Question about ASUS 52x (CD-S520) QUIE TRACK BEIGE RETAIL (ODCDS520) CD-ROM Drive
Dvd/cd rom drives
Wont run when insert a disc
  • 1 more comment
  • letutllit Sep 12, 2008
    Dvd/cd rom drives problem,
  • bilzzy Nov 13, 2008
    hi i have a problem in my rom
  • angela_angel Dec 05, 2008
    I am having the same problem and it is not because of a defective cd-rom. I have checked the bios, and I have even tried an external cd-rom - it still will not recognize the cd-rom.
I cnt run my dvd rom drive but only cd.disk
Posted on Jan 04, 2009
  • 170 Answers
Hi paul12345 this is nichu,
wont run when insert a disc because the autoplay of your cd rom has been disabled.
hence go to the my computer ,right click on the cd rom icon then click on properties then chek the hardware tab and change the settings and restore defaults ,this will autoplayyour cd whenever you insert the cd.
if this dont work then some virus or some other program is blocking the autoplay feature of your system hence find out whats blocking the autoplay feature.
take care
bye
have a nice day
Posted on Nov 07, 2007
2 Suggested Answers
SOURCE:
SOURCE: CD Rom/DVD drive
Check out the Jumper setting of the CD/DVD drive as the Jumper setting is not proper or your H-disk and CD/DVD drive can have the same jumper setting so only can be used at one time .I think you should also update your CD/DVD driver form your system disk.
Posted on Jul 19, 2008
Cd software disc will not load on to my computer. Isn't being recognized
If in case the cd was not recognized upon loading it to the computer you may do the following to check wether the cd is faulty or the cd drive.
  1. Verify that the correct disc (CD/DVD) is used when prompted to insert the disc.
  2. For programs on DVD, verify that the drive containing the DVD is a DVD drive and not a CD-ROM drive. Most DVD drives will have DVD printed on the front of the drive. For programs on DVD, consider the following:
  • DVD drives can read both DVD's and CD's.
  • CD-ROM drives can read only CD's.
  1. If multiple disc drives (e.g., CD-ROM and CD-RW, or DVD and DVD-RW, or CD-ROM and DVD-RW, etc.) exist on the computer that can read the disc (refer to the items under Step 2), insert the CD or DVD into the other drive and try the program again.
  2. If you are attempting to install a program and the installation does not begin after inserting the CD/DVD into the proper drive, refer to the program's instructions for the installation procedure.
  3. Clean the CD/DVD in the following manner:
  1. Place a small amount of nonabrasive liquid soap on the shiny side of the CD/DVD.
  2. Using your fingertips and warm water, gently rub the soap on the CD/DVD in a circular motion.
  3. Rinse the CD/DVD thoroughly and dry it using a clean, soft T-shirt or lint-free towel. (Do not use paper towels or tissue paper.)
  1. Try to use a different CD or DVD in the drive to see if that disc can be read.
  2. If possible, insert the problem CD or DVD into the DVD or CD drive of another computer to see if the issue persists.
Mar 16, 2011 | Logitech C500 Up to 1280 x 1024 pixels 30...
I put in a blank cd and I cannot burn it because in my computer it shows that there is no cd inserted
Here you go...I hope this works for you....
CD/DVD Is Not Recognized
spacer.gif spacer.gif spacer.gif spacer.gif Many times, after inserting a disc into the CD or DVD drive, the disc is not recognized by that drive. CD-read and DVD-read issues can be caused by many sources. Perform the procedures presented in this General Computer Advice article when troubleshooting CD-read and DVD-read issues.
Begin with the first procedure and continue through the list. Try using the CD or DVD after each procedure is completed. For any procedure that requires changing current system settings, record the original settings before completing the procedure.
  2. For programs on DVD, verify that the drive containing the DVD is a DVD drive and not a CD-ROM drive. Most DVD drives will haveDVD printed on the front of the drive. For programs on DVD, consider the following:
Apr 01, 2010 | LG GSA-H55N DVD-RAM Burner
I have a dell latitude D620. and it wont read from the cd/dvd drive. when the disc is inserted you can hear the disc start up and rotate and see the cpu light flashing but nothing else happenshen...any...
The Readhead off the drive is broken and refuses to move.
only way to fix this is change the cd/dvd drive.
This is your solution. Please vote!!!
Jan 18, 2010 | Dell DVD-rom DVD Drive
I purchased a CD-Rom advertised on Amazon as compatible with Asuseeepc and I wanted it for use with the DVD support disc. It works fine with cds but does not recognize dvds when inserted. I have been
A CD-Rom will only recognize CD's. It must be a DVD-ROM to recognize DVD's. DVD-ROM will recognize CD's ,but not the other way around. No drivers needed for thes, they are plug and play.
Char S.
May 20, 2009 | Teac PortaCD 224PE External 24x CD-ROM...
Dell PC with XP DVD s wont read but CD s play
I had the same problem. Discovered that the drive was CD only. I think "raph quintos" has the right idea.
Mar 02, 2009 | Dell XPS 400 PC Desktop
Do not recognize any cd/dvd in dell vostro 1510 bios A13
i have dell vostro 1510 labtop < bought from SA 2 y ago, dvd rom not work, always rejected when inserted, also bluetooth and toutch pad not recognized, i use windows 7
find me a solution
Jan 24, 2009 | Dell DVD-rom DVD Drive
ACER 4520 CD-RW/DVD-ROM its pops up insert disc
you can try two solutions
1) go to device manager and uninstall the primary and secondary ide controller under the IDE ATA/ATAPI controllers and than restart the system and than chk it if that works out
2 ) if the first option doesnt work try to update the firmware of the drive
Sep 09, 2008 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
ASUS 52x (CD-S520) QUIE TRACK BEIGE RETAIL (ODCDS520) CD-ROM Drive Logo
435 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Thomas F. Schneider
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
