Question about RCA DIRECTV Satellite Remote Control
No signal Had a thunderstorm move through last night, lightning hit nearby, lost picture. Recieved message seaching for signal. I replaced LMB, checked location of dish realigned. still no signal, all boxes power up, reset them still no signal. Any idea's
    President:
  • 814 Answers
Sorry it took so long for you to get a reply to your request for help.You have had a component failure in the system. This type of problem requires a qualified satellite service technician. He will have to test each component in the video signal pick up to see which components may have failed. This will be done with signal tracing equipment and testing meters to test the signal path and strength of the signal.The power overload may have taken out some internal signal processing circuits. I hope this information helps you solve your problem. Thank you for using FixYa and have a nice day!
Posted on Jun 20, 2009
Does not run. All systems not working. No pilot lights on. Fuse?
That is highly possible. Lightning can hit miles away from you and ruin your electronics. I would suggest that you contact your insurance company about it because it could be expensive to repair.
Jun 17, 2015 | LG LTC22350ST 22.1 cu. ft. Top Freezer...
No signal and sometimes picture freezes
sometimes you can have weaker signal, and pictures freeze...
it can be caused by bad weather, by thunderstorms, heavy rain....
you can't do anything about it, just get stronger antena....it can improve your gain from signal, but never for 100%
Jan 13, 2014 | Polaroid Televison & Video
14 blinks
Power surge. Unplug for ten min Should reset
Aug 06, 2012 | Televison & Video
I received a text message from skout and have never used this site before.. Has anyone ever had this problem?
My husband recieved 6 messages last night at really odd hours saying he has recieved a message from skout but he says hes never even heard of it
Feb 11, 2012 | Facebook Apps
We had a thunderstorm last night, and the power went off and came back on a couple of times and now our Tv isn't working. The green power light stays on, but there is no picture on the screen. We...
The tv Tuner signal board it is shorted and dead.That the board where the tv incomming broadcasting signal cable plug into it.U have some basic mechanical skills like take things aparts and putting it back together.Yes?Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.
Aug 12, 2011 | Norcent Technologies LT-3250/LT-3251 32...
Toshiba TV dead: is there a fuse inside? Toshiba 24AF46 is dead after a thunderstorm and nearby lightning. Plug sparks when I plug it into the wall. Nothing happens on the TV. No sound, nothing when I hit...
Yes,there is a fuse in inside on the tv main pcb board near the power a/c cord.But if the tv have sparks,main pcb board could have more other components fries too.If tv less 10 years repair it by a shop,more than that should buy a another tv.
Jun 09, 2011 | Toshiba 24AF46 24" TV
I have sansui 27inch tv and because of thunderstorm my tv got blew off and its not working at all now it dont even turn on so please let me know what should i do now
You can check the fuse which is internal to the TV, but that requires removing / opening the case and potentially exposing yourself to lethal voltages. Be careful. If lightning hit nearby, it is likely damaged permanently, no cost effective to repair. Might talk to insurance company if applicable.
Jun 17, 2010 | Sansui 27" TV
My tv comes on and has "unusable signal" floating on it
What is your signal source, OTA or cable? Did lightning or another type of power surge recently hit? Make sure you have the TV on the desired input.
If OTA check your antenna direction and that you have the Channel Setup (from the menu) set to Antenna. Also check if you have the right antenna to get stations in your area. Antennaweb.org gives the most likely channels and directions. tvfool.com will give more detailed information and more stations. Both sites assume outdoor antennas but the direction information is always good. Look for new construction or big trees that might block the signal. Do you have multiple TVs sharing the same antenna? You might need an amplifier.
If cable, check the Channel setup. Check for someone recently damaging your cable installation (cutting the wires, trying to split the signal to get it for free) Splitting the signal to multiple TVs may also be an issue, get an amplifier of the correct type. Some cable systems may require a bidirectional amplifier.
If you recently had a power surge, see if the TV works with other inputs.
Tuners can be replaced if the TV is worth the labor costs for you.
I hope this helps.
( My household had three tvs and a digital to analog converter that lost their tuners after a nearby lightning strike. We chose to replace the TVs since two were over 15 years old and the third was also out of warranty.)
Apr 13, 2010 | RCA L46WD22 Television
Fan runs but blowing hot air. Thunderstorm reset some breakers. I did reset the two breakers inside the house and one unit working fine, upstairs unit fan running but blowing warm air only. Box out
Sounds like your Capacitor is bad, or you had a wire burn off compressor terminal or capacitor. Way you can check capacitor is take cover off and see if looks swollen. Make sure to turn off power before taking panel off.
Apr 25, 2009 | Heating & Cooling
RCA DIRECTV Satellite Remote Control Logo
138 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
