Question about Panasonic CT-27SL14 27" TV
No sound after going through menu settings. I selected something that turned the TV mute
I ran through all the set-up menus today simply to determine what was what and now there is no sound via the amp or the internal speaker. What did I do to turn the TV forever mute?
  • specialedbil May 15, 2009
    No help. The audio runs through an amp and even when I did turn the internal speaker on and off, no change.
    Thanks for the good shot.
    Bill
    Genius:
  • 1,148 Answers
THE MENU ,,YOU PROBLY TURNED INTERNAL SPEAKERS OFF,,
Posted on May 15, 2009
Sanyotv com
Sanyo TV Service Menu Method 1
1.Unplug the power cable.
2.Press and hold the {MUTE} button on the remote control while plugging the power cable back into the outlet.
3.Keep pressing the {MUTE} button until the TV powers on with the Service Menu displayed.
4.Use the {CH+} {CH-} buttons to select menus.
5.Use the {VOL+} {VOL -} buttons to change settings.
6.Some menus might have sub-addresses. Use the numeric buttons {0} to {7} to adjust sub-item data.
7.Press the {MENU} button or turn the TV off to exit.
Sanyo TV Service Menu Method 2
2.Press and hold the {VOL -} button on the TV while plugging the power cable back into the outlet.
3.Keep pressing the {VOL -} button until the TV powers on with the Service Menu displayed.
Sanyo Projector Service Menu Method 1
Factory Menu Access
1.Press and hold the {SELECT} and {INPUT} buttons on the Projector at the same time for about 10 seconds.
2.The Factory Menu will be displayed.
Service Menu Access
1.Press and hold the {MENU} and {INPUT} buttons on the Projector at the same time for about 10 seconds.
2.The Service Menu will be displayed.
Use the {UP} {DOWN} {LEFT} {RIGHT} buttons to move through menus and change values.
To exit, turn the Projector Off.
Sanyo Projector Service Menu Method 2
1.Press & hold the {MENU} button on the Projector for about 10 seconds.
3.Use the {UP} {DOWN} {LEFT} {RIGHT} buttons to move through menus and change values.
4.To exit, turn the Projector Off.
Jul 20, 2013 | Televison & Video
Sound not working, Was working earlier today and after shutting off the tv, when we turned it back on, sound wasen't working
Sound issues and answersa short list:
sound on set or a box muted or turned down?
speakers inside the set (see menu) switchedon or off?
internal/external switch somewhere in or on back of set?
Clearly it could be a audio problem (a model number?) but explore all here thatyou have not already done--make sure theremote set to TV and look for a button on it marked MTS and if there cycle it.
You can also determine if same trouble when you play a DVD.
Apr 03, 2012 | Vizio 42 in. LCD TV
We just bought it today, got it set up. we have a picture. but we can not get any sound at all.
Here are some things to check;
Does the tv have the remote mute button set ?
Is the remote volume control turned up ?
Go into the menu to the sound section. Do you have the TV speaker selected on?
You did not give the make and model of the set so I am limited is suggestions as to what the problem is.
Check the owner's manual for suggestions.
Call your seller.
If the problem can not be solve the warranty should repair/replace it.
Feb 18, 2011 | Televison & Video
The book shows 0154 as the code for my sanyo tv ,it does not work .
Hello
If you are looking for its service menu, there is no code, but some doings is necessary as follows.
Two proceedings are given. One amoung them will surely open your TV to service mode adjustments.
To enter the service menu do the following. Most of the sanyo sets will get positve results with this.
* Press and hold the {MUTE} button on the remote control while plugging the power cable back into the outlet.
* Keep pressing the {MUTE} button until the TV powers on with the Service Menu displayed.
* Use the {CH+} {CH-} buttons to select menus.
* Use the {VOL+} {VOL -} buttons to change settings.
* Some menus might have sub-addresses. Use the numeric buttons {0} to {7} to adjust sub-item data.
* Press the {MENU} button or turn the TV off to exit.
OR
* Unplug the power cable.
* Press and hold the {VOL -} button on the TV
* Keep pressing the {VOL -} button until
OK
Jan 24, 2011 | Sanyo Televison & Video
Sanyo mode...
Hello
You just try one the procedure given below. One amoung will lead you to its service mode.
Dec 16, 2010 | Televison & Video
I would like to have my CC come on when I mute the TV?
Most TVs today have a program specifically called the "CC on Mute" function. Go to your "Input Setup Program," also called the "On-Screen Display Menu," and choose from the menu the "Setup" function (usually represented by the image of a "wrench"). If your set is capable of this function, then it ought to be located on this page, so simply choose, turn it on, and you ought to be able to have CC with mute each time you choose to turn it on.
May 09, 2010 | Vizio L37 Television
Sony bravia kdl- 4052510 picture but no sound from my dvd player
1 Press volume +/- or Mute 2 If it does not work then check if the 'speaker' is set to 'TV speaker' from the "AV set up" menu in "Settings" 3 Press Menu and select Settings. Go up/down and select Set Up icon.Press enter 4 In AV Set up go to speaker and turn on the TV Speaker. This should solve your problem
Nov 25, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Samsung LCD -no picture/sound from any input source-Cable,DVD,PS3
Use the menu button in the front screen of your tv.Maybe your remote control need a battery.
Jul 24, 2009 | Samsung LE40B650T2 40 in. Full HD Crystal...
SAP
Hi Suezie,
The problem is most likely your SAP being turned On.
SAP was created for audio programing including translations into a 2nd language. On nearly all sets, the SAP being ON will essentially select an alternate audio stream and will de-select or mute the main audio from the channel your are viewing. However not all TV stations have SAP enabled.
I am the Chief Engineer of a TV station in Denver, CO. We are not using SAP so if you selected SAP while watching my station you would get noise or static. There would not be any audio there.
Go to the front panel of your TV and select the "MENU" function. Step through the menus to Audio features and De-select SAP or Enable your main audio and this should take care of the problem. Alternatively you might be able to unplug your set for a period of time and it would reset itself. I used to get calls from elderly viewers when the set wouldn't pick up the UHF TV stations anymore. These were always after a power failure and the set had defualted to factory settings,
Different set manufacturers use different menu schemes and withou a password feature, these menus are so simple a small child playing with those fascinating buttons can change them for you to something you really don't want.
Good luck and write back if you can't find it. The set manufacturer and model number would help me look up a menu tree for your TV set.
Thak you,
Bernarr Howell
Feb 03, 2008 | Televison & Video
Samsung LE40R73BD DTV freezing, wont chnage channel
i've just some digging around and found that you can access a service menu and perform a reset which sorted the issue for me.
Access the service menu by pressing, in order, whilst the tv is in stand-by mode:
info
menu
mute
power
when the tv comes back on you will have a service menu; select option 12 (reset) the tv will then switch off.
this will reset your TV back to factory defaults.
turn tv back on and you should be prompted to go through the plug and play setup again - go through everything and then all should start working OK (it did for me)
HTH
Oct 24, 2007 | Televison & Video
Panasonic CT-27SL14 27" TV Logo
163 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
