Question about Hampton Bay 52 In. White Redington III¿ Ceiling Fan w/ Remote Control & Light Kit
Ceiling fan i have a hamptpn bay geneva model 310 564 worked fine when installed now ion high speed runs slow took off light kit and small capacitor was melted not the 3 speed capacitor . where would i get another capacitor if this is the p[roblem
  • donald w brown
    donald w brown Feb 13, 2014
    gulf fan , 979-553-3260
SOURCE: Wiring light kit to ceiling fan
connect the white wires from light kit filter to the white wire labeled "for light" from fan. then connect black wire from light kit filter to blue wire from fan. use wire nuts to make the connections
Posted on Feb 09, 2010
  • 43501 Answers
SOURCE: can you replace light kit on Hampton Bay ceiling
There are a bout three screws that hold the light part to the fan.
Make note of the wiring before you disconnect it also.
Remove the screws and the wiring will be exposed as the light part drops down...
Check the diameter of the light parts and find a new light kit that will fit it...
The Hampton Bay fans are exclusive to Home Depot, so most any of their light kits will fit, but any kit the right diameter will work..
Posted on Mar 05, 2010
  • 351 Answers
SOURCE: Where can I find glass shade / globe for a hampton
Hampton Bay is an exclusive brand to Home Depot. They have replacement globes in their fan section. or you could try a lighting store or Lowes.
Posted on May 06, 2010
SOURCE: capacitor for ceiling fan burned out, just barely
model number is on top of motor facing ceiling
Posted on May 13, 2010
  • 351 Answers
SOURCE: Trying to connect a ceiling fan light kit.
Those connections sound OK ,, now you have to go to the canopy and see if all the wires for the fan/light are connected to a house wire. If there are two switches , then the blue fan wire would connect to the red wire .. it may be capped off in the ceiling. If there is only one control switch , then the blue wire from the fan will connect to the same ceiling wire as the black fan wire does.
Please Vote !!
Posted on Jun 01, 2010
My Hampton Bay ceiling fan runs only on high speed and the remote has stopped working even after changing the batteries. Does Hampton Bay have a life time warranty?
Yes, look up and get their contact number from them. It sounds like your transmitter (Remote) has failed. If it were the receiver the fan would most likely not work at all.
Jun 09, 2010 | Hampton Bay 52 In. White Redington...
We have a Hampton Bay ceiling fan (about 10 yrs old) don't know the model. It will only turn 1 speed? When trying to change speeds with the chain pull it stays the same. It quit working for a while and I...
the fan changes speed by inserting a capacitor of different values in series with the motor .. direct drive to the motor is the fastest speed .. a large capacitor in series slows it down a bit and a smaller capacitor slows it down more ... so if your fan is running at full speed all the time then one of the capacitors is shorted or the switch is bad .. if its stuck on one of the lower speed settings then the switch has a bad contact .. the capacitors are mounted together in a small box with several wires going to the pull chain switch .. you can replace the capacitor box .. and you can replace the 3 or 4 position switch ... or you can remove all that stuff and put in a remote controled system .. that involves a box that just fits inside the fan .. it is hooked to AC power and neutral .. it then hooks up to the lilght and the fan giving you control over both .. you can vary brightness and fan speed .. you would no longer need the fan or light pull switch or the capacitors ... you could also get a new fan having such a controller .. since yours is fairly old it might be worthwhile to upgrade .. some of the remote controls allow you to set a temperature ..if the room goes above that temp then the fan turns on automatically and the speed is determined by how much higher the room temprature is from that set value .. some remotes also give you an additional very low fan speed .. thats nice at night when you just need a gentle breeze .. some also allow you to set a delay before the lights go out after you have clicked "turn off" ... that gives you time to exit the room or get in bed before the lights actually go out ... kindof nice features that might make it worth while to up grade .. to get parts for your old fan see this URL
since Home Depot sells hampton bay .. then they might have parts as well .. worth a try .. you can also see new models there ..
Jun 06, 2010 | Hampton Bay 52 In. White Redington...
I have a hampton bay ceiling fan which will only run on the fast speed. I have changed switches but still only the fast speed. I have touched each wire to the load wire to see if it was the swith but no...
Hello Brother,
Hang your ceiling fan on the Quick Connect fan bracket and wire the ceiling fan according to the manufacturer's instructions. The three wires coming from your ceiling should match the three wires coming from your ceiling fan: black (positive or hot), white (neutral or negative) and green (ground wire).
Use the high, medium and low keys on the remote to adjust the Hampton Bay fan speed, then use the light key to dim the light and the off key to turn off the fan.
For REMOTE CONTROL FANS you cannot use with any variable speed or slide wall switches. The remote control function must be used with on & off switch outlets only.
Speed Controls Click here Capacitors Link
I hope This Helped you,Thanks for Contacting FixYa...
Apr 22, 2010 | Hampton Bay Heating & Cooling
Altura 68" fans will not operate on high speed.
I jtoo, ust bought The Altura (68" fan from home depot)
Home depot makes hampton bay through various chinese manufacturers.................
The fan ran slow on high speed, and barely ran on medium or low.
home depot gave me a number for their tech department that knew right away.....that the capacitor(s) are defective in many of the Altura fans.
They are sending the capacitors in 3 days to me no charge.
They are located under the fan ( remember the white square plastic plug you had to connect and the 2 wires for the optional light kit?.....)That plug is for the capacitors that everyone is having a problem with.
My guess is they are under rated for a fan that big and are sending better ones to those with problems.
Hope this helps.
The number is:
Aug 18, 2009 | Hampton Bay 24002 Ceiling Fan
HB ceiling fan is getting slower and slower bi the day
Solid-state controls change the level of power in the fan motor to control the speed of the fan. For instance, when you switch from medium to high on a solid-state fan, the speed control mechanism increases the power of the motor. Solid-state controls are generally equipped in fans with controls that have predetermined settings, such as low, medium and high.
The solid state device in or around the fan motor could be defective and in need of replacement.
Dec 07, 2017 | Hampton Bay 52 In. White Redington...
New Hampton Bay ceiling fans spin too slow
Slow spinning of the fan might be caused by a low voltage. Is there any way you can measure the voltage, and if the wires are properly connected, check for any loose wiring or rust in between connections. Maybe the breaker that supplies power to the fans has a loose connections inside, try putting a new breaker of same rated current. Check if those three fans are connected to the same breaker. Breaker can go bad from the inside not doing a proper connection and supplying a low voltage, this might be causing the slow spinning of the fan. Second the black box in the space with all the wires is called the capacitor.
May 30, 2009 | Hampton Bay 24750 Huntington III Ceiling...
High speed only 60rpm
I too just installed a 68" Altura and noticed a huge difference in fan speed. I spoke to a rep for the manufactorer and found out that the high, medium, and low rpms are 70, 45, and 25. The typical 52" fan has rpm speeds of 190, 130, and 75. The kicker is airflow. The 68" moves 7,808, 4,417, and 2,953 cfms on high, medium, and low; the 52" fans move 5,503, 4,087, and 2,509 cfms.
Jun 10, 2008 | Hampton Bay 24002 Ceiling Fan
Hampton Bay Ceiling Fan At Slow Speed
I recently replaced my hampton bay fan for the same reason (slow at all speeds) and discovered scorched and melted capacitors and wiring inside the fan. My suggestion is to stop using fan and replace immediately.
Aug 10, 2007 | Hampton Bay 52 In. White Redington...
Hampton Bay 52 In. White Redington III¿ Ceiling Fan w/ Remote Control & Light Kit Logo
62 people viewed this question
Top Hampton Bay Dryers Experts
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
