Question about GE 27 in. Monogram ZGU48N4GD Gas Cooktop
The grill on the ge cooktop does not light
All burners and griddle work fine
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 05, 2010
GE cooktop ignitor jgp
Look for a short in the wiring (usually white wires running to the ignitors) or a loose ground wire. (usually green)
Jul 02, 2012 | GE Cooktops
Should I buy a two burner unit if available? Or a new cooktop?
Yes you can as long as there ae two heat controls for the grill side of the stove/cooktop. That allows one burner control for each of the burners. You should be able to order directly from GE but I would also check out repairclinic.com since they normally sell OEM GE parts cheaper than you can buy them from GE. At least check out the price at both sources beforw purchasing.
Dec 29, 2009 | Cooktops
I was given a 36" magic chef gas cooktop with griddle. It was very greasy and dirty, all the burners were sticky and slow to get turned on, but 2 of them refuse to turn on, parts lists say the griddle...
If it's two burners on the same side that won't light, it is probably the igniter for that side. If so, remove the grates, griddle, and griddle sub pan, and then lift up the main "pan (if it's like mine, it's hinged at the back and lifts up). Now, if each burner on that side has a tube going to the middle between the burners, the igniter is in that middle section. Mine is a small plug-in ceramic and metal part (see photo). If yours looks like this, contact me at jazzskier@verizon.net, I have a spare.
Nov 29, 2009 | Magic Chef 30 in. 8241RT Gas Cooktop
Need to restore the non-stick surface on a GE griddle
Put a sheet of wax paper between the two plates for a few minutes while it heats up, then remove. It will transfer the wax to the grill so you'll temporarily restore the non-stick coating.
Oct 17, 2009 | GE Cooktops
Thermador Gas Range - Griddle ignition will not spark
I have a Thermador Gas Range PG364GDBS - Oven, 4 burners, and center griddle. All are gas. The four burners and gas oven work fine. The griddle just stopped working, no spark. Turning on the griddle control, the gas valve opens(hear it), gas flows (smell it), but the ignitor will not spark (no loud or faint spark that I can hear). I got a replacement ignition device (mount at the burner) thinking it might be the problem, but still no spark. I checked the AC voltage at the terminal and measured 39 VAC between the terminal and ground. Not sure if that is the correct voltage. Any insights or advice would be great.
Dec 07, 2008 | Thermador SGS36GS Gas Cooktop
Thermador PCS364GDUS griddle needs cleaning.
Wear gloves, put all items in a garbage bag. Put outside and spray a can of easy-off oven cleaner on all parts. Seal bag and let sit for 24 hrs. They should come out looking new after you rinse them off. After you wash them off, put them in a 300* preheated oven for about 30 min to ensure they are dry.
Oct 22, 2008 | Thermador PC366BS Stainless Steel Gas...
Exhaust turns on automatically in burner mode
Hello
I have the one with the 4 burners and the grill, and when the grill in on the fan has to come on, and it does automaticly, but once you finish with the grill you have to change it back to stove mode by putting the 2 burners back or the fan will allways go on when you turn the switch. It is a safety regulation for the fan to be on with the grill to avoid the fumes......I know I hate that too.
Hope this help
Eddie Rentas
Tupper Lake NY
Jul 19, 2008 | GE 30 in. Profile JGP979 Gas Cooktop
GE 27 in. Monogram ZGU48N4GD Gas Cooktop Logo
79 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Dave Harrison
Are you a GE Cooktop Expert? Answer questions, earn points and help others
