Question about Samsung Digimax L60 Digital Camera
Transfering problem on my samsung l60 camera i took a few pictures which were saved to camera memory. But now i have bought a new sd memory card and i wish to transfer my pictures from camera memory onto sd card memory. i dont have a usb lead for the camera. i have searched on menu for an option that cuold guide me to move the pictures but i am unable to find one.could u help please asap?
    Problem Solver:
  • 30 Answers
Re: transfering problem
Your camera has no internal memory so please buy a card reader and transfer your images into your pc and your next memory card
Posted on Oct 17, 2007
0 characters
3 Points
I have an Optio S camera. We haven't used it in a while because we lost the battery charger. We bought a new one and we took some pictures last night but they are not saving to the SD card. The card...
They are being saved to the internal memory of the camera. With no card in the camera, go into the menu and find "format" and follow the instructions to erase the internal memory. Insert your card and it should now work properly.
Jun 28, 2011 | Pentax Optio S Digital Camera
Kodak easyshare m360 says memory full after 3 photos i just bought the camera, what i shell do < shell i buy memory card or usb for it ?
You need to switch the camera over to saving pictures directly onto the SD card.
  • Menu
  • Cam settings
  • Chose AUTO or SD card option
  • Press OK to SD card
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
If you experience problems:
The lever on your SD card might be turned the wrong way so the SD card is reading protective.
Please turn the lever and try again.
The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 2 Gigabyte and SDHC up to 8 Gigabyte
The SD card might not be faulty, try another card, since the camera could give you a message like the one you're experiencing.
Try with a different SD card that is supported by the camera.
Once you have set the settings to save onto the SD card directly you might like to transferre your existing pictures from the internal memory onto the SD card:
Question :
How do I transfer pictures from the internal memory of my KODAK Digital Camera to a memory card? Answer :
Follow these steps:
  • On the camera, press Review and then Menu.
  • Select Image Storage.
  • Change to Internal Memory.
  • In the menu listing, scroll down to Copy, and select OK.
  • Select a single picture, or select All.
  • When you have finished copying pictures, reset the Image Storage location to your original setting.
  • Jan 18, 2010 | Kodak EasyShare One Digital Camera
    How do you transfer internal memory pictures to memory card? I have a Samsung Digimax L60 camera and I forgot to put my memory card in my camera and took pictures without it in. How do i transfer the...
    Put the memory stick inside the camera. Then open the photos which is save in your camera memory. Select them all & then you find a option Send to memory card or copy to memory card. Select that and press ok. Your photos transfer from camera memory to memory stick.
    Dec 30, 2009 | Samsung Digimax L60 Digital Camera
    A New 2G SD Memory Card Destroyed Samsung L60 Camera's Screen
    I am kinda confused what you mean by black blob, but anyhow a SD card cannot do this to a camera as long as the camera supports the memory card. I feel there is a little more to it then this. The lcd will need to be repaired this will need to be taken to a camera shop to repair this with a new lcd around $50 bucks respectivly. I find it hard to understand this ether as this should not have happend. the memory card if compatable should not have shorted this camera lcd out.
    Please do leave a postive rating and feeback for your free answer today.
    Dec 04, 2009 | Samsung Digimax L60 Digital Camera
    Transfering images to SD Storage card
    I'm not familiar with your camera but most of them have a listing in the menu for "copy" with instructions on how to transfer from the internal memory to the memory card.
    Nov 17, 2009 | Samsung Digimax D53 Digital Camera
    I took picture w/o SD card. Don't know how to transfer to SD
    Search the menus for an entry for "copy". It should give you the option to copy the internal memory to a memory card. You could also take the camera and a usb connecting cord to a store like Walmart that has a Kodak picture maker machine. You can plug the camera into the usb slot and print the picture.
    Sep 11, 2009 | Samsung Digimax S730 Digital Camera
    SD Card Issue
    Usually when you take pictures using NO SD card you can't take the picture, however in this case the pictures you took are stored in a memory bank temp only to test the picture your actually taking. In the manual what's the size of the built in memory card? Usually it's small amount of memory built in
    Sep 07, 2009 | Samsung Digimax S730 Digital Camera
    Save on to sd card
    Greetings nickylaa,
    To transfer the pictures to your sd card, you would want to first transfer to your computer then you can download them to an sd card. If you dont have a media computer then a memory card reader would be the easiest way to accomplish this.
    I hope this helps!
    Go Ahead. Use Us.
    Jun 10, 2008 | Samsung S1030 Digital Camera
    Memory Stick
    Samsung camera usually use a SD (Secure Digital) cards not memory sticks.
    Dec 26, 2007 | Samsung Digimax L60 Digital Camera
    Digimax L60 will not recognize my card
    Your Digimax L60 will also recognize your SD card please select the option to save pics
    In camera or in memory card. This time your camera work on its internal memory.
    Oct 11, 2007 | Samsung Digimax L60 Digital Camera
    Samsung Digimax L60 Digital Camera Logo
    228 people viewed this question
    Top Samsung Digital Cameras Experts
    Are you a Samsung Digital Camera Expert? Answer questions, earn points and help others
