Rheem Classic X Humming
I have a Rheem Classic X air conditioner and when I turn the AC on, the unit hums inside the house for approx one min and then blows the breaker. The fan outside the house will run fine until the breaker is blown. Any comments would be appreciated. Do you think I have a contactor problem?
  • faith41184 May 15, 2009
    How do I figure that out for sure? I'm in the medical field this is not really my thing lol
  • Ken Bledsoe May 11, 2010
    Sounds like you have a bad compressor.
  • 116 Answers
Does the indoor fan come on if fan comes on then the problem is out side if the fan is not coming on and the breaker blows this will turn off the out door unit also due to the 24v transformer is located in the indoor unit your system has two breakers one for out door and one for indoor units as far as your contactor goes with power off look at the contacts if pitted bad replace it most need replaced after 5yrs also check for voltage drop on the load side look at the capacitor to make sure it is not swelled up on top if so then bad unplug the fan motor and bump the contactor with an insulated object to make sure the compressor is running if not with power off remove the cap on the side of the compressor and look to see if wires are connected good they some times get lose and ends burn off also on the contactor they some times buzz when bad hope this helps with your problem
Posted on May 15, 2009
  • Todd Felts Aug 09, 2012
    It's difficult to decipher what ac fixer is saying without any punctuation.
    It's difficult to decipher this information without the use of punctuation.
Rheem classic 80 fan motor on furnace hums will not turn on
Have you checked the capacitor? Try spinning the blower wheel by hand, if this gets the motor going you have a bad capacitor. If not, the motor will need to be replaced.
Nov 16, 2012 | Rheem Prestige 14 Series 2.0 ton 14 SEER...
Outside unit comes on. inside unit stays humming
You could have a bad motor or motor capacitor. The capacitor is the can with two or three wires coming from it. Shut off the power to the unit and remove the blower panel. Check to see if the motor turns free and is not noisy. Next see if the motor is hot after it has been humming; if it is it may just a new capacitor and they are cheap and can be picked up at ac supply house. I'm going off the info you provided. humming can sometimes just be the transformer and you could have a blower relay issue. I have provided the most common issue that I find with this description.
Jul 31, 2012 | Goodman Heating & Cooling
My outside Kelvinator central ac unit will not turn on. I hear a faint humming noise coming from it so it appears that it is getting power but won't turn on. My fan in the house will turn on and...
Its possible that the contactor that closes to start the outdoor unit is not pulling in and passing power. You are hearing the coil humming since it is getting control power. Also first check that breaker for outdoor unit is not tripped
Jun 22, 2011 | Heating & Cooling
We have a Goodman Furnace and Air Conditioner approx 7 years old. When I put the Cool on thermostat and lowered the temperature for the air conditioner to come on the furnace fan started but the outside...
You are right. The outside unit starts quickly. The humming will either be the evaporator fan or the AC compressor itself. If you can reach into the evaporater fan with something narrow and stiff you may be able to see if the fan turns. Sorry for the trouble you are having.
One or the other is trying but unable to start, hence the humming.
Wayne
Jun 11, 2010 | Heating & Cooling
A/C fan will not start when therm clicks on, also a Rheem Model
What make & model is it? How hard to get at the fan that's humming? Sounds like capacitor to fan is shot.
Aug 03, 2009 | Heating & Cooling
Compressor switches on but only humms fan does not spin
You have a bad run capacitor. You can change it or you can get a service tech to change it. About 150 for the job Rus
Jul 19, 2009 | Heating & Cooling
Ac not on but humming
Sounds like the contactor inside the condensing unit is stuck closed. Once this occurs, it should probably be replaced, as this kind of condition can lead to compressor damage if left unsolved.
Apr 25, 2009 | Heating & Cooling
Air Handler Blower Unit Humming
More then likely it's the transformer. It may be getting weak. I've seen them hum/vibrate almost new and last for years. It's more an annoyance than anything.
Jan 18, 2009 | Heating & Cooling
RV Rooftop AC Unit
Sounds to me like your fan is hitting something
Remove the cover and turn the fan by hand ( with the power off ! ) See what it is hitting
Oct 24, 2008 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
828 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
