Question about Whirlpool 18.2 cu. ft. Top Freezer Refrigerator ET18PKXG
Leaking freezer into fridge
Freezer is leaking water into the main fridge. Both temperatures in each compartment are adequate but the freezer appears to be leaking water into the fridge. The fridge is level and not over packed. It's a whirlpool top freezer fridge. Any suggestions?
  • nthomas37 May 15, 2009
    That is the case the hole was completely frozen up. What part could we install to prevent this from happening again? Your advice was very helpfull!!! :)
    Thank you so much! We're canadian so i think we'll pick it up at a hardware store here. We appreciate the help! You saved us buying a new fridge!! :)
    President:
  • 1,136 Answers
Hi, What has happened is that the drain hole in the freezer has frozen up and the defrost water is dripping into the fresh food area.
Remove the floor panel and the rear fan cover in the freezer and you see the ice that is blocking the drain.
Be carefull when removing the ice. DO NOT use a sharp object. The best way is to use a hair dryer.
Once you locate the drain hole, you will need to melt the ice down in the drain hole too. For this, you can use the hair dryer or poor a few glasses of hot water (sopping up the water between each glass).
What you will need to do after the drain is open is to put an after market drain heat transfer kit on to prevent this from reaccuring.
Please let me know if this is the case and I can get you the right part# or even send you the part.
Thakns
Vic
Posted on May 15, 2009
  • Victor
    Victor May 15, 2009
    The part# 819043
    www.whirlpoolpartssurplus.com is my parts site if you need to order one.
    You're very welcome on the support.
    Vic
  • Victor
    Victor May 15, 2009
    I understand. I appreciate that you checked.
The freezer compartment of my F & P Model E522B Fridge/freezer leaks water but the seal appears OK. Why?
draining tube plugged which normally would drain defrost water to a evaporating pan under fridge
Jan 18, 2016 | Fisher and Paykel Active Smart E522B...
What shld settings be as food is freezing in fridge it has side by side knobs saying colder mid less cold it is a westinghouse fan forced frost free freestyle unit
The settings are "relative". Someone with this fridge in Montana may need to run the same fridge with different settings than someone in Texas to get the same temperatures.
Many manufacturers recommend that the fresh food compartment should be 34 degrees F, and the freezer -10 to 0 degrees F. To set this properly, place a thermometer in the freezer (that can display temperatures as low as the desired temperature). Adjust the thermometer for the correct freezer temperature before going on to the fridge. A fully stocked freezer could take 12 hours or more for temperatures to stabilize after making changes to the thermostat. Once the -10 to 0 degree temperature has been achieved, set the fresh food compartment temperature.
Place a thermometer (that can display below freezing) in a 6 (or so) oz flexible plastic cup of water and place on a shelf in the fridge. A glass of water could break if the temperature gets below 32 degrees if the water turns to ice. The water acts as a buffer to rapidly changing temperatures when the door is opened to read the thermometer. If the fridge is "full", allow 24 hours for the temperature to stabilize before making changes.
If the fridge and freezer are empty, changes may be seen in just a few hours or less. Otherwise, wait the 12 / 24 hours for the freezer / fridge compartments.
I hope this helps and good luck!
Sep 06, 2011 | Freezers
Hoover Contour refrigerator HE383TF. Water is leaking inside the fridge. It appears as a puddle under the vegetable compartment and then leaks onto the floor. I have completely defrosted and then poured...
Could be the little red stopper at the back of the fridge on the inside has come off, and this is where the water is coming from, look inside on the lower shelf and you will see a round opening which should have a red stopper in it.
Dec 30, 2010 | Hoover Refrigerators
RED TEMP WARNING LIGHT ON MOTOR RUNNING
I'm sorry to have to tell you that this sounds like a very expensive fault to fix!
Either your fridge/freezer has degassed (lost the refridgerant gas) through a small leak in the pipe system behind or inside the freezer compartment, OR the compressor (what you called the motor) has started to fail.
Either way, these are very expensive repair jobs. It's possible to replace the compressor within about an hour, but if your model is out of guarantee, there will be around a £50/60 Call-out charge and the compressor will cost between £75 and £150 depending on the model.
Alternatively, if the fridge/freezer has lost gas, the engineer would have to try to find the leak - this could be IMPOSSIBLE if the leak is within the pipework inside the back of the fridge or above/below the freezer compartment.
I'm sorry to say that it's looking like you may have to part with a lot of money - or say goodbye to the fridge/freezer you have!
Nov 17, 2009 | Hotpoint FFA70 Bottom Freezer Refrigerator
Fridge compartment is freezing food/milk etc
Sir, To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant. I suggest you to contact the service authority.
Thanks for contacting Fixya.
Sep 06, 2009 | Hoover HFA270K Bottom Freezer Refrigerator
Freezer is building up frost and refrigerator is not cold enoough
Almost certainly, you have a leak within the freezer compartment.
The cooling system will use a divertor valve to concentrate coolant to the fridge or freezer compartment - whichever is necessary to maintain selected temperatures.
If a seal within either compartment is compromised and leaks then the coolant will be excessively diverted to that area in an attempt to lower it's temperature - the other section will suffer since more coolant is diverted to the weaker area; the weaker area that is being excessively cooled will also have more moist air circulating, hence moisture will contribute to a build up of ice - exacerbating the problem.
Ensure that both fridge and freezer doors are closing properly, if they appear to be secure then also check that the seals are airtight - there should be no ice accumulating around them.
You might need to re-align the doors, or less likely, replace the door seals.
Please reply if you require further clarification or help.
May 31, 2009 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
I have a zanussu fridge
Re. Zanussi ZK87/46EFS Fridge Freezer
The same symptom occurred in our fridge freezer. The fridge compartment warmed up whilst the freezer compartment continued to keep temperature.
The cause of our problem was diagnosed as a frozen sensor that controls a flap, that controls the flow of cold air from the freezer compartment up into the fridge compartment. We were advised to power off the fridge freezer (removing all food and trays from the freezer unit first), and to leave it to defrost for 24hrs. We needed to place a few towels on the floor of the freezer compartment to soak up the melt water. After 24hrs we followed the power up instructions in the manual (versions are available online if you have lost yours). Within a few minutes it was obvious that the fridge compartment was being cooled – Problem solved :)
Apr 13, 2008 | Zanussi Refrigerators
Refrigerators Logo
330 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
