your HDTV and computer.
6. Select RGB using the INPUT button on the remote control or side of your HDTV.
Note: Refer to your PC computer user manual for more information about the video output requirements.
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
Sep 07, 2010 | Vizio VM230XVT 23 in. TV
Hooking up my Sony HD Tv
Couple of items come to mind.
In the menu of the receiver, is there a way to choose video and RGB?
Set the receiver to SAT
Connect the HD Cable Box to SAT
Check the TV is on Monitor RGB.
Check the input being used by the monitor RGB cables is selected on the TV.
Have a picture? NO, receiver has issues.
Yes? Do this with each input to confirm they work.
You can reset the whole receiver to factory by holding the tone button down and holding the standby button for three seconds. (This clears your speaker setups, too.)
Apr 02, 2010 | Televison & Video
TV Picture is green
is your RGB cables are the same output from your tv...are you connecting from where dvd cable box sattelite box, if you are connecting from a box exs output of cable box is what colour are you using? for your your output to your tv and what input are you using of your tv set.[input 1is it video input 1,] or comp? let me know...
Jan 10, 2009 | Televison & Video
LG 37LC7D Connect to VGA from a PC
Your right. I just had the same "Invalid Input" issue as well and it completely relates to the resolution compatability with any VGA or HDMI connection. Check the LG website for the online manual if you don't have it and see the section on RGB-PC cable. There is a table that incdicates the Resolutions the LG product is capable of displaying.
Thanks for the help.
May 20, 2008 | Televison & Video
Trying to use rgb input
Cable TV: Connect the LCD TV to the cable with CATV and Digital cable. Preset the cable TV channels into memory with Auto Scan function when using a cable TV system. Make sure you set the INPUT SOURCE properly (TV, VGA, S-Video, etc)
Mar 10, 2008 | ViewSonic VPW425 42 in. Plasma HDTV
Upgraded DirectTV satelite TO HD
direct tv hd receiver is hdmi or rgb which is a different signal than the rgbhv input on the back of older mitsubishi tv . You can buy a converter that converts the format for about 90 dollars online. It converts rgb or component to vga/rgbhv
Oct 24, 2007 | Mitsubishi WS-55805 55" Rear Projection...
Computers & Internet Logo
534 people viewed this question
Top Matrox Computers & Internet Experts
Jerry
Jerry
 Gary Gemmell
Gary Gemmell
Are you a Matrox Computer and Internet Expert? Answer questions, earn points and help others
