Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
Adjusting carb on a 20 hp onan
Engine started to sputter at iddle and throttle up
3 Suggested Answers
  • 11 Answers
SOURCE: Engine floods and misses , at settings above 1/2
your carburator sounds like it is too rich it needs adjustement try turning the adjustement screws in all the way and back them out 1 and 1/2 turns and adjust from there
Posted on Apr 03, 2009
bargainbin2
  • 123 Answers
SOURCE: My 420 with an onan runs great at half throttle, then bogs down.
Are you sure you did not get the jets in the wrong places when you cleaned that carburetor.
Posted on Aug 26, 2009
It buckle and sputters when in iddle or at light
Your air/fuel mixture is too rich so it's choking out the engine. Get your mechanic to adjust the carburetor.
Mar 18, 2014 | Hyundai Motor 1995 Accent
Starting hard
Hi Ted, most likely the choke is not coming on fully. To fix this adjust the choke cable or if the choke is on the throttle adjust the throttle cable. Regards Phil.
Jan 01, 2013 | Cub Cadet Street Sign- tractor lawn riding...
Craftsman ys4500 mower-- starts great and runs ok at low speed but at full throttle sputters and pops and of course loses power
sounds like your choke is not opening up all the way fast easy test,take a sharpe pen and mark priar adjustment on choke cable. next; remove cable from carb,then hold chokeopen start give full throttle{no difference} carb kit
Oct 22, 2012 | Craftsman 20 hp 42 in. Deck Yard Tractor
After running for awhile the engine begins sputtering and dies out. I generally have to keep it a full throttle to keep it running. I tried spraying down the carb with cleaner which allowed me to run with...
always check spark and compression first spark needs to be blue and compression should be 120 but will barely run on 80psi if both are fine rebuild and acid dip carb the adjustment is 2 full turns out
May 19, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Vanguard V Twin 18 hp. monted in Cushman Motor scooter, runs great at W.O.T and at on quarter throttle, misses at range inbetween
Sounds like your carb needs the fuel/air mix adjusted..uses all the gas at high speed but has excess at low speeds...find your adjusting screw and at med throttle slowly screw it clockwise until the engine starts to sputter then back it out until it starts to sputter again then continue to do this until you reach ideal mix where it runs the best it can..then go slowly through the throttle up and down..when set..unjust your idle speed screw to your ideal idle speed..if this dies not fix ..carb will bed cleaned or rebuilt. Good luck.. Note always push or pull your throttle handle slowly to position avoids gas load up causing sputter and backfire.
Mar 15, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
Starts easily, run for 5 to 20 minutes and then
If the fuel filter (strainer) is OK, carb gives enough fuel for the load you apply, air filter is dry and clean, your problem may be the low oil level protection.
Check if generator is at level position.
After the oil is distributed in all the engine its level may go less than the measuring sensor level. Try to put some more (not much) oil.
If this will not help your measuring sensor may be bad and switch off when the oil gets hot.
Jul 26, 2010 | Watts Onan Portable Generator - 5000 ,...
I have a riding mower with a Briggs 20HP Intek engine. A couple of years ago it started sputtering when put under a moderate load. The problem is worse when going up a hill or in a tight turn. Once the...
I think your carb float/needle valve are not opening fully. Adjusting the carb doesn't help this. Try lightly tapping the side of the carb with a small hammer to see if that corrects - at least temporarily
Apr 20, 2017 | Briggs & Stratton Briggs Stratton Intek V...
Motor chokes and misses under moderate load and loses power
Sounds to me as tho it might need a carburetor adjustment, providing there is an adjustment screw on the carb. Sounds like the engine is running a bit lean. Did this problem occur right after the carb cleaning, or was it there in advance? Is there a fuel filter that might be clogged?
Jan 18, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Civic 95 lx 1.5 engine dies when iddling
Check the IACV, its located at the throttle body, facing the firewall. They get junked up with carbon. Just clean it up with carb cleaner and bleed out the air from the coolant.
Jun 25, 2009 | Honda Civic Cars & Trucks
1993 charade 4 cylinder
try to adjust the tension cable between your pedal and the throttle swing arm and if this thus not work try to clean your carb if you have a carb engine and if you have the EFI engine try to check the iddling resistor it is usually on the other side of your intake butterfly valve.
Jul 16, 2008 | 1992 Daihatsu Charade
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
742 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
