Question about Dryers
Dryer does not heat up
I have a ADMIRAL 20 pound Capacity heavy duty with Model # LDGA400AAW, SERIAL#KH18442. When I put a load in turn it on the tub spins. But does not heat up. Took the top and front of the housein off. Took tub out to see if any thing looked brokin. I have noticed that the blower is missing a clap, cleaned everything around it. Would this be the cause or a sensor is not working.  The igniter is still together. Please help me THANK YOU
  • 248 Answers
  Does the ignitor glow at all?  If it comes on then goes back out you may have a bad burner coil.  If it doesn't and the ignitor is good you may have a bad hi-limit stat.  Check your vent for restrictions.  If it is full of lint you probably have  bad hi-limit.  This is usually mounted on top of burner assembly.
Posted on Oct 15, 2007
What is the capacity on a Admiral Mega22Plus heavy duty dryer?
The largest admiral dryer which has 27'' x 27'' dimensions is 7 cu ft.
Jan 15, 2017 | Admiral Dryers
Admiral designer series heavy duty giant capacity 20 lb dryer
two possible problems
the air blower is not running properly
too many clothes being dried restricting air flow
Nov 24, 2016 | Admiral Dryers
Admiral heavy duty super capacity dryer won't heat up.
see this causes , fix it. God bless you, use the common sense
Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Thermal Fuse / Thermal Cut out
On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel or behind the front panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing or is sometimes round and made of metal and plastic.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse this is the most common reason for blowing the fuse. (You can't re-set this type of fuse.)
Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Sep 28, 2012 | Admiral Dryers
Admiral heavy duty super capacity 5 cycle3 temperature won't start
dryer will not start when start button id pushed
Aug 07, 2012 | Admiral Dryers
Admiral heavy duty super capacity 5 cycle 3 temperature only heats some time
susara awz 7457 ne greje koji sum moguci kvarovi jel moye iko da mi pomogne..unapred hvala
Nov 28, 2011 | Whirlpool LER5636P Electric Dryer
Admiral Heavy Duty Super Capacity Plus dryer does not start when button is pushed. The dryer buzzes when the start button is pushed, but the dryer will not start tumbling. The model number is ADE7005AYW...
Motor runs, but drum does not turn
1. Broken or slipping belt---replace
2. Loose pulley---tighten pulley on shaft
3. Drum jammed or bearing frozen---check for foreign object & clear it
Clean or replace bearing
Sep 21, 2011 | Dryers
Admiral 6.5 Cu. Ft. Super Capacity Electric Dryer not drying load
does the admiral aed4475tq have a reset button it will not turn on it is only 9 months old
Nov 29, 2009 | Dryers
Admiral washing machine no cold water
HI, this is a faulty inlet valve assembly. you should replace this failing component asap if possible.This will fix the issue.
Jun 22, 2009 | Admiral Washing Machines
Ultimate care heavy duty dryer is not heating
SOUNDS LIKE YOVE GOT A CLO OF LENT IN THE LINT BASKET CLEAN AND LET ME KNOW HOW IT TURNS OUT
May 03, 2009 | Dryers
Dryers Logo
372 people viewed this question
Top Dryers Experts
Marvin
Marvin
